The best 100 PLC projects can be invaluable for engineering students looking to gain hands-on experience. These Programmable Logic Controller projects can range from basic to advanced levels, catering to various industrial applications.
PLC Projects for Final Year Engineering Students
Final-year engineering students often look for projects that are not just challenging but also aligned with real-world industrial applications. Here are 100 PLC-based projects for final-year engineering students with a brief description for each.
Advanced Automation Systems
- Smart Warehouse Management
- Develop a PLC-based system to automate warehouse operations like inventory tracking, sorting, and dispatching.
- Automatic Pharmaceutical Dispensing
- Use PLCs to control the automated dispensing of pharmaceutical items in hospitals, including proper dosages and timings.
- Solar Panel Tracking System
- Create a solar tracking system that moves the solar panel to follow the sun using PLC control algorithms.
- Smart Traffic Control System
- Implement adaptive traffic light timings based on real-time traffic conditions using PLCs and sensors.
- High-speed Rail Signalling System
- Develop a PLC-based control system for high-speed rail signaling, focusing on safety and efficiency.
Process Control and Monitoring
- Chemical Batch Process Control
- Implement a PLC-based control system to handle the mixing, heating, and reactions in a chemical batch process.
- Water Treatment Plant Automation
- Automate the different stages of water treatment including filtration, chlorination, and distribution using PLC.
- Automated Brewery System
- Control the brewing process including mashing, fermentation, and bottling through a PLC-based system.
- Oil Refinery Operations
- Develop a PLC control system for monitoring and controlling the complex processes within an oil refinery.
- HVAC Control with Energy Efficiency
- Implement an energy-efficient HVAC control system using PLCs to monitor and adjust heating, ventilation, and air conditioning.
Industrial Robotics
- Robotic Arm Control
- Develop a PLC program for the precise control of a multi-axis robotic arm used in sorting or assembly lines.
- Automated Guided Vehicles (AGVs)
- Implement PLC-based control for AGVs used in industrial plants for material handling.
- CNC Machine Control
- Use PLC to control a CNC machine, focusing on high precision and multiple axis control.
- Robotic Painting System
- Implement a PLC-based robotic system for automated painting of industrial parts.
- Drone Landing Pad
- Develop a PLC-controlled landing pad with various safety and guidance features for drones.
Advanced Monitoring Systems
- Earthquake Monitoring and Alerting
- Use PLCs to detect seismic activity and trigger alarms or other safety measures.
- Industrial Fire Safety System
- Implement a PLC-based fire detection and control system that can activate sprinklers, alarms, and notify authorities.
- Pipeline Leak Detection
- Develop a PLC-controlled system for detecting and isolating leaks in oil or gas pipelines.
- Real-time Energy Monitoring
- Use PLCs to monitor energy consumption in an industrial plant and suggest optimizations.
- Medical Monitoring System
- Develop a PLC-based system for monitoring vital stats and administering medication in a healthcare sector.
Renewable Energy Systems
- Wind Turbine Control System
- Implement a PLC-based control system for optimizing wind turbine performance based on wind speed and direction.
- Hydroelectric Dam Control
- Use a PLC to control the water flow and turbine speeds in a hydroelectric dam.
- Smart Grid Implementation
- Develop a smart electrical grid that uses PLCs to optimize distribution and handle load shedding.
- Waste-to-Energy Conversion
- Create a PLC-based system to automate the conversion of waste material to energy.
- Solar Water Heating System
- Implement an automated water heating system that uses solar energy, controlled by a PLC.
Industrial Internet of Things (IIoT)
- Remote Industrial Monitoring
- Develop a PLC-based IIoT system for remote monitoring and control of industrial machines.
- Automated Agricultural System
- Use PLC and IoT sensors to automate agricultural processes like irrigation, harvesting, and pest control.
- Smart Building Management
- Implement a PLC-based building management system that integrates lighting, HVAC, and security.
- Supply Chain Tracking
- Use PLCs and IoT to develop a real-time tracking system for supply chain management.
- Predictive Maintenance
- Implement predictive maintenance algorithms in a PLC to forecast machine failures and schedule timely repairs.
