Reading: Paddle Wheel Flow Meters – Principle, Advantages, Limitations
Inst Tools > Blog > Flow Measurement > Paddle Wheel Flow Meters – Principle, Advantages, Limitations
The principle of Paddle Wheel Flow Meters consists of a freely rotating wheel with embedded magnets which is perpendicular to the flow rate.
Last updated: October 31, 2023 11:02 am
Flow Measurement How It Works
3 Min Read
Paddle wheel flow meters consist of three primary components: the paddle wheel sensor, the pipe fitting, and the display/controller.
Paddle Wheel Flow MetersAdvantages of Paddle Wheel Flow MeterLimitations of Paddle Wheel Flow Meter
The paddle wheel sensor consists of a freely rotating wheel or impeller with embedded magnets that is perpendicular to the flow and will rotate when inserted in the flowing medium.
Working Principle of Paddle Wheel Flow Meters
As the magnets in the blades spin past the sensor, the paddle wheel meter generates a frequency and voltage signal which is proportional to the flow rate. The faster the flow the higher the frequency and the voltage output.
The paddle wheel meter is designed to be inserted into a pipe fitting, either ‘in-line’ or insertion style. These are available with a wide range of fittings styles, connection methods, and materials such as PVDF, polypropylene, and stainless steel. Similar to turbine meters, the paddle wheel meter requires a minimum run of straight pipe before and after the sensor.
Flow displays and controllers are used to receive the signal from the paddle wheel meter and convert it into actual flow rate or total flow values. The processed signal can be used to control the process, generate an alarm, send signals to external, etc.
Paddle wheel flow meters (also known as Pelton wheel sensors) offer a relatively low-cost, high-accuracy option for many flow system applications, typically with water or water-like fluids.
  • Low-cost solution with high flow system accuracy
  • Easy to install and operate, resulting in a low cost of ownership
  • No pressure drop making it ideal for gravity flows
  • Insertion flow meter design lowers installation and maintenance costs
  • Paddlewheel meters work best with clean fluids as particulates can prevent the paddle from spinning properly
  • Not suitable for gases
  • Requires a turbulent flow profile (consistent fluid velocity across the pipe diameter) for accuracy
  • Requires a straight run of pipe before and after the flow meter to allow swirl patterns in the flow stream to dissipate
  • Paddlewheel meters may not function properly with high-viscosity fluids where the flow profile is laminar
  • The pipe must be full; any air in the line may lead to inaccuracies
Typical applications for paddle wheel flow meters include the accurate measurement of preset fluid volumes in dispensing systems, control of chemical metering pump output, flow verification, irrigation systems, and alerting users to flow rate increases or decreases outside a programmed range.
  • Turbine Flow Meter Verification
  • Flow Meter Installation Guide
  • Optical flow meter Principle
  • What is an Ultrasonic Flow Meter?
  • Piston Flow Meters Working
What Factors Affect the Stability of Flow Meter Readings?
Oscillating Piston Flow Meters Working Principle
Turbine Flow Meters Animation
Types of Vortex Flow Meter Sensors
Thermal Dispersion Flow Switch Working Principle
  • AYON BHOWMIK says:
    May 30, 2016 at 5:10 pm
    Sir, what is the difference between paddle wheel flow meter and turbine flow meter ? thanks
Gas chromatograph Working Animation
Venturi Flow Meter – Working Principle, Advantages, Animation
Gas and Liquid Measurement: Processes and Solutions for the Industrial Sector
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Short Notes on Differential Pressure Flow Meters
Pressure Temperature Compensation Flow Measurement
How does an Orifice Measures Flow?
Orifice Plate Turndown ratio
Flare KOD
Flare Knockout Drums Working Animation
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Magnetic Float Level Switch Working Animation
multi-variable transmitter
Mass Flow Meters
Turbine Flow Meter
All About Turbine Meters
Coriolis Mass Flow Meter Working Animation
Coriolis Meter Explained with Animation
Anti Surge Controller Theory
Anti Surge Controller Working Principle
Sealed Bellows Temperature Sensors
Bellows Pressure Sensors Working Principle Animation
Thermocouple Extension Lead Problem
Residual Current Circuit Breaker (RCCB)
OTDR testing
OTDR Testing
Full Wave Rectifiers Objective Questions and Answers
Under and Over-Capacity Control Valve
Under and Over-Capacity Control Valve Pose Poor Controllability
Solar Pump
What is a Solar Pump VFD? – Advantages, Principle
PLC Program for Washing Machine
