Electrical engineering root cause analysis (RCA) related to welding machines and their poor availabilities and often fail.
| Category: | Electrical |
| Equipment Type: | Welding Machines |
Welding Machine Fail
Motor Generator Welding Sets, (MGWS) and even Rectifier Welding Sets (RWS) of no moving parts fail often in dusty and corrosive areas.
Author Solution
The author got the RWS internals housed in a shop-made below given features tank:
- Radiators akin to transformers fitted oil circulating and heat radiating tubes
- Inside and outside epoxy painted
- Silica gel breather mounted and transformer oil filled
In addition, he ensured well-crimped tinned ‘hole drilled to suit terminal’ copper lugs to the Al welding cables, and well-tightened cable lugs by strict supervision to form a habit.
Gone are terminal burns, charred cable insulation, etc. Consequently, all welding machines were trouble-free forever.
Added ‘snail conveyor belt covers’ as in TEFC motors to MGWS, and strictly ensured their cleaning and return to the workshop immediately after corrosive areas job completions. MGWSs too serve trouble-free forever.
Author: S. Raghava Chari
- Poor Power Factor Problem
- HT Motor Direction of Rotation
- Inability to Test Repaired HT Motors
- General Corrosion of Electrical Motors
- Light Fittings Corrosion Problems
