Reading: What is a Velocity-based Flow Meter?
Inst Tools > Blog > Flow Measurement > What is a Velocity-based Flow Meter?
Velocity-based Flow Meter able to directly measure fluid velocity, therefore capable of inferring volumetric flow rate of fluid in a pipe.
Last updated: November 2, 2023 6:05 am
Flow Measurement
1 Min Read
The Law of Continuity for fluids states that the product of mass density (ρ), cross-sectional pipe area (A) and average velocity (v) must remain constant through any continuous length of pipe:
Velocity-based flow meters
If the density of the fluid is not subject to change as it travels through the pipe (a very good assumption for liquids), we may simplify the Law of Continuity by eliminating the density terms from the equation:
Law of Continuity
The product of cross-sectional pipe area and average fluid velocity is the volumetric flow rate of the fluid through the pipe (Q = Av).
This tells us that fluid velocity will be directly proportional to the volumetric flow rate given a known cross-sectional area and a constant density for the fluid flow stream.
Any device able to directly measure fluid velocity is therefore capable of inferring the volumetric flow rate of fluid in a pipe. This is the basis for velocity-based flow meter designs.
Example Flow Meters
  • Turbine Flow meters
  • Vortex Flow meters
Orifice Plate Questions and Answers
Lobed Impeller Flow Meters Working Principle
Pressure based Flow Meters
Spring Loaded Variable Area Flow Meter Working Principle
Heat Tracing Problems
Wedge Flow Meter Principle
Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
How to do Turbine Flow Meter Verification?
Coriolis Mass Flow Sensor Theory
Measure Flow rate using Level Sensors
Optical Flow Meter Principle
All About Variable Area Flow Meters
Electromagnetic Flow Meters Working Principle
What is Gas Meter and Regulating Station?
Vortex Flow Meters
All About Vortex Flow Meters
Troubleshooting Ultrasonic Flow Meter Common Problems
Orifice Flow Measurement Formula
Basics of Flow Measurement
What is an Orifice Flange ?
What is an Orifice Flange? – Purpose and Applications
Square root extractor Parts
What is a Square Root Extractor? – DP Flow Measurement
positive displacement flow meter pictures
What is a Positive Displacement Flow Meter?
V Cone Flow Meter Working Principle
V Cone Flow Meter – Principle, Advantages, Disadvantages
Coriolis Mass Flow Meter Working Animation
Coriolis Meter Explained with Animation
Field Instruments
Is Vacuum affects Field Instruments in Industries?
Calculate Power in Parallel RCL Circuit
Control Valves Leak Tightness
Control Valves Leak Tightness Restoration Pose Difficulties
Solenoid
Difference between AC and DC Solenoid Valves
Ground Fault Versus Short Circuit
Difference Between Short Circuit and Ground Fault
Career Opportunities in Instrumentation Engineering
Job and Career Opportunities in Instrumentation Engineering
Basic Electronics Questions and Answers
How Buoyant Force instruments Works
