Reading: Control Valve Parts Questions and Answers
Inst Tools > Blog > Control Valves > Control Valve Parts Questions and Answers
Test your knowledge of control valve parts and components with our questions and answers related to industrial applications.
Last updated: August 31, 2024 8:16 pm
Control Valves Instrumentation MCQ
2 Comments
16 Min Read
Control Valve Parts and ComponentsWhat role does the Diaphragm play in a diaphragm-actuated control valve?What is the role of the spring in a spring-and-diaphragm actuator?What does the Actuator Stem do in a control valve?The Diaphragm Case in a control valve serves what function?The Scale Plate on a control valve is used for what purpose?What is the main role of the Stem Connector in a control valve?The Yoke in a control valve assembly provides support to which component?What is the function of the Packing Flange in a control valve?What does the Packing Follower do in a control valve?What is the purpose of the Yoke Clamping Nut in a control valve?The Gland Packing in a control valve is primarily used for what?The Valve Stem in a control valve is responsible for which action?What is the main function of the Bonnet in a control valve?What is the primary function of the Rain Cap on a control valve?The Eye Bolt in a control valve assembly is mainly used for what purpose?The Stud Bolt and Nut in a control valve assembly primarily serve what function?The Gasket in a control valve assembly is used for what purpose?What role does the Guide Ring play in a control valve?The Guide Bushing in a control valve assembly is mainly used for what?What is the function of the Valve Plug in a control valve?The Seat Ring in a control valve assembly is primarily responsible for what?What role does the Valve Body play in a control valve assembly?The Adjusting Screw in a control valve actuator serves what purpose?What is the purpose of the Cylinder in a pneumatic control valve actuator?The O-Ring in a control valve is used for what purpose?What is the primary function of the Piston in a control valve actuator?What role does the Yoke O-Ring play in a control valve assembly?The Stem Clamp in a control valve is primarily used for what purpose?What is the function of the Upper Packing in a control valve?The Yoke Clamp in a control valve assembly is used for what?What role does the Packing Spacer play in a control valve?The Bonnet Flange in a control valve serves what function?What is the main purpose of the Seat Retainer in a control valve?The Seat Ring Gasket in a control valve assembly is used for what purpose?What is the role of the Adjusting Screw Gasket in a control valve?The Spring Button in a control valve actuator serves what purpose?What is the primary function of the Piston Retaining Nut in a control valve actuator?What does the Actuator Stem Spacer do in a control valve?The Actuator Stem Bushing & O-Ring in a control valve assembly are primarily used for?What role does the Stem Bellows play in a control valve?The Cylinder Retaining Ring in a pneumatic control valve actuator serves what function?What is the purpose of the Stroke Plate in a control valve?What purpose do the Upper Stem Guide & Guide Liner serve in a control valve assembly?What is the purpose of the Bonnet Flange Bolting in a control valve?What is the function of the Lower Packing Spacer in a control valve?What role do the Lower Stem Guide & Guide Liner serve in a control valve assembly?What is the purpose of the Bonnet Gasket in a control valve?What is the primary responsibility of the plug in a control valve assembly?Which part of a control valve assembly is critical for adjusting the tightness of the seal around the valve stem?Which component helps in sealing the valve to prevent leakage?
The following control valve video provides detailed explanations and tests your skills on valves.
Question 1
A. Transmits actuator force
B. Reduces pressure
C. Seals valve body
D. Regulates flow
Show the Answer
Question 2
A. Provide feedback on valve position
B. Seal the valve body and actuator
C. Transmits actuator force
D. Return the valve to its original position
Show the Answer
Question 3
A. Seals the valve
B. Guides the plug
C. Transmits movement
D. Connects to diaphragm
Show the Answer
Transmits movement
Question 4
A. Holds packing materials
B. Protects diaphragm
C. Houses the spring
D. Seals the valve body
Show the Answer
Protects diaphragm
Question 5
A. Displays flow rate
B. Adjusts the valve
C. Shows valve position
D. Secures the stem
Show the Answer
Question 6
A. Seals the valve
B. Supports the yoke
C. Joins actuator stem and valve stem
D. Connects valve to piping
Show the Answer
Question 7
A. Valve stem
B. Actuator
C. Valve body
D. Bonnet
Show the Answer
Actuator
Question 8
A. Guides valve stem
B. Compresses packing
C. Seals valve body
D. Holds valve bonnet
Show the Answer
Compresses packing
Question 9
B. Seals valve body
C. Compresses gland packing
D. Secures the actuator
Show the Answer
Question 10
A. Seals the valve body
B. Adjusts actuator tension
C. Secures stem connector
D. Locks yoke to valve body
Show the Answer
Question 11
A. Sealing against leakage
B. Guiding the valve plug
C. Lubricating the stem
D. Reducing stem friction
Show the Answer
Question 12
A. Supporting the actuator
B. Guiding the plug
C. Sealing the valve body
D. Opening and closing the valve
Show the Answer
Question 13
A. Supports the actuator
B. Guides the stem
C. Compresses the spring
Show the Answer
Question 14
A. To prevent dirt
B. To shield against rain
C. To stop leakage
D. To regulate flow
Show the Answer
Question 15
A. Lifting the valve
B. Adjusting the valve
