Reading: What is Integral Flow Orifice Assembly?
Inst Tools > Blog > Flow Measurement > What is Integral Flow Orifice Assembly?
Integral Flow Orifice Assembly is used when a Differential Pressure Transmitter has to be directly mounted on the orifice assembly.
Last updated: November 2, 2023 12:36 pm
Flow Measurement
2 Comments
3 Min Read
Integral Flow Orifice AssemblyAdvantages of Integral Meter run assembly:Types of Meter Runs
This eliminates the cost of installation of a Differential Pressure Transmitter with impulse piping up to the orifice assembly.
Integral Orifice Assembly
The transmitter is mounted on the orifice assembly through a 3/5 Valve H-type manifold. Available with line sizes of 2″ & below. However, due to the process temperature limits of the transmitter, this assembly cannot be used to process temperatures above 120 degrees Centigrade.
The assembly consists of an orifice plate between two integral blocks having corner taps. Generally, a meter run pipe is recommended with an upstream length of 750mm and a downstream length of 250mm. The pipes are welded to the blocks with end flanges.
The use of an integral orifice flow meter will eliminate the three measurement inaccuracies recorded in small orifice line installations.
The Integral orifice-honed body reduces ID uncertainty.
By inserting precision bored upstream and downstream sections of pipe, the velocity profile distortion due to pipe roughness is reduced.
The self-centering design of the Integral Orifice Plate eliminates plate misalignment.
Improves Reliability and Maintenance Costs
The integral orifice flow meter eliminates impulse lines, reducing leak points by over 50% and decreasing start-up time due to the flexibility of numerous process connection options.
The direct mount design minimizes line plugging by eliminating long lines, small-bore ports, and services while providing consistently reliable installations.
  • Accuracy up to ±0.5% of the volumetric flow rate.
  • The integral manifold head allows direct mounting of DP transmitters.
  • Ideal fluid types: liquid, gas, and steam
Integral Orifice Assembly with flange union, manifold valve, DP transmitter & end flanges
Integral Orifice Parts
Meter runs are supplied as a complete unit of normally 1M length to ensure the necessary straight pipe length to achieve the highest possible efficiency.
These are available with line sizes mostly below 50mm with a corner tap.
These are used for the measurement of small flow rates precisely where high accuracy of flow rates is required.
Types of Meter Runs
  1. Orifice Flange union with Meter -run.
  2. Orifice flange union with Carrier ring and meter run.
End Connection: Socket Weld, Screwed and Flanged ends with meter run piping suitable to ANSI, IS & DIN flanges.
Reference – prisma-instruments
  • Advantages of Flow Meter
  • Magnetic Flow Meter Corrosion
  • What is an Orifice Flange?
  • Displacement Flowmeters
  • What is a Dall Tube Flowmeter?
Hot Wire Anemometer Principle and Types
Working Principle of Vortex Flow Meter
Is it Easy to Measure Natural Gas Flow and Volume?
Orifice Plate Questions and Answers
Coriolis Meter Explained with Animation
2 Comments
  • M.Umer Irshad says:
    April 22, 2022 at 5:34 pm
    Can compact type integral orifice with Transmitter installed with isolation valves bw TX n sensing integral lines??
  • Mi says:
    July 11, 2023 at 2:00 pm
    Your site, your articles are very helpful. Thank you for your understandable description.
What is a Segmental Wedge Flow Meter?
Different Flow Measurement Technologies
DP type Flow Transmitter Preventive Maintenance and Calibration
Interferometer Principle
What are the Orifice Plate Flow Requirements?
Troubleshooting DP type Transmitter Common Problems
In-Line Flow Switch Working Principle and Animation
Important Factors in Flow Measurement
What is a Condensate Pot? How to Install it?
Magnetic Flow Meter Corrosion Effects
W Type Transit Time Flow Meter
Transit Time Flow Meter – Types, Advantages, Disadvantages
Vortex Flow Meter Animation
Orifice Plate Sizing
Orifice Sizing Guidelines and Thumb Rules with Flowchart
What is a Ultrasonic flow meter
What is a Ultrasonic Flow Meter?
Venturi Flow Meter Theory
Basics of Venturi Flow Meter
Paddle Wheel Flow Meter
Paddle Wheel Flow Meters – Principle, Advantages, Limitations
Electrical bonding jumpers
Proper Sizing of Conductors
Three Phase Induction Motor Power Factor Control
Difference between Servo Motor and DC Motor
Simulation in Machine Expert HVAC
How to do Simulation in Schneider PLC?
Compression load cell Principle
Types of Load Cells
Benefits of IoT in the Manufacturing Industry
advantages-of-suspension-insulators-and-pin-type-insulators
Advantages of Suspension Insulators and Pin type Insulators
Single-beam non-dispersive analyzer
Single-beam Non-dispersive Analyzer
