Reading: Centrifugal Compressor near ½-RPM Frequency High Magnitude Shaft Vibrations
Inst Tools > Blog > Root Cause Analysis (RCA) > Centrifugal Compressor near ½-RPM Frequency High Magnitude Shaft Vibrations
Root Cause Analysis (RCA): Compressor near ½-RPM frequency high magnitude shaft vibrations.
Last updated: September 28, 2022 3:20 pm
S Raghava Chari
Root Cause Analysis (RCA) Process
2 Min Read
Centrifugal Compressor Shaft Vibrations ProblemSolution
Article Type:Root Cause Analysis (RCA)
Category:Mechanical
Equipment Type:High Speed, Hi KW Major Rotating Machines
Author:S. Raghava Chari
Note: This root cause analysis (RCA) is from real-time scenarios that happened in industries during the tenure of one or two decades ago. These articles will help you to improve your troubleshooting skills and knowledge.
K-603, a horizontally split 8000 RPM, 2000 KW, centrifugal compressor draws 300 mm WC CO2 and delivers it at 13-bars. It performed fine, but for 45 to 50% x shaft RPM frequency 75 to 100 microns amplitude high shaft vibration problems.
Unable to find a cause, the plant lived with high vibration problems for over 5 years.
Solution
The author learnt from a tech journal article that tilting pad bearings eliminated such vibration problems in a compressor.
Substituting compressor vendor-supplied TPB was the answer.
Author: S. Raghava Chari
  • Process Air Compressor Overhauls
  • Heat Exchanger Root Cause Analysis
  • Mechanical Variable Speed Drives RCA
  • Compressor Case Discharge Temperature
  • TEFC Motors Rampant Winding Burnouts
Discharge Head 3‑monthly leaks of Steam Turbine Driven Centrifugal Compressors
Amine Pump Trip – Root Cause Analysis
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Pulverizer Electrical Problem Solved
Rotary Drier Shell to Split Gear drive eliminates too frequent drive failures
Ball Float Steam Trap
Plant Shutdown Analysis: Valve Closed and SOV Coil Failure
Doubtful Temperature Readings threatens Soaking Pit Wrecks
Instrumentation Engineering Problems Solved – Root Cause Analysis
Thermocouple Extension Lead Problem
Mechanical Temperature Indicators (MTI) Problem
Water Treatment Plant
Bellows Steam Trap
Too Low Efficiency Torque Converter Elimination Attempt
Transformers Coolers Weld Joints Oil
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Industrial Gases
Questions and Answers on Gas
Compressor Coolers
Level Flow Cascade Control Pumping Station
Introduction to Wastewater Treatment Works and Pumping Station
Solving Critical Control Valve Hunting
Solving Control Valve Hunting: Instrument Troubleshooting
Thermocouple Extension Lead Minimizer Circuit
Thermocouple Wires and Extension Lead Issues
Incident Investigation: Motor Operated Valve Lesson
CO2 Stripper Collapsed Internals Revamp
Two Hand Control Logic
Two Hand Control Logic using PLC
Thermocouple Calculations
Single Beam and Double Beam Instruments
A typical wiring diagram from Field Transmitter to Control Room
How to Wire a Field instrument to Control Room with Example
Time Response Analysis
Approximation of Higher-Order Systems by Lower Order
Porpoising PID Controller
Recognizing a Porpoising PID Controller
Components of MCB
Components of MCB – Electrical Engineering Questions
Two solenoid valves circuit
Solenoid Valves Questions & Answers – 4
