Reading: Automated Block Valve (ABV)
Inst Tools > Blog > Control Valves > Automated Block Valve (ABV)
In this article, you will learn the automated block valve (ABV), butterfly & ball valves, and valve data required for sizing in SIS systems.
Last updated: May 18, 2022 8:49 am
Control Valves Safety Instrumented System (SIS)
6 Min Read
Final control elements used in Safety Instrumented System (SIS) application shall be carefully engineered to meet the stringent requirements. As these valves are operated based on the safety requirements per LOPA, they’re termed as Automated Block Valve (ABV).
Automated Block ValveBall ValveButterfly ValveSIS Valve (ABV) Application CharacteristicsApplication Specific RequirementsPneumatic on/off Valve Actuator SizingValve Data Required for Actuator SizingActuator Data Required to do the Valve SizingSolenoid ValveTypes of Solenoid ValvesSwitch boxSwitch typesConclusion
Usually, these valves play a critical role in isolating the process from any hazardous events, hence the valves need to meet the SIS design requirements and satisfy the testing needs.
The basic characteristics of Automated Block Valves (ABV) are as follows
  1. Automated Block valves are of Quarter-turn type on/off valve assemblies with pneumatic actuation
  2. Valve designs are Ball / Butterfly valves / Plug valves in some cases.
  3. Quarter-turn Valve Styles – Metal seat, Soft seat, Full bore, Reduced bore & Cavity Relief
  4. Valve Leakage Rate: the valves seat leakage is a critical parameter and it has to meet the design requirement by API-598 or IEC 60534-4 Class V, VI for metal seated ball valves
  5. Actuators are of Rack & Pinion or Scotch Yoke type.
Ball Valve
A ball valve is a type of quarter-turn valve which uses a hollow and pivoting ball to control flow through it.
The valve turns full open when the ball’s hollow portion is parallel to the pipeline with the flow and the valve turns closed when the ball’s hollow portion is perpendicular to the pipeline (which is a 90-degrees turn).
The valve can be operated automatically with a pneumatic/electric actuator or manually by the valve handle.
Ball valve with pneumatic actuation
A typical picture of Quarter-turn Ball valve assemblies with pneumatic actuation is shown above.
Butterfly Valve
The butterfly valve has a disc and shaft arrangement, with the rotation of the valve disc controlling the fluid flow. In the closed position, the disc seats along the pipe bore, thus blocking the flow through the valve. Whereas in the open position, the disc is oriented perpendicular to the flow direction to allow flow.
There are 3 types viz.
  1. Zero offset,
  2. Double offset &
  3. Triple offset butterfly valve.
Typical schematic of Butterfly valve
SIS Valves‘ performance is based on the below factors:
  • Fluid Medium
  • Process Data parameters
  • Design Conditions
  • Fluid Properties
  • Flow Direction
  • Pressure / Temperature rating (Pipe Specification – pressure class, rating)
The below parameters decide the type of valve to be chosen in SIS applications.
  • Cycle Frequency
  • Open/Closing Time (travel time)
  • Water hammering
  • SIL classification (SIL 1/2/3)
  • Fail Action
  • Fire Safe/Fire Retardant
  • Fugitive Emission Requirements
  • Tightness Class requirement
SIS Valve (ABV) selection is based on the Application characteristic and Specific requirements for the respective applications.
Actuator sizing is very vital for the safe and fast response of SIS valves.
  • Required valve torque values
  • Available actuator output torque
  • Available air supply pressure
Actuator output torque > Required valve torque
Actuator output torque < Max allowable stem torque
Below parameters are required to be provided by the Valve manufacturer to the Actuator manufacturer for designing a suitable actuator for a particular valve.
  • Valve torque
  • Net break out the torque for the available shut off pressure
  • Torque factors: Running torque; Break away from open torque: Reseating torque
  • Torque correction factors: Application characteristics like particles, application process temperature
  • Frequency of operations etc
  • Maximum Allowable Stem Torque (MAST)
  • Travel time requirements
The below parameters are required to be provided by the Actuator manufacturer to the Valve manufacturer for designing a suitable actuator for a particular valve.
  • Air supply pressure related: Air start torque; Air end torque’ Air running torque
  • Spring related: Spring supply pressure related: Spring start torque; Spring end torque; Spring running torque
  • Adjustment factors for high/low-temperature executions
  • Intermediate travel stop (if any) – Break to close torque
Solenoid Valve
Type of solenoid valve in SIS valve application also plays a vital role Default:
Namur type solenoid – Breather function: keeps spring chamber actuator clean
Pipe mounted solenoid – re-breather block
3/2-way for single acting
5/2-way for double acting
Direct Operated valves require Higher power consumption (>7 Watt), Bigger Cv-values (> ~5.0), and hence more reliable.
Pilot Operated valves have Lower power consumption (< 2 Watt), Smaller Cv values (< ~5.0), and current consumption is also very less, More vulnerable to non-clean air supply filters in air supply.
Solenoid valve coil assembly (ref figure)
Switch box
The type of switch/ switch box shall be according to the actuator style to have better assembling and ease of maintenance.
Switch types
Proximity type switch (non-contact switch)
Reed Switch: switch activated by an external magnetic field
Inductive Switch: detect magnetic loss due to eddy currents that are generated on a conductive surface by an external magnetic field.
Of all the above types Non-contact type proximity type switch is most preferred for SIS applications.
Mechanical types of switches shall never be used in SIS.
Conclusion
We must understand the type of valve, actuator, solenoid valve, switch, and accessories such as Air Filter/Regulator, Booster relays to be selected with a thorough understanding of the process fluid/gas application and valve response, leakage requirement.
Common Cause Failure – Safety Instrumented System
Control Valve Performance with Constant Pressure
Choked Flow of Control Valves
Safety Instrumented System Probability
Difference between Globe Valve and Gate Valve ?
Control Valves Multiple Choice Questions
What is Control Valve Flashing ?
Pneumatic Piping Design and Specification
Basics of Gate Valves
What is Maintenance Override Switch (MOS) ?
What is a 3-way Solenoid Valve ?
Solenoid Valve Problems and Solutions
Difference between SIS, PLC and BPCS Systems
Functional Testing of Control Valve Positioners
Gate Valve Parts
What is Gate Valve ?
Bathtub curve
Bathtub Curve
Valve Basics
Basics of Control Valves
Gate Valve
How Gate Valves Work ?
Types of Control Valve Trim
Butterfly Valve
Butterfly Valves Construction, Types, Stem & Bonnet Assembly
Direct & reverse actions control valve
Direct Acting Control Valves & Reverse Acting Control Valves
IR Instrumentation Questions & Answers
How to Find the Correct Solenoid Valve Size
How to Find the Correct Solenoid Valve Size?
Difference between Force and Power
Allen-Bradley VFD
Why V/f Ratio is kept Constant in VFD?
Biosensors Questions & Answers
Motor Controls
Design and Implement Motor Control – Electrical Engineering
Static VI Characteristics of Thyristor
Thyristors – Working, VI Characteristics, Turn ON Methods
Relief Valve
Pressure Relief Valve Principle
