Reading: Types of Valve Leakage Tests
Inst Tools > Blog > Control Valves > Types of Valve Leakage Tests
Last updated: May 31, 2019 4:03 pm
Control Valves
3 Min Read
All valves are inspected and tested by the manufacturer to ensure that they conform to the required valve leakage standards. In addition, optional testing can be requested by the purchaser, and regular testing is critical for ongoing valve maintenance and safety.
Typical Valve Testing ProcedureTypes of Valve Leakage TestsValve Inspection and Testing Standard – API 598
In many cases it is recommended that valves are tested at an interval of no longer than 12 months. However, the specific interval may vary based on the valve condition, the service condition, and the desired level of performance.
Valve leakage is tested using either a hydrostatic test (i.e., the test medium is a liquid, such as water or kerosene) or a pneumatic test (the test medium is a gas, such as air or nitrogen). Zero leakage is rarely if ever possible, so the standards define the maximum allowable leakage (MAL) for valves under the specified testing conditions.
For both hydrostatic and pneumatic tests, the MAL is usually defined by valve size—a small amount of leakage through a valve with a small effective orifice poses much more risk than would the same amount of leakage through a valve with a large effective orifice. MAL may also be a function of the valve class and pressure category.
Valve leakage test results can vary based on the technique of the tester, so it’s essential to have your valves tested by trained, highly qualified technicians.
A typical hydrostatic valve test follows these basic steps:
  1. The valve body is filled with the testing fluid at the specified temperature.
  2. The specified pressure is applied for the specified length of time (usually at least 1 minute).
  3. Leakage is measured across the valve element of interest (e.g., stem, seat, closure mechanism) using both measuring instruments and visual examination. Most valve standards specify that no visually detectable leakage is allowed.
  4. A visual inspection is performed to ensure the valve has not been damaged during the testing procedure.
The tests that must be conducted depend on the type of valve and, therefore, the valve elements.
Below are some of the most commonly performed tests of valve leakage.
    • Valve seat leakage tests are required for pressure relief valves.
    • Backseat tests are required for valves with a backseat element, including gate and globe valves.
    • Closure tests are required to test the closure mechanism of several types of valves, including gate, globe, plug, check, and ball valves.
    • Shell leakage tests are required for valves that are used in “full open” and “full closed” service, such as check, stop, and isolation valves.
Source : alliedvalveinc.com
Articles You May Like :
What is Rupture Disk
Valve Seat Leakage
What is Pinch Valve ?
Questions on Valves
Valve Terminology
What is a Disc Valve ?
Rotork Motor Operated Valve Basic Configuration
What is Double-ported Globe Valve ?
What is Partial Stroke Test?
Solving Control Valve Hunting: Instrument Troubleshooting
Valve Interlock
  • Shivakumar K R says:
    June 24, 2022 at 3:12 pm
    THANK YOU VERY MUCH HELPFUL
Free Control Valve Software Download
Comparison of Gate Valves and Globe Valves
Pilot-operated Relief Valve Principle
Disassembly of Sliding-stem Control Valve
Pilot-operated Safety and Relief Valves
What is a Boiler Pressure Relief Valve?
Control Valve Air Lock Relay Working Principle
Self-actuated Temperature Regulator – Principle, Types, Advantages
Incident Investigation: Motor Operated Valve Lesson
What is Instrument Air Manifold
What is Instrument Air Manifold ?
3-way globe valve
What is Mixing or Diverting Valve ?
Relief Valve
Pressure Relief Valve Principle
Valves Pressure Loss - Questions and Answers
Valves Pressure Loss – Questions and Answers
Common Valve Abbreviations
Common Valve Abbreviations in US Engineering Drawings
Difference Between the Control Valve and Shut-off Valve
Safety Relief Valve Material Selection
YouTube Channels About Tech and Engineering
Awesome YouTube Channels About Tech and Engineering
Electrical Voltage and current Signals
Automatic Transfer Switch
Automatic Transfer Switch (ATS) Using Classic Control Circuit
What is PDCA - Industrial Maintenance
What is PDCA? – Industrial Maintenance
What is WHCP?
Formula for Linear mA to Square root mA conversion
Pneumatic Valves and Cylinders Sizing
Pneumatic Valves and Cylinders Sizing – Part 2
