Reading: What is a Line Choke or Reactor in a VFD?
Inst Tools > Blog > Electrical Basics > What is a Line Choke or Reactor in a VFD?
Line choke is an inductance connected to the VFD input or output circuit to protect the VFD from unwanted spikes, transients, and harmonics.
Last updated: September 28, 2022 4:09 pm
Electrical Basics PLC Tutorials
2 Comments
In this post, we will see the concept of a line choke or reactor.
Line Choke in a VFDLine ChokeLoad Reactor
Line choke is an inductance connected to the VFD input or output circuit. It is a component that forms a magnetic field as current flows through it and when the current increases, it limits the increment in current by producing a voltage or emf across it that opposes it.
This protects the VFD from unwanted spikes, transients, and harmonics. The reactor is used on either the input side or output side of the VFD.
When a reactor is used on the input side, it is called a line reactor and when it is used on the output side, it is called a load reactor.
Line Choke in a VFD
Refer to the above image. The inductance is shown on the input side and the output side is nothing but the line choke. It is normally used for VFD’s which have a rating of more than 1 KVA. Let us understand its basic working.
It is not always necessary that a current wave be sinusoidal. When it is not sinusoidal, it contains harmonics. Harmonics are a large current distortion.
If you see the basic equation of an inductor, it is – V = L (di/dt)
Here, V is the voltage, L is the inductance of the choke or reactor, and (di/dt) is the rate of change of current.
As the current change rate increases, the voltage too increases in proportional to the inductance.
But, this induced voltage has the opposite polarity to that of the applied voltage. This automatically reduces the rate of current change and limits the current applied.
Line Choke
One more theory can be understood here for the output side of VFD. As a high switching frequency is produced at the output of VFD, sharp changes in voltage outputs are reflected sometimes.
This high spikes in voltage can damage the motor circuit or even heat the VFD itself. This can be reduced by using a line choke.
The line choke reduces the peak of the voltage waveform and increases the changing rise time of the signal; to stabilize the final output waveform.
The stabilized waveform will indirectly provide limited current and voltage output to the motor.
Load Reactor
A load reactor is used when the distance between the motor and VFD is very large; mostly 100 feet or more.
Due to long-distance, voltage spikes are amplified more and this can affect the circuit in a large way. So, the line choke will limit this current to a safe limit.
This inductance plays a very important role in protecting the thyristors of the VFD from damage or overheating. Mostly, this device is used when several drives are connected in parallel closely; or the line power supply is imbalanced or largely variable, etc.
In this way, we understood the basic concept of the line choke.
  • What is a Link Box?
  • Static UPS and Rotary UPS
  • Commissioning of VFD Drive
  • DOL Starter Working Principle
  • Motor Forward Reverse Control
Siemens TIA Portal Project: Liquid Temperature Control System
PLC Level Control of Two Tanks
Effects of Long Distance Cables between VFD and Motor
PLC Program Examples
What is Electrical Busbar? Types, Advantages, Disadvantages
Set the S5 Timer Value by a Memory Word
2 Comments
  • b says:
    July 12, 2023 at 2:13 pm
    in practical oprational case some tims there is harmonices.how we reduce such conditions?the other critical thinkg here on the choking line in what mechanism?auto?
    manually?penumatic? the technology limitation also limtted ,how you can imprve such manner/
    thanks alot.
  • Bhanu says:
    August 5, 2023 at 11:18 am
    Thanks for this article,
    I want to design line chokes.
    Can you help me.
Why Are Charcoal and Salt Added to an Earthing Pit?
Programmable Logic Controller Questions and Answers
Dynamic Braking Resistor in VFD
Why V/f Ratio is kept Constant in VFD?
How to use Master Control Reset (MCR) Instruction in PLC
DCS
What is insulation? How to Choose the Insulation Material?
Instrumentation Earthing
PLC Programming Limit Switch
PLC Program for Password Management using Structured Text
Alarm prioritization
What is Alarm Prioritization? – Types of Alarms
Rotary UPS or Dynamic UPS
Instrumentation During the Detail Design Phase
How to Filter Digital and Analog Inputs in a PLC
How to Filter Digital and Analog Inputs in a PLC?
PLC automation timers and counters
Gas Turbine Troubleshooting Guide
Gas Turbine Troubleshooting Tips
Configure an IP address
What is an IP address? How to Set IP Address of the Computer?
DC Machines Circuit Model Objective Questions
The Hardware Structure of DCS
DCS Applications and Hardware Structure of Plant Automation
PLC Programming Best Practices and Tips
PLC analog output card
PLC Analog I/O and Network I/O
Allen-Bradley SLC 500
History of Programmable Logic Controllers (PLC)
Weir Flow Meter Principle
Measure Flow rate using Level Sensors
