Reading: Control Valve Fail Safe Action
Inst Tools > Blog > Control Valves > Control Valve Fail Safe Action
Last updated: July 25, 2019 12:00 pm
Control Valves
3 Comments
There are two primary system considerations centering around an emergency operational situation for control valves.
Control Valve Fail Safe ActionI. Loss of Instrument Air Supply Pressurea.) Fully Closeb. Fully Openc.) In Last Positiond.) Continue ThrottlingII. Loss of Electrical Powera.) Fully Closeb.) Fully Openc.) In Last Position
I. Loss of instrument air supply (IAS) pressure
II. Loss of electrical power
There are four choices as to control valve “response” to the emergency condition :
a.) Fully Close
b.) Fully Open
For either fail-safe loss of IAS or loss of electrical power, it is the actuator’s benchset range spring that “drives” the control valve’s plug to its fail-safe open or closed position.
a.) Fully Close
The actuator’s benchset range spring “drives” the valve plug “closed” when loading air pressure goes towards or near 0 psig. (ATO-FC “Reverse”)
Loss of Instrument Air Supply to Control Valve
Because IAS piping systems can be extensive (big), the IAS can decay too slowly causing operational problems.
In such cases it may be desirable to use a 3-way pilot switching valve to “anticipate” the eventual loss of IAS and quickly stroke the control valve to its fail-safe position, eliminating the transitory operational effects of the slow decay.
b. Fully Open
The actuator’s benchset range spring “drives” the valve plug “open” when loading air pressure goes toward or near 0 psig. (ATC-FO “Direct”)
A similar scheme to I.a. previous may be applied for ATCFO arrangements for fail open control valves to eliminate transitory effects.
This is accomplished with a “lockup valve”, which is a 2- way pilot switching valve. If the air pressure is lost from the control loop’s airset, the lockup valve will “close” and “trap” the air within the actuator’s loading chamber.
If no air leaks are present, the control valve will stay at the last throttling position. Such loops are normally “local”. (Control valve action is a non-issue.)
Control Valve in Last Position
This is an “elaborate” system that can be accomplished two different ways
i.) Volume Tank
A volume tank stores a limited supply of IAS to sustain normal operation for a finite time period, i.e. approximately up to a hour.
Volume Booster for Control Valve
ii.) Alternate Supply
A high pressure cylinder is on standby with an alternate gas, usually GN2. If IAS pressure falls below 50 psig, the alternate gas will take over to supply pneumatic control. The high pressure will allow for several hours of sustained operation, enough time for the emergency loss of the IAS to be restored.
Such applications are normally for “very important (critical)” services. Such loops are normally “local” and pneumatic only; i.e. no electrical power involved except the low pressure alarm switch.
Control Valve Alternate Air Supply
Protection for loss of electrical power is indirectly accomplished thru the use of a solenoid valve. In normal operation the solenoid valve is energized electrically; in an emergency loss of electrical power the solenoid valve is de-energized and trips to the “shelf-position”. Solenoid voltage can be 120 VAC, 240 VAC, 125 VDC, 24 VDC, etc.
a.) Fully Close
By blocking the LOAD air to the actuator and venting the air within the actuator’s loading chamber to atmosphere (P = 0 psig), the actuator’s benchset range spring “drives” the valve plug “closed”. The solenoid valve is a 3-way type.
Control Valve Loss of Power
b.) Fully Open
By blocking the air to the actuator and venting the air within the actuator’s loading chamber to atmosphere (P= 0 psig), the actuator’s benchset range spring “drives” the valve plug open. The solenoid valve and tubing interconnection is identical to the II.a. case previous.
This is accomplished with a 2-way solenoid valve. In the “energized” condition, the solenoid valve ports are “open”; loading air passes thru. In the “de-energized” condition, the solenoid valve “closes” and traps the air within the actuator’s loading chamber.
If no air leaks are present, the control valve will stay at the last throttling position. (Control valve action is a non-issue.)
Abbreviations :
  • IAS : Instrument Air Supply
  • FTC : Fail to Close
  • FTO : Fail to Open
  • FO : Fail Open
  • FC : Fail Close
  • S/SV : Solenoid Valve
Articles You May Like :
Solenoid Valves Questions
What is 3-way Solenoid Valve ?
PLC Valve Control Ladder Logic
How Diaphragm Valves Work ?
Solenoid Valve’s Energized
Air Filter Regulator Working Principle Animation
What is Split Range Control Loop ?
How Ball Valves Work ?
What is an Altitude Valve?
Pressure Relief Valve Principle
Difference between Butterfly Valves and Ball Valves
3 Comments
  • Priyadarshini says:
    October 11, 2016 at 8:16 am
    hi sir,
    Thank you very much for doing this incredible work!!! this website is highly informative and very useful to instrumentation engineers like me!!!keep doing this great job!!!!
    Many thanks once again!!!
    October 11, 2016 at 8:27 am
    Hi Sir,
    i have a question if i have a control valve, which is actuated by an interlock via a solenoid under trip conditions and if the fail position of the control valve is FLC.
    Can you please explain what will be the position of the valve and how it is established during
    1. Loss of instrument air supply
    2.Loss of electric power
    • S Bharadwaj Reddy says:
      October 11, 2016 at 11:46 am
      In case of loss of air supply or power, the valve will be in Close Position.
Common Valve Abbreviations in US Engineering Drawings
What is a Electric Motor Actuator ?
Short Notes on Different Valve Types
Solenoid Valve Troubleshooting Tips
What is ON/OFF Valve ?
What is a Disc Valve ?
What is Needle Valve ?
What is Motor Actuator ?
Piping Schematic for Two Solenoid Valves Double Acting
Different Types of Control Valve Actuators
Types of Failures in Control Valves
Installation of a Control Valve
How to Install a Control Valve?
What is a Servo Valve?
What is a Servo Valve? – Principle and Advantages
Rupture Disc
Working of Rupture Disk
control valve sizing problem
Importance of Proper Control Valve Sizing
Types of Control Valves Noise
valve plug and seat damage
Control Valve Erosion Problems
HAZOP
What is HAZOP ?
Basics of FOUNDATION Fieldbus
Difference between Fieldbus, Profibus and HART Protocols
Steady-state process gain
Steady-State Process Gain
Power Plant Blackout
What Happens When the Power Plant Blackout?
Salient Pole Machines Quiz
PLC Power Supply and Operating Voltages
Omron PLC for Product Painting with Integrated Weighing System
Pressure Gauge with Syphons
Pressure Gauge Syphons Principle
