  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Sequential PLC Programming for the Pneumatic Valves
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > Sequential PLC Programming for the Pneumatic Valves
Write a ladder logic for sequential PLC programming for the pneumatic valves to operate cylinders in sequential mode.
Last updated: May 23, 2023 2:17 pm
2 Min Read
This is a PLC program for pneumatic valve operation in sequence mode.
Sequential PLC Programming for the Pneumatic ValvesList of inputs/outputsLadder Diagram for the Sequential Operation of Cylinders
Pneumatic valve operation in sequence mode
Solution:
Here in this system, there are two cylinders and two push buttons that are connected to the PLC.
 The push buttons are connected to the PLC inputs and the cylinders are connected to the Outputs of the PLC.
There are the following condition for the system to work which are as follows: –
When START PB is pushed, cylinder A should start, and Cylinder B should start after 5 seconds of Cylinder A.
When STOP PB is pushed, both cylinders A & B are to be stopped.
Now to meet the following conditions, we must use a timer which delays the operation of cylinder B.
Inputs:
  1.  X1 -START PB
  2.  X2 -STOP PB
Outputs:
  1.  Y0 -Cylinder A
  2.  Y1 -Cylinder B
Program Explanation:
In rung 1, we used STRAT PB (X1) to start Cylinder A (Y0). Here we used NC contact of STOP PB (X2) to stop cylinder A (Y0). In parallel with X1 contact, we used NO contact of Y0 to latch the output.
In rung 2, we used Timer T0 to count the delay for cylinder B (Y1).
In rung 3, we used NO contact of T0 so once time delay over the Cylinder B (Y1) will ON.
  • PLC Restrict Data Interfaces
  • Use PLC Flags as Integrity Checks
  • Offline and Online UPS Systems
  • Diagnostic Buffer for SIEMENS PLC
  • S7-1200 Hardware Configuration
Rockwell PLCs for Large Scale Applications
PLC Timer Programming Examples – TON, TOF, TP and TONR
Power Supply Sizing for Industrial Automation Systems
Types of Industrial Control Systems
208kSubscribersSubscribe
Recent Comments
Related Articles
What is meant by the Batching Process
Batch Simulator PLC Example Program using LogixPro Simulator
Difference Between Wifi and Industrial Wireless
PLC Programming Example with Pushbutton and Motor
Transistor Output Wiring
PLC Output Types
Best PLC for Your Project
Finding the Best PLC for Your Project – Tips and Tricks
Contextual HMI
What is Contextual HMI? – HMI Screens on a Mobile or Tablet
Actuator Sensor Interface (ASi) Protocol in PLC
Types of Limit Switches
Types of Limit Switches – Principle, Advantages, Disadvantages
More Articles
Industrial Instrumentation Questions & Answers
P&ID arrangement for Pressure Safety Valves
P&ID Guidelines for Pressure Safety Valves
Ladder Logic Questions and Answers
Infrared Hydrocarbon Gas Detector Calibration Procedure
AI AO DI DO Signals
What are AI, AO, DI, and DO? – Definition, Examples, Purpose
Falling Ball Viscometer Principle
Four Wire RTD Circuit
What is a Four-wire RTD ?
Relay Motor Logic Circuit
Motor Control Circuits
