Reading: Various Communication Protocols in PLC
Inst Tools > Blog > PLC Tutorials > Various Communication Protocols in PLC
In this post, we will understand the various communication protocols used in PLC (programmable logic controller).
Last updated: October 17, 2023 2:03 pm
7 Min Read
Communication Protocols in PLCEthernet/IPModbusProfibusOptomuxDF-1InterbusHostLinkData Highway (DH+)Point to Point (PP)Actual Sensor Interface (ASI)Open Smart Grid ProtocolCAN (Controller Area Network) OpenHART (Highway Addressable Remote Transducer)Conclusion
Communication is an important role player in PLC. Apart from traditional hardware IO’s, communication protocols provide more diversity and flexibility to exchange data with various means.
You must be familiar with OSI layers and different types of communication hardware ports used in PLC, to understand the whole cycle of communication in a better way.
We will here see the various communication methods used in a PLC:
Ethernet/IP
It is a protocol that works under Common Industrial Protocol (CIP), which is an open application layer protocol. It is an advanced version of standard Ethernet, which is useful only for in-home and commercial purposes; but not for industrial applications.
It defines all the devices on a network as a series of objects and binds all of them to work on the same standard. This protocol was developed by Rockwell Automation.
Similar protocols with these standards are Profinet, ControlNet, DeviceNet and RAPIEnet. They are different in it’s OSI layers and have their individual functions which differentiate themselves from each other. They have been manufactured by different vendors.
Modbus
Modbus is a protocol that is used for transmitting information over a serial lines or Ethernet, based on master-slave technology.
Here we have two types of devices in this communication. The devices which request information are called Modbus Master and the devices which provide the information are called Modbus Slaves.
It is further categorized into Modbus RTU, Modbus ASCII, and Modbus TCPIP. This protocol was developed by Modicon (now Schneider Electric).
Profibus
It is similar to Modbus RTU, which also works on serial line communication. The only difference is that it is owned by Siemens Automation.
Optomux
It is a serial network protocol that works on RS-232/RS-485 and works on ASCII standard. It was developed by Opto22.
Similar protocols with these standards are Interbus and DirectNet.
DF-1
It is an asynchronous byte-oriented protocol that is used to communicate with only Rockwell devices based on RS-232.
Interbus
It is a serial network protocol which works on RS-232/RS-485 and works on RTU standard.
It was developed by Phoenix Contact.
HostLink
It is a serial network protocol that works on RS-232/RS-485 and works on RTU standard.
It works only on Omron PLCs. It was developed by Omron.
Data Highway (DH+)
It is a protocol developed by Rockwell Automation and uses transformer-coupled differential signals; meaning that the transmitter and receiver stations need not be at the same ground potential.
It works with the differential signaling concept. It uses two wires for data transfer and the data is represented with voltage differences in the two wires. Here the data is carried with differential voltages, the noise will be easily removed in the two wires.
It uses half-duplex transmission for communication. It is a very old protocol and is used only in Rockwell PLCs. Nowadays, it has become obsolete and rarely used.
It works on token-passing protocol and uses trunk lines with drops.
Point to Point (PP)
As the name suggests, it is a communication protocol which is used to communicate between only two connected devices.
It is byte-oriented and is full duplex.
It is a protocol that is used to connect all the sensors and actuators in a field with a single two-conductor cable.
It reduces the wiring and manpower done to connect the field equipment to the PLC. It works in master-slave technology.
This protocol has been developed to connect all the electrical devices in a power grid through communication and make it a smart grid system.
The devices are meters, direct load control modules, solar panels, gateways, and other smart grid devices.
Due to use of communication, all the information is transmitted in a safe and efficient way; to make the whole power grid system a better way to operate.
This protocol is an application layer protocol that communicates with various devices using peer messaging. It is a multi-master slave communication system and has an object dictionary that contains all the functions of a device.
This is an actual communication mean and has standard communication objects for real-time data (PDO’s), configuration data (SDO’s), timestamp, sync message, emergency message, boot-up message, NMT message, and error control message, and other data.
In a hardware configuration, one point to remember is that it requires termination at the end device to establish the whole link communication.
HART is a protocol in which digital data is superimposed on the traditional analog signal of 4-20 mA; so that the user gets both the analog information as well as digital information.
HART-enabled field transmitters and actuators are of great use in industrial automation; as the user gets all the information and calibration settings sitting at one corner in the office.
Conclusion
These are the general communication protocols used in PLC. Apart from these, many more are available depending on different manufacturers.
Did we miss any communication protocol? Share with us through below comments section.
  • Compare Modbus, Fieldbus, and Profibus
  • Modbus Communication Interview Questions
  • Why is the PLC Going in Stop Mode?
  • Foundation Fieldbus Installation Practices
  • Industrial Automation Protocols
Motor Speed Control using VFD and PLC Programming
What is the Firmware Version of a PLC? – Siemens PLC Hardware
Tank Filling and Emptying using Intouch Scada Script
  • sreekanth says:
    August 8, 2022 at 7:08 pm
    ASi- Actuator Sensor Interface not Actual sensor interface
Upload Option Disabled in Siemens PLC
Electrical Earthing Calculations
PLC Program for Positive Edge Pulse Output for One Scan Cycle
What is Multi-touch Technology? – Industrial Automation
PLC Example on Manufacturing Line Assembly
PLC Examples for calling functions in SCL
Types of Switches
Electrical Switches Principle & Types
PLC Ladder Logic Example based on Set Coil and Reset Coil
Light Tower in Industrial Automation
What is meant by a SCADA System
Troubleshoot the Status of a PLC Via CPU Indicators
PLC XOR LOGIC with Ladder Diagram
PLC Logic Functions
Communicating Delta PLC Software to Simulator
PLC Fault Diagnosis - PLC Training Documents
PLC Fault Diagnosis – PLC Training Documents
PLC Memory Mapping
PLC Memory Mapping and I/O addressing
Solar Pump
What is a Solar Pump VFD? – Advantages, Principle
Electricity Generated From Wind Energy
How is Electricity Generated From Wind Energy?
Integral controller eliminates offset error
How Integral Controller Reduces offset error ?
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
LogixPro Simulator Software
Questions on Resistive Tape Level Sensor
Random Access Memory Objective Questions – Part 4