Healthcare Systems
- Automated Blood Bank
- Implement a PLC-based system to manage blood storage conditions, blood type sorting, and dispensing.
- Hospital Bed Allocation
- Develop a PLC system to automate the allocation of hospital beds based on patient needs and availability.
- Automated Drug Dispensing in Pharmacy
- Use PLCs to create an automatic system for sorting and dispensing drugs in a pharmacy setup.
Smart Manufacturing
- Quality Inspection Automation
- Implement a PLC-controlled quality inspection line that uses machine vision and other sensors to inspect products.
- Flexible Manufacturing System
- Develop a flexible manufacturing line that can be easily reconfigured for different products, all controlled by a PLC.
- PLC-based 3D Printer Control
- Use a PLC to control a 3D printer, focusing on precision and support for various materials.
Utilities Management
- Waste Management and Recycling
- Implement a PLC system to sort recyclables and non-recyclables in waste management facilities.
- Automated Street Lighting
- Develop a PLC-based control system to adjust street lighting based on time of day or detected movement.
- Water Supply Network
- Create a PLC-based control system to manage water supply networks including pumps and valves.
Food Processing
- Automated Bakery Line
- Implement a PLC system to control various stages of bread-making including kneading, proofing, and baking.
- Automated Beverage Filling
- Develop a PLC-based system for an automated beverage filling line with precise volume control.
- Food Packaging Automation
- Create a PLC-based system to handle the automated packaging of different types of food items.
Maritime Applications
- Automated Fishing System
- Implement a PLC-controlled fishing system to manage nets, winches, and sort catches.
- Port Container Management
- Use PLCs to automate the loading and unloading of containers in a shipping port.
- Submarine Ballast Control
- Develop a PLC system for managing ballast tanks in a submarine to control buoyancy.
Retail and Services
- Automated Retail Checkout
- Implement a PLC-based system for automated scanning and billing in retail stores.
- Smart Car Wash
- Create a PLC-controlled smart car wash system with variable wash modes and billing.
- Automated Restaurant Ordering
- Develop a PLC-based system for automating food ordering and table allocation in restaurants.
Miscellaneous
- PLC-controlled Mini Golf Course
- Use PLCs to create obstacles and track scores in a mini-golf course setup.
- Escape Room Automation
- Develop a PLC-controlled escape room with various automated puzzles and challenges.
Transportation Systems
- Automated Parking Lot
- Use PLCs to manage entry, exit, and slot allocation in an automated multi-level parking lot.
- Railway Crossing Safety
- Develop a PLC-based system that controls railway crossings, including gate movements and signaling.
- Airport Baggage Handling
- Implement a PLC-controlled baggage handling and sorting system for airports.
- Elevator Control System
- Create a PLC-based elevator control system that handles multiple elevators in a building.
- Automated Toll Collection
- Develop a PLC system for automated toll collection that supports various payment methods.
Renewable Energy and Sustainability
- Smart Home Energy Management
- Implement a PLC-based system to manage energy consumption in smart homes, including solar and wind energy sources.
- PLC in Waste-to-Energy Plants
- Use PLC to manage and control the conversion of waste material to energy, focusing on efficiency and safety.
- Automated Composting System
- Develop a PLC-based system for efficient and odor-free composting in community settings.
- PLC in Smart Agriculture
- Implement a PLC-based smart irrigation and crop monitoring system.
- Automated Solar Cleaning System
- Create a PLC-based system for automated cleaning of solar panels to maintain efficiency.
Home Automation
- Smart Lock and Security System
- Develop a PLC-controlled smart lock system with integrated security features like face recognition.
- Home Theater Automation
- Implement a PLC system to control lighting, screens, and sound in a home theater setup.
- Automated Laundry System
- Create a PLC-based system for a complete laundry process including washing, drying, and sorting.
- Intelligent Cooking Assistant
- Use PLCs to manage temperature, cooking time, and stir in an automated cooking system.
- Automated Pet Care System
- Develop a PLC-controlled feeding, cleaning, and monitoring system for pets.
Hazardous Environment Operations
- Automated Chemical Handling
- Implement a PLC system for safe and accurate handling of hazardous chemicals in an industrial plant.
- Mining Automation
- Develop a PLC-based control system for automated drilling and material handling in mines.
