Reading: Calculate Current (4-20ma) from Process variable PV
Inst Tools > Blog > Instrumentation Tools > Calculate Current (4-20ma) from Process variable PV
Last updated: November 12, 2019 4:46 pm
8 Comments
1 Min Read
This tool is used to calculate the current signal in the range of 4-20ma using process variable (PV), Upper Range Value (URV) & Lower Range Value (LRV).
This calculation tool is used to find out the equivalent current signal 4-20 ma using PV, URV & LRV.
Calculate current from Process variable:
Where,
PV = Process Variable
URV = Upper Range Value (Transmitter Max scale value)
LRV = Lower Range Value (Transmitter Min scale value)
Note:
For calculating the equivalent current 4-20ma, we have to enter PV, URV & LRV details.
The above calculation tool designed for a standard 4-20 ma signal conversion.
You can convert out of range signal also with the above tool.
(Example: URV = 100, LRV = 0 and PV = 110)
Instrumentation Calculator
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
RTD Calculator : Calculate Temperature from Resistance
Transmitter Current Conversion Tool
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
RTD Calculator : Calculate Resistance from Temperature
8 Comments
  • Nisanth K says:
    April 13, 2015 at 6:37 pm
    Looks like Now it is in hands and can calculate 4-20 ma signal easily in seconds.
    Superb Tool for easy calculation. I Loved your blog and nice creativity.
  • Pavan kamunuri says:
    April 18, 2015 at 6:53 am
    Hi,
    I am Pavan working as assistant engineer, instrumentation. I used your instrumentation tools for calculations.Can you please share the formula for the Calculate current from Process variable conversion tool. Thanks
    • S Bharadwaj Reddy says:
      April 25, 2015 at 2:27 pm
      Hi,
      You find the formula for calculating pv in the below link
      https://instrumentationtools.com/formulas-to-calculate-ma-from-pv/
      Thanks,
      S Bharadwaj Reddy
  • M Kahan says:
    April 22, 2015 at 3:58 pm
    Nice tool.
  • Tinumathew says:
    January 29, 2017 at 4:24 am
    Hello sir thank you very much… I want to know (i mean formula) how to calculate process variable to MA.
    Example 1) range LRV is -17℃ URV is 3.3℃
    If PV is -11.7℃ how much ma.
    Example 2) range LRV is -185mbar URV is -80mbar
    If PV is -72mbar how much ma.
    Example 3) range LRV is 0 barg URV is 34.4barg
    If PV is 19barg how much ma. In this deferent type of range. How can i calculation ma from PV. Sir can you pls explain the formula.I hope you can give the answer. Thanks you sir
    Tinumathew
      January 29, 2017 at 5:08 am
      Hello, You can enter PV, LRV, URV values in the above application and click outside once then it will automatically calculate mA value. For Formula Please check “Formulas”category or Click Here. Regards
  • Sohaib says:
    May 10, 2020 at 12:39 pm
    Which formula best for the conversation of 4-20ma
    y=mx+b or y= 16x/100+4
  • YUVARAJ says:
    September 5, 2022 at 11:28 pm
    We have pv=687.7°c and ma= 9.47 then how can I find LRV & URV
Convert Process Variable to Percentage
DP Flow Transmitter Re-Ranging Calculation
Boiler Drum Level Transmitter Calibration
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
Interface Level Measurement using DP Transmitter
Convert current (4-20mA) to Percentage (0-100%)
Convert Percentage (0-100%) to current (4-20mA)
Conversion of Transmitter Output in Percentage to Process Variable
Density-Measurement-using-DP-Transmitter-for-open-tank
Density Measurement for Open Tank with Constant Level Application
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Wet-leg
Density Measurement using DP Transmitter for closed tank with wet leg
Convert Linear mA to Square root mA
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
Closed-Tank-DP-Type-Level-Measurement-with-Dry-leg-and-transmitter-installed-below-tapping-point
Level Measurement with Dry leg and Installed Below Tapping Point
Convert Linear Percentage to Square root Percentage
Closed-Tank-DP-Type-Level-Measurement-with-wet-leg-and-transmitter-installed-below-tapping-point
Level Measurement with Wet leg and Installed Below Tapping Point
Load Cell Assembly
Urea Bagging Plant – Process Flow
Up Down Counter Objective Questions
Counters Objective Questions
Time Response Analysis
Design Considerations for Higher Order Systems
PLC Programming Questions
PLC Programming Question & Answer
Less than 40% available Plant Air Compressors made available 100%
Less than 40% available Plant Air Compressors made available 100% for Operations
Digital Control Systems
The inverse z-transform & Response of Linear Discrete Systems
Actuators Questions and Answers
