Reading: Calculate Flow Transmitter Output Current
Inst Tools > Blog > Flow Measurement > Calculate Flow Transmitter Output Current
A flow transmitter is ranged 0 to 350 GPM, 4-20 mA output, direct-responding. Calculate Flow Transmitter Output 4-20mA Current for 204 GPM.
Last updated: October 31, 2023 12:33 pm
Flow Measurement Formulas
2 Comments
2 Min Read
A  flow transmitter ranges from 0 to 350 GPM with 4 to 20 mA output, direct-responding. Calculate the current signal value at a flow rate  of 204 GPM.
Flow TransmitterFlow Transmitter Calculations
Flow Transmitter
We are solving this problem using the standard 4-20mA Conversion Formula. Click here for the formula
One way we could solve for the amount of signal current is to convert the flow value of 204.
GPM  into a ratio of the flowmeter’s full-flow value,  then apply the same formula we used in the previous example relating percentage to milliamps.
Converting the flow rate into a “per unit” ratio is a matter of simple division since the flow measurement range is zero-based:
Flow Transmitter 4-20 mA formula
Therefore,  the transmitter should output a PV signal of 13.3 mA at a flow rate of 204 GPM.
An alternative approach is to set up a linear equation specifically for this flowmeter given its measurement range (0 to 350 GPM)  and output signal range (4 to 20 mA).
We will begin this process by sketching  a simple graph relating flow rate to current:
flow transmitter formula
We can also solve the problem using a direct formula. Click here for the formula
  • Flow Control Loop Controller
  • Variable Area Flow Meters
  • Linear to Square Root Extraction
  • PV to Percentage Conversion
  • Closed Tank Level Calculations
What is an Insertion Flow Meter? – Types, Principle, Advantages
Basics of Restriction Orifice (RO) – Types, Applications, Standards
Raw Counts to Engineering Units : Conversion Formula
Reasons to Calibrate Different Types of Flow Meters
Basics of Orifice Plates
Target Flow Meter – Working Principle, Advantages, Disadvantages
2 Comments
  • Faran says:
    October 2, 2015 at 7:24 pm
    Also Another Simple way to calculate:
    Signal = 4 – 20 mA..
    So Signal varies between 16 mA
    So Each gallon tends to have (16/350)= 0.046 mA
    So 204 Gallon will make (0.0457 * 204) = 9.33 mA
    Hence Output signal will be 4 mA + 9.33 mA = 13.33 mA
  • aiyaz says:
    November 22, 2016 at 7:33 am
    how calibrate a ff type flow transmitter ABB 2600T range is 53.39mbar and out showing 5000m3/H how calculate plz gv reply on transmitter showing 53.39 m baar and on data sheet showing calibration range 5000 m3/hm confuse
Flow Transmitter Rangeability
Types of Variable Area Flow Meters
How to Select a Rotameter? – Parameters and Applications
What is a Paddle Wheel Flow Meter?
Siemens Pressure Transmitter with Remote Seals Calculations
Orifice Plate Questions and Answers
Flow Standards
DP Level Transmitter Elevation and Suppression Corrections
Transit Time flow meter Theory
Transit Time Flow Meter Principle
DP transmitter
Square-root characteristics of Differential Pressure Flow Meters
Lobed Impeller Flow Meters Working Principle
Orifice Plate Flow Requirements
What are the Orifice Plate Flow Requirements?
Weigh feeders Principle
What is a Weigh Feeder?
Types of Flow Meters MCQ - Instrumentation and Control
Types of Flow Meters MCQ – Instrumentation and Control
Ultrasonic Flowmeters Principle
Factors Affecting the Performance of Ultrasonic Flow Meters
flow Nozzle
Flow Nozzle Principle, Advantages, Disadvantages, Applications
Piezo Electric Transducers Objective Questions
Process Air Compressor Overhauls Eliminated
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
Two-Liquid Manometer Principle
On Delay Timer TON in Tia Portal
Timers in PLC Programming – Siemens Tia Portal Tutorials
gauge’s bourdon tube
Pressure Gauges : Remote and Chemical Seals
Bimetallic Thermometer
Valve Safety Factor
Valve Safety Factor
pressure gauge snubber
Pressure Gauge Snubbers
