Reading: What is an Automated Guided Vehicle?
Inst Tools > Blog > Common > What is an Automated Guided Vehicle?
Automated guided vehicle drives itself in a predefined path without the need of a driver or any operator.
Last updated: September 28, 2022 4:13 pm
Common
In this post, we will see the concept of the automated guided vehicles.
Automated guided vehicles come under the group of robotics and artificial intelligence. Automated guided vehicle drives itself in a predefined path without the need of a driver or any operator.
It is a combination of smart software programming and sensor-guided interfaces, which enables it to move automatically.
Since a normal vehicle has a driver to drive it, these vehicles have precise acceleration and deceleration parameters defined inside it; which provides the same control that a driver would do.
These types of vehicles are used on a large scale in the manufacturing industry, which helps in the transportation of goods and reduces the use of manpower with accurate movements.
AGV’s are powered by batteries. Various guidance technologies like magnetic tapes/bars, lasers, optical sensors, etc. help in navigating it properly.
So, you can correlate this with a normal driver. If he sees an obstacle, he will automatically guide the vehicle away from it. In the same way, these devices are programmed to move in a predefined path.
The sensors will monitor its movement. Whenever it senses an obstacle, it will trigger an internal program to move the vehicle away from it.
Or simply, forget the obstacle. If that vehicle is driving in a U-turn-shaped road; after moving straight, when it senses the turn by reading its path, the vehicle will automatically turn itself along with the road and move in correspondence with it.
AGV’s are typically connected in a wireless manner to a remote operation center to monitor its movement continuously. This real-time location tracing helps them to properly design the route of the vehicle in its program accordingly.
Also, due to remote control access, driving instructions for starting, stopping, changing gear, changing the path, etc. becomes easier.
AGV’s are of great use in the automation sector. Due to the absence of humans, the high efficiency of driving with less number of errors is achieved.
Also, replacing humans with a vehicle will reduce the cost to the company, as it is a one-time investment.
Due to the use of a large number of guidance sensors in it, the safety of the transport is assured in a great way and thus, the materials in it are carried safely to its destination.
Also, AGV’s can operate in areas where human presence is not possible, citing examples like a hazardous environment.
If a task changes, you just have to reprogram the vehicle or make necessary changes in its design. Though it will take great human efforts to design it, once developed, it can run without any interference and function smoothly.
Typically, AGV’s are used in sectors like food and beverage, chemicals, automotive, manufacturing, paper industry, plastics, warehousing, pharmaceuticals, etc.
You also to properly design the path for the movement of AGV’s. Because, as defined earlier, they move on predefined paths. Any wrong design in the path can cause mishaps or damage to the environment.
  • SCADA System with OPC UA
  • PLC Digital Output Types
  • Actuator Sensor Interface
  • PLC Communication Protocols
  • PLC to PLC Communication
Instrumentation documents
Difference between Force and Power
Introduction to Embedded Systems – Features, Types, Applications
Conveyor : Belt, Screw, Pneumatic, Hydraulic, Roller, Chain, Bucket, Vibratory
Job and Career Opportunities in Instrumentation Engineering
Questions on Chemical Reactor Vessel P & ID
Condensate Automation in the Sugar Industry
Software Testing Projects – How to Approach the Process Effectively?
D.C Tachogenerator Principle
Pilot Valves and Pneumatic Amplifying Relays
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
Modern Engineering Solutions for Rotary Equipment
HVAC Valves
Ultrasonic Thickness Gauge
How to Use a Paint Thickness Gauge?
Meters used in Troubleshooting Electrical Equipment
Electrical Motor Failures
Most General Reasons for the Electrical Motor Failures
Difference Between Resistive Touch and Capacitive Touch
pneumatic circuit with sensors
Electro-Pneumatic Circuit Using Pressure Sensor and Timer Relay
Difference Between Microcontroller and Microprocessor
What can you do with an Engineering Degree
What Can You Do with an Engineering Degree?
Range Finders
Range Finders – Ultrasonic, Light, & Global Positioning Systems
RTD Connection Diagram
Difference Between 2 wire RTD, 3 wire RTD, and 4 wire RTD’s
Thyristor Family Quiz
4-20mA Current Loop Components
Why Use a Current Loop?
What is Profinet and How to Configure in Siemens PLC
What is Profinet and How to Configure in Siemens PLC?
EPC Questions and Answers
Measurement of Resistance Objective Questions
Electrical Engineers Basics
Basic Electrical Engineering Questions & Answers
Electronic Devices & Circuits Quiz – Set 15