C. Measuring pressure
D. Securing the valve
Show the Answer
Lifting the valve
Question 16
A. Aligns the actuator
B. Secures bonnet to body
C. Adjusts valve position
D. Compresses packing
Show the Answer
Question 17
A. Aligns the valve stem
B. Supports the actuator
D. Seals between body and bonnet
Show the Answer
Question 18
B. Seals the valve body
C. Centers the valve stem
Show the Answer
Question 19
A. Guiding the valve plug
B. Supporting the actuator
D. Aligning the valve stem
Show the Answer
Question 20
A. Regulates fluid flow
C. Seals the valve body
D. Guides the stem
Show the Answer
Question 21
C. Supporting the actuator
D. Compressing the spring
Show the Answer
Question 22
A. Compresses the packing
B. Houses the plug and seat
C. Guides the stem
D. Contains the actuator
Show the Answer
Question 23
A. Tunes spring tension
B. Guides the valve stem
C. Adjusts flow rate
D. Secures the diaphragm
Show the Answer
Question 24
A. Contains the pressurized air
B. Houses diaphragm
C. Contains actuator spring
D. Guides the valve stem
Show the Answer
Question 25
A. Compresses gland packing
B. Reduces stem friction
C. Aligns the actuator
D. Seals against fluid leaks
Show the Answer
Question 26
A. Regulates flow rate
C. Converts pressure to motion
D. Supports the actuator
Show the Answer
Question 27
A. Seals between yoke and packing
B. Seals between yoke and bonnet
C. Supports the actuator
D. Seals between yoke and plug
Show the Answer
Question 28
A. Reducing stem wear
B. Adjusting the flow rate
C. Securing the stem to actuator
D. Sealing the valve
Show the Answer
Question 29
A. Reduces stem friction
C. Seals against leakage
Show the Answer
Question 30
A. Secures the yoke to the valve body
C. Guides the valve plug
D. Seals the valve
Show the Answer
Question 31
A. Adjusts flow rate
B. Maintains packing alignment
Show the Answer
Question 32
A. Compresses packing
C. Attaches the bonnet to the valve body
D. Connects the actuator
Show the Answer
Question 33
B. Holds the seat ring in place
C. Guides the valve stem
D. Seals the bonnet
Show the Answer
Question 34
B. Seals the valve plug
C. Prevents leakage around the seat ring
Show the Answer
Question 35
A. Adjusts the stem position
D. Prevents leakage at the adjusting screw
Show the Answer
Question 36
A. Distributes spring load evenly
Show the Answer
Question 37
A. Seals the actuator
B. Adjusts flow rate
C. Secures the piston to the actuator stem
Show the Answer
Question 38
A. Adjusts spring tension
B. Aligns the actuator stem
C. Supports the piston
D. Seals the actuator
Show the Answer
Question 39
A. Supporting the bonnet
B. Compressing the packing
C. Adjusting the spring
D. Sealing and guiding the stem
Show the Answer
Question 40
C. Seals against fluid leakage
Show the Answer
Question 41
B. Secures the cylinder
Show the Answer
Question 42
D. Measures valve stroke length
Show the Answer
Question 43
A. Compressing the packing
D. Guiding and stabilizing the stem
Show the Answer
Question 44
A. Attaching bonnet flange to valve body
B. Securing the actuator
C. Compressing the packing
D. Sealing the valve plug
Show the Answer
Question 45
B. Aligns the stem packing
C. Adjusts valve flow
Show the Answer
Question 46
A. Aligning and stabilizing the stem
B. Sealing the valve body
D. Guiding the valve plug
Show the Answer
Question 47
C. Seals between body and bonnet
D. Compresses the packing
Show the Answer
Question 48
A. Guiding the stem
C. Regulating flow through the valve
D. Sealing the valve body
Show the Answer
Question 49
A. Actuator
B. Gland follower
C. Valve body
D. Valve plug
Show the Answer
Gland follower
Question 50
A. Actuator
B. Valve plug
C. Gasket
D. Valve stem
Show the Answer
Gasket
  • Valve Functions and Basics
  • Control Valve Selection Guide
  • Proportional Valve and Servo Valves
  • Control Valve Stem Packing Replacement
  • Control Valve Installation & Maintenance
Trip Valve Principle
100 Test and Electrical Measurement Objective Questions and Answers
Common Terms Used in Control Valves
Multiple Choice Questions on Sensors & Transducers
What is Mixing or Diverting Valve ?
What is Globe Valve ?
2 Comments
  • Shreyash Kumar says:
    September 13, 2024 at 7:55 am
    thank you
    nice question in control valve and good question and my knowledge is good with read in control valve question
What is Valve Packing ?
What is a Electric Motor Actuator ?
Digital Input Output Devices Objective Questions
Electro Pneumatic Valve Positioner Schematic & Principle
What is Poppet Valve? When we Use a Poppet Valve?
Motor Operated Valve Problems and Troubleshooting
Temperature Balance System Objective Questions
Magnetic Tape Recorders Objective Questions
How to Protect Pumps from Cavitation
How to Protect Pumps from Cavitation? – Reasons, Solutions
ON OFF Valve Parts
ON OFF Valve Preventive Maintenance and Testing Procedure
Mechanical Systems Objective Questions
Types of Pressure
Types of Pressure – Instrument Questions and Answers
2-way solenoid valve Normally Closed
What is a 2-way Solenoid Valve ?
fluid flow reversed through a Control Valve
What happens when Fluid Flow Reversed through Control Valve?
Objective Questions on Valves
Induction Motor Phasor Diagram
Profibus Listener Principle
Profibus Listener
Electrical Engineering Materials Objective Questions
200 Electrical Engineering Materials Objective Questions & Answers
Stability in Frequency Domain
Closed-Loop Frequency Response
thermocouple voltages
Manually Interpreting Thermocouple Voltages
Annunciators - 2
What is a Annunciator ?
Flow Transmitter Readings mismatch with DCS
Side Mounting Float Switch Working Principle
