Reading: Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
Inst Tools > Blog > Control Systems > Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
Control loops are the building blocks of control systems and come in various configurations such as open, closed, cascade, feedforward, ratio.
Last updated: October 17, 2023 12:38 pm
Control Systems PLC Tutorials
Control loops are the building blocks of control systems and come in various configurations, depending on the number of variables being controlled, the type of control, and other factors.
Comparison of Control Loops - Open, Closed, Cascade, Feedforward, Ratio
Below is a comparison table that outlines the key features of commonly used types of control loops such as open, closed, cascade, feedforward, ratio, and split range loops.
ParameterOpen LoopClosed LoopCascade LoopFeedforward LoopRatio Control LoopSplit Range Loop
Principle of OperationNo feedback is used. Output is neither measured nor adjusted to achieve a desired result.Uses feedback to adjust the control action based on the output.Two control loops where the output of one serves as the set point for another.Anticipates disturbances and proactively adjusts the system.Maintains the ratio between two variables.Uses multiple control devices to handle different ranges of a process variable.
TheoryA predetermined input directly controls the action, irrespective of the output.Measures output, compares to a set point, and adjusts accordingly.Main loop controls a process variable, secondary loop controls another variable.Identifies disturbances and proactively makes adjustments before they affect output.Measures two variables, adjusts one to maintain a set ratio with the other.The controller splits its output to different control elements based on setpoints.
AdvantagesSimple design. Generally less expensive and less complex.Higher accuracy due to feedback. Adaptable to system changes.Better disturbance rejection. Enhanced control accuracy.Preemptively deals with disturbances. Enhances output quality.Ensures consistent ratios. Useful for processes like blending or mixing.Efficiently manages processes with a wide operation range.
DisadvantagesNo correction for disturbances. Potential inaccuracy.More complex design. Potential for instability.More complex setup. Needs tuning of two controllers.Requires knowledge and model of the disturbance. Complexity increases.Requires accurate measurement. If one variable falters, the ratio is affected.Potential for overlap or dead zones. Needs careful tuning.
Response to DisturbancesPoorGoodGoodGoodGoodVariable
AccuracyLowHighHighModerate to HighHighModerate to High
StabilityVariableGenerally stableGenerally stableCan improve stabilityGenerally stableGenerally stable
ComplexitySimpleModerateComplexModerate to ComplexComplexModerate to Complex
CostLowModerate to HighHighModerate to HighHighModerate to High
Control ActionPre-determinedDynamicMultiple, DynamicDynamicDynamicDynamic
Tuning RequiredNoYesYesSometimesYesYes
Application ExamplesTimers, Basic motorsHVAC, Industrial processesComplex systems with interacting variablesSystems with measurable disturbancesMixing, Blending processesHeating and cooling systems
Feedback RequiredNoYesYesYesOptionalOptional
Brief explanation:
  • Principle of Operation: The fundamental principle that the control loop operates on.
  • Response to Disturbances: How well the loop can handle changes in the system or environment.
  • Accuracy: How precisely the loop can control the process variable.
  • Stability: The loop’s ability to maintain control without oscillating.
  • Complexity: The difficulty level in understanding, implementing, and maintaining the loop.
  • Cost: The relative financial expense of implementing and maintaining the loop.
  • Control Action: Describes the method of control action undertaken by the loop.
  • Tuning Required: Whether the control parameters need to be tuned for optimal performance.
  • Application Examples: Examples of real-world applications where each type of control loop is used.
  • Feedback Required: Whether the loop needs feedback from the process variable.
  • PLC Data Files and Program Files
  • Testing Modbus Communication
  • S7-1500 S7-1200 S7-400 S7-300
  • Static and Temp Variables in PLC
  • Power Supply Sizing for Systems
Tia Portal – Optimized and Standard Data Block Access
Water Fountain Control Logic – PLC Exercises and Solutions
Remote Factory Acceptance Test
Definitions of Electrical Grounding
PLC Ladder Logic Questions and Answers
UPS Working Principle and Types – Offline and Online UPS Systems
Difference Between Wifi and Industrial Wireless
Procedure for Reading or Searching the Tag number in Siemens PLC
Design a Water Pump PLC Program using CX-Programmer
PLC Timer Application in Security Camera Recording
Loop Calibrator to Simulate a 4-20 mA Signal
Pressure Control System Problems
Studio 5000: Programming Three Motors with Fixed Priorities
Studio 5000 Logix Emulate Controller
How to Create New Project in Studio 5000?
pressurized-water reactor
Runaway Processes
Redundant system communication cable
What is Interface Module in Siemens PLC?
de-energized-to-safe-mode
Example Ladder Logic Diagram
What is Relay Logic ?
Nuisance Alarms
What is Alarm Shelving? – Nuisance Alarms, Types, Suppression
OpenPLC - PLC Training for Students - Free Tutorials & Courses
Automatic Car Washing Process using PLC Ladder Diagram
Token Ring Communication
Token Ring and Token Bus Working Animation
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
Structured Text PLC Example for Motor Interlocking and Control
Multistage Flash Drums Erratic Level Readings
Quiz on Thyristor Chopper
What is a Filter Circuit
What is a Filter Circuit ?
Calculate-current-4-20ma-from-process-varibale-pv
Calculate Current (4-20ma) from Process variable PV
