Reading: Converter Instruction in Siemens PLC Programming
Inst Tools > Blog > PLC Tutorials > Converter Instruction in Siemens PLC Programming
Last updated: March 4, 2021 1:11 pm
3 Min Read
Let’s study the working of converter instruction in Siemens PLC programming using different ladder logics and programs.
Converter Instruction in PLCBlock DescriptionRound to double integer:Truncate double integer part:Ceiling:Floor:Ladder LogicLadder Description:
Block Description
It reads the input floating point value and converts it to double integer and round to nearest integer. The result is output by the parameter OUT.
Rounding to Nearest Integer in PLC
It reads the input floating point value and converts it to double integer and round to zero mode. The result is output by the parameter OUT.
Truncate Double Integer Part in PLC Logic
Ceiling:
It reads the input floating point value and converts it to double integer. The result is the lowest integer which is greater than the floating point number i.e  Round to + infinity mode. The result is output by the parameter OUT.
Ceiling Instruction in PLC
Floor:
It reads the input floating point value and converts it to double integer. The result is the greatest integer component which is greater than the floating point number i.e Round to -infinity mode. The result is output by the parameter OUT.
Floor Instruction in PLC
Ladder Logic
PLC Programming Example using Converters
Ladder Description:
Network 1:
If I0.0 is pressed, value in MD0 (99.78) is read as a floating point number and converted to the closest double integer(100). The result of round to integer is stored in MD4(100).
Network 2:
If I0.0 is pressed, value in MD0 (99.78) is read as a floating point number and converted to the double integer. The integer part of the floating point number is the result. The result is stored in MD12 (99).
Network 3:
If I0.0 is pressed, value in MD0 (99.78) is read as a floating point number and converted to the double integer by round function . The result is stored in MD12 (100).
Network 4:
If I0.0 is pressed, value in MD0 (99.78)is read as a floating point number and converted to the double integer by the round to – infinity mode. The result is stored in MD16(99).
Note: For positive numbers, trunc and floor give the same result. But for negative numbers, floor rounds down and trunc rounds up. This is because trunc always rounds toward 0.
Author: Hema Sundaresan
  • JUMP Instruction in PLC Programs
  • Master Control Reset (MCR) in PLC
  • One-Shot Rising & Falling Instructions
  • Sequence and Logic Control in PLC
  • Scaling with Parameters Instruction
  • What is DCS and ESD Systems?
What is an Instruction List? – PLC Programming
Steps in PLC System Design
PLC Instruction List for Motor Reverse and Forward Direction
Difference Between PNP and NPN Sensors
Ladder Logic Example with Timers
Studio 5000 Tutorial: PLC Programming for Digital Alarms
PLC Programming Projects for Beginners
Drive Multiple Speeds with Different Reference using PLC
Types of Expressions in the SCL Language of the Tia Portal
PLC Code to Start & Stop Motor and Pump as per Logic
Grounding Electronic Equipment
Importance of Grounding Electronic Equipment
How to Choose a PLC
How to Choose a PLC for New Project? – Criteria for Selection of PLC
Types of Industrial Relays
What is a Relay? Types of Industrial Relays
PLC Motor Control Circuit-3
Basics of PLC Programming
Single-Acting Cylinder Control Operation using Proximity Sensor
Single-Acting Cylinder Control using Proximity Sensor
Network Switch
Compare Servo Motor and Stepper Motor
Level Transmitter configuration in PLC
Scaling with Parameters (SCP) Instruction in PLC
Difference Between Wifi and Industrial Wireless
Industrial Automation Cold and Hot Standby
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
2-wire loop-powered transmitter
Loop Controller HART Signal Noise
Electrical bonding jumpers
Proper Sizing of Conductors
Gas Analyzers Interview Questions
Gas Analyzers Interview Questions and Answers
Vortex Flow Meters
All About Vortex Flow Meters
Allen-Bradley MicroLogix 1000 controller
PLC Switch Actuation Status
