Reading: Automation Panel Electronic Cards Failure investigation
Inst Tools > Blog > Root Cause Analysis (RCA) > Automation Panel Electronic Cards Failure investigation
Discover the causes and solutions for electronic card failures in automation panels. Learn how to prevent damage to instrument systems.
Last updated: September 25, 2024 12:27 pm
vicky
6 Min Read
Learning from an incident in which frequent card failure occurred in a panel.
Automation Panel Electronic Cards FailureRoot Cause AnalysisSolutionVortex CoolerAdvantages of Vortex CoolerConclusion
Panels are one of the important parts of the instrument systems. Most of the system components, i.e. PLC cards, power supply cards, barriers, and many more, are installed inside the panel. This panel can be in the panel room which is also called the rack room and this panel can be in the field also.
The panel room or rack room is usually a place where temperature and humidity are regulated so that the instrument system in the panel room does not get damaged. But the surrounding environment in the field can be good and sometimes too harsh.
Let us see one incident related to this.
Background of the incident:
A panel having a controller and some cards for running a small plant was installed in the field area. A total of 9 cards, 32 barriers, and 3 relays were installed in this panel.
Card Failures in Automation Panels
The temperature of the surroundings is in between 10 degrees Celsius (minimum temperature in the month of December-January) and 35 degrees Celsius (maximum temperature in the month of May-June) during the year. The panel was installed 2 years ago in September month and Instrument Engineers were facing frequent issues of barrier failure in this panel after 9 months i.e. in May month of next year. After a year, the problem of card failure also started.
So, Instrument engineers studied this and came up with a very cost-effective solution. This solution not only saved them from frequent failure of components but also increased the uptime of the plant.
Root Cause Analysis
So, how did the Instrument Engineers come to a solution and what was it?
When the Instrument Engineers started discussing about this problem and a permanent solution to this problem, the Instrument Engineers first doubted the quality of all these failed barriers and cards. However, the Instrument Engineers realized that the quality of these failed barriers and cards cannot be doubted because barriers and cards of a similar lot are installed in other panels and also in different areas.
Now the Instrument Engineers thought that there might be moisture inside the panel which could be causing this problem. So, the panel was thoroughly checked for traces of moisture, but this was also not the problem. The panel was tightly locked and silastic was used on the openings to protect it. Cable glands were perfect and blind plugs in spare cable entry holes were also perfect. Then the Instrument Engineers thought of excessive heat inside the panel which may have damaged these barriers and cards.
So, to verify this, the Instrument Engineers did the thermography and found that many places inside this panel had hotspots of 43 degrees Celsius when the surrounding environmental temperature was just 20 degrees Celsius. Now, imagine the inside temperature when the surrounding environmental temperature reaches 35 degrees Celsius. This will definitely cause damage to the components installed inside the panel.
Solution
The Instrument Engineers installed a vortex cooler for this panel whose approximate cost was around 18,000 Rs. After running the vortex cooler for a few hours, the hotspot of 43 degrees Celsius had become 24 degrees Celsius (in the same surrounding environmental conditions). This vortex cooler gave a huge financial benefit because the component failure frequency was reduced very much which increased plant uptime also.
Some of you might be thinking what is vortex cooler?
Let us have a quick look at a vortex cooler.
Vortex Cooler
Explaining how does a vortex cooler works is a bit difficult, still in an easy language a vortex cooler can be compared to a heat exchanger. Compressed air is given as an input to the vortex cooler from one side. From one end hot air comes out and from the opposite end cold air comes out.
The compressed air travels to the hot end side in the form of vortices having very high RPM where an adjustable valve is present. Some air goes out from there and other comes back from inside of these vortices and travel to the opposite side i.e. cold side. Here this air becomes cold by exchanging energy. The below figure shows a vortex cooler.
vortex cooler
Image Courtesy: Exair
The benefits of vortex cooler are:
  1. The vortex cooler has no moving parts
  2. Only compressed air with normal temperature (20 degrees Celsius to 30 degrees Celsius) is needed
  3. No power supply is needed
  4. Maintenance free design
Conclusion
A few important things we learned from this case are:
  1. If there are any barriers or cards, then air conditioning is needed
  2. Regular LLF of every instrument item is needed whether it is a transmitter or gauge or cable or panel
  3. Regular thermography of components installed in panels should be done
  4. Regular cleaning of components installed in panels should be done
  • Process Air Compressor Overhauls
  • Refrigeration Compressor Turbine
  • Erratic Stroking of Control Valves
  • Temperature Sensors Fault Problem
  • Junction Box Corrosion Problem
Cooling Tower Fans Frequently Failing
Premature Arc Fault Breaker Failures
Miscellaneous Electrical Tasks – Repaired Reformer Tubes Weld Stress Relief
Boiler Feed Water Heater Shell Flange Leaks
Burst Transformer – Electrical Problem Solved
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Root Cause Analysis for Plant Trip Due to Work on Incorrect Tag
CO2 Stripper Old Differential Pressure Transmitter Stopped Working
None Could Repair Slightly Damaged Magnetic Flow Meter Flow Tube
Antifriction bearings (AFB) Problems and Delays Plant Restarts
Rupture Discs bursts caused too many Urea Plant Shutdowns
Erratic Radar Level Gauges
Erratic Radar Level Gauges Delays a Refinery Commissioning
HT motors Corrosion Problem
Steam Letdown Station Problems
Steam Letdown Station Problems and their Solutions
Bently Nevada Proximity Probe
Root Cause Analysis for Vibration Probe Not Responding
Thermocouple Extension Lead Minimizer Circuit
Thermocouple Wires and Extension Lead Issues
Less than 40% available Plant Air Compressors made available 100%
Less than 40% available Plant Air Compressors made available 100% for Operations
Compressor IP Case Discharge Temperature Gradually Increases
Compressor Anti-Surge Control near-miss incident
NH3 Plant Turbo-compressor Sudden Rise in Temperature
Conductivity Analyzer Principle
Conductivity Analyzers Interview Questions & Answers
Relay Parts
Difference Between NO and NC Contacts
Zener Diode Limiter Working
Zener Diode Limiter
How Does a Touch Sensor Work
How Does a Touch Sensor Work?
Demystifying Reynolds Number
Why Viscosity is Not Included in the Orifice Equation?
Four Wire RTD Principle
How a 4 Wire RTD Works ?
Top 100 Zigbee Projects for Engineering Students
Diaphragm valves
Basics of Valves
