Reading: Why is 24 Volts Commonly used in PLC Systems?
Inst Tools > Blog > PLC Tutorials > Why is 24 Volts Commonly used in PLC Systems?
Explore why 24 Volts is commonly used in PLC systems and discover its safety advantages for electrical wiring.
Last updated: March 15, 2025 9:56 pm
6 Min Read
In PLC systems, when you work on electrical wiring, you need to take special care of the voltages involved. The voltage is classified into two types of use – power and control. But be it any type, you will find that DC voltage is more preferable and used in PLC systems, than AC voltage. There are many reasons for this support.
Why is 24 Volts Commonly Used?Safety:High switching rate of semiconductors:Reduced noise interference:No need for additional safety equipment:SMPS can take any type of AC voltage as input:Smaller electronic boards:Reduced thermal consumption:Voltage stability:
In this post, we will see why the PLC makes use of 24V often.
Safety:
The very first reason for using 24V DC is the safety of the control circuit. Yes, you may argue that if this is the case, then we should stop using 230V AC for PLC systems. But, this is not the point. You can use 230V AC as it provides more flexibility for current consumption, but what heavy devices does a PLC actually work with? It is connected to instruments, sensors, relays, and other small current consumption devices, which itself use 24V DC. Just for PLC purposes, if you use 230V AC, then an engineer can by mistake connect this potential to an instrument, which will damage it. If the whole control circuit is thus consumed by 24V DC, then the safety of the PLC system is ensured in a great way.
Semiconductors used in electronic items often function at high switching rates. They use low DC voltage for this purpose. You may have seen in relays, if AC voltage is used and if it is switched frequently, then sparks are created due to chattering and may damage them. So, as PLC is an electronic item and comprises semiconductors inside, using 24V DC ensures a reliable operation. That does not mean you cannot use AC voltage; it entirely depends on the design of the circuit. But designers too mostly prefer DC voltage over AC voltage.
At lower DC voltages, there is a very low chance of electromagnetic noise interfering with actual control signals and disturbing the output. If AC voltage was used, then harmonics and noise play a greater role in signal interference, which indirectly affects the efficiency of a PLC system. This is also the reason why instruments prefer 24V DC voltage for their power supply and control signals.
When you work on high AC voltages, you have to sometimes wear protective gear like helmets, gloves and other related items. All this is not required when you are working on DC voltages. It is very low voltage and you do not get any electric shock if touched by mistake. So, all this additional equipment and gears are eliminated automatically when working with DC voltages.
This is a very important factor for using 24V DC voltages. AC voltage input can vary by some factors, depending on the region where electricity is used. A standard PLC or instrument manufacturer will not make products based on different AC voltages. So, a simple solution for him will be to use 24V DC as supply, because an SMPS can convert a wide range of AC voltages into a standard 24V DC voltage.
Circuits employing lower DC voltages consume a low space area for assembly, as compared to 230V AC devices which consume a higher space area for assembly. Lower space consumption automatically increases simplicity, and reduces cost and transport costs. This directly impacts your finances and business.
When you work at high AC voltages, you will see that devices will heat up more quickly, give a larger heat dissipation and will eventually require more cooling. This is not the case with DC voltages, as they consume less thermal energy with reduced heat dissipation. This will automatically reduce your cooling demands and save energy. Also, frequent heating of a product can reduce the lifespan of PLC. As PLC is used in critical environments, these types of issues create a headache for the engineer.
Voltage stability:
DC voltages are constant and stable in nature, as compared to AC voltages which vary more frequently with a large span sometimes. And as sensitive electronic circuits require a stable voltage for operation, 24V DC is more preferred due to this reason.
In this way, we saw why the PLC makes use of 24V DC often.
  • PLC Program for Measuring Event Duration
  • Conveyor Speed Logic using the PLC Program
  • PLC Tank Liquid Heating Control by Steam Flow
  • Wet Contacts and Dry Contacts in PLC Systems
  • PLC Functional Blocks for Tanks Drain Control
Siemens PLC Tia Portal – OB100 Start-up Organization Block
Mail Box Automation: Programming with Schneider PLC
PLC Program for Ceramic Burning Oven Conveyor System
Sequential Operation of Output Bits using Two Push buttons
Relay circuits
PLC Program to Count Running Hours of any Equipment
PLC Multiple Choice Questions
Allen Bradley PLC ControlLogix Hardware
What is the DDE Protocol?
PLC Program for Automatic Heating and Mixing of Products
Heating and Mixing of Products using PLC Example Tutorial
21 CFR in SCADA and HMI Systems
What is 21 CFR in SCADA and HMI Systems?
Data Types in PLC
Data Types in PLC – Bit, Byte, Integer, Real, String
Analog Input Card Resolution Effects on Accuracy
PLC Analog Input Card Resolution Effects on Accuracy
Studio 5000 Logix Emulate Controller
How to Create New Project in Studio 5000?
Example of PLC Programming based on Logic Circuit
Interlock
Process Interlocks and Trips
PLC Ladder Logic for Demultiplexer
1 to 8 Demultiplexer PLC ladder diagram
Direct digital control principle
Direct Digital Control (DDC) Systems
Calculate Temperature of RTD
Automatic Motor Forward and Reverse Control using Timer
Open Loop Control Block Diagram
Three Wire RTD Wheatstone bridge Circuit
RTD Wheatstone Bridge Circuits
Difference Between Contactor and Relay
CNC Machining Deep Hole Drilling
Deep Hole Drilling Ideal Methods For CNC Machining