- Radiation Monitoring
- Create a PLC system to monitor and manage radiation levels in nuclear power plants.
- PLC in Deep-Sea Exploration
- Implement a PLC-controlled system for deep-sea exploration tasks like mapping and sample collection.
- Explosive Material Handling
- Use PLCs to safely transport and handle explosive materials in a controlled environment.
Utility and Public Services
- Automated Waste Collection
- Develop a PLC system for efficient waste collection in urban areas.
- Water Reservoir Management
- Create a PLC-based control system to monitor and manage water levels in a reservoir.
- Emergency Response System
- Implement a PLC system for optimized emergency vehicle dispatch based on real-time traffic conditions.
- Automated Public Toilets
- Use PLCs to control cleaning, maintenance, and usage of public toilets.
- Smart Bus Stops
- Develop a PLC-based smart bus stop with real-time tracking and schedule updates.
Research and Education
- PLC-based Telescope Control
- Implement a PLC system for automated celestial tracking in a telescope.
- Automated Science Experiment
- Create a PLC-based system to run a series of science experiments with data logging features.
- Classroom Automation
- Use PLCs to automate classroom functionalities like lighting, projectors, and attendance tracking.
- Library Automation
- Develop a PLC system for automated book sorting, tracking, and check-in/check-out processes.
- Automated Test Grading
- Implement a PLC-controlled machine for automated test paper grading and data analysis.
Automotive and Transport
- Automated Car Manufacturing Line
- Use PLCs to control various stages of an automobile manufacturing line, including welding, painting, and assembly.
- Conveyor Belt Sorting System
- Develop a PLC-based system to sort items on a conveyor belt based on weight, size, or other criteria.
- PLC-based Drone Control
- Implement a PLC-controlled system to manage drones for tasks like delivery, surveillance, and more.
- Traffic Light Control System
- Develop a PLC system that manages traffic lights dynamically based on real-time traffic flow.
- Automated Bicycle Sharing System
- Implement a PLC-based system to manage a public bicycle-sharing program including check-in, check-out, and real-time tracking.
Sports and Entertainment
- Automated Bowling Alley
- Create a PLC-based system to control the pin setting, scoring, and lane conditions in a bowling alley.
- PLC in Paintball Arenas
- Use PLCs to manage and control various elements in a paintball arena, such as pneumatic traps and scoreboards.
- Swimming Pool Management
- Develop a PLC-controlled system to manage pool cleanliness, heating, and water levels.
- Automated Shooting Range
- Implement a PLC-based system to manage targets, scoring, and safety measures in a shooting range.
- Race Track Management
- Create a PLC-based system to manage the functioning of a race track including lap timing and safety measures.
Advanced Technologies
- PLC-based AR/VR Systems
- Use PLCs to control augmented and virtual reality systems, focusing on interaction and real-world integration.
- Quantum Computing Simulation
- Develop a PLC-based simulation system to understand quantum computing algorithms.
- Nano-Fabrication Control
- Implement a PLC-controlled system for nano-fabrication tasks in a lab environment.
- Smart Mirror
- Create a PLC-based smart mirror that displays news, weather, and other customizable information.
- Wearable Device Control
- Develop a PLC-based control system for wearable devices like smartwatches or fitness trackers.
Environmental Applications
- PLC in Wildlife Monitoring
- Use PLCs to manage sensors and cameras for wildlife monitoring in remote locations.
- Forest Fire Detection
- Implement a PLC-controlled system to detect and alert about forest fires in real time.
- Air Quality Monitoring
- Create a PLC-based system to constantly monitor and report on air quality in urban areas.
- Flood Alert System
- Develop a PLC system that monitors water levels and weather conditions to provide flood alerts.
- Soil Health Monitoring – Implement a PLC-based system to continuously monitor soil health, nutrient levels, and moisture content.
The list of 100 PLC projects covers a wide range of industries, applications, and complexities. These projects can serve as excellent material to select as your final year engineering projects for students. I hope this list serves as a useful resource.
- PLC Objective Questions
- True or False PLC Quiz
- PLC Multiple Choice Questions
- Troubleshooting PLC
- PLC Animation
