Reading: Use of Regions in SCL Language
Inst Tools > Blog > PLC Tutorials > Use of Regions in SCL Language
Find out how the use of regions in SCL language can improve your programming efficiency and make troubleshooting easier.
Last updated: March 15, 2025 4:06 pm
TIA PORTAL provides one very interesting option where you can keep all your codes in separate areas. This helps for ease in troubleshooting. Due to this, if there is any issue in a code, you can see clearly which area has faults. Then, you can access that code and solve it. This option is called a region in SCL language. In this post, we will see how to use regions in the best way in SCL language.
What is a region in the SCL language?How to write regions in the SCL language?
A region is a feature by which you can structure your codes in specific defined areas. You have to name these regions and due to this, you will get a clear idea of what you have written in the program. Simply speaking, suppose there are 20 lines in a code. Out of that, the first 10 lines perform a different task and the other 10 lines perform a different task. Means, there are 2 groups in short. So, we can name these two groups as regions. Due to this, a programmer will know that there are two types of statements working in a code.
Regions can be expanded or collapsed in view. Due to this, the navigation becomes fast and you can decide which region to show and which region to hide. One more feature is that if a particular line in a region has an error, then that region will be highlighted with a cross mark. Due to this, you can quickly navigate to that region and rectify that fault.
Refer to the below image. Here, we have defined two regions. One is named as for and the other is named as while_do. The general syntax for writing a region is:
Region name
Statements
End_Region
So here, the first region covers the for statement written. The second region covers the while-do statement written. You can name the region in any way you require. You can use the – tab for expanding or collapsing a view as shown.
In the second image below, you can see a collapsed view of the regions. Due to this, you can clearly understand how many separate groups are working in a code. The variables may be linked in the whole program, but you can at least distinguish the groups which work in a similar manner.
On the left hand side, you can see the region names and even expand or collapse the view by clicking there. This also clearly helps in understanding the number of regions written in a section. When the arrow is down, it means the view has been expanded. When the arrow is right, it means the view has collapsed.
SCL Regions in TIA Portal
In the third image below, you can see a compile error written on line no.41, where the end keyword was commented. Due to this, that particular region showed a red cross mark as shown. This helps the programmer to quickly visit that region and see where the fault is.
Siemens SCL Region Programming Example
You can also right-click the region name and copy-paste it. This simplifies the process even more easily. Also, you can nest regions within regions. But remember to end them correctly; otherwise, a compile error will occur.
In the next post, we will see how to write a repeat-until statement in SCL language.
  • Flip-Flop PLC Programming Examples
  • PLC Manual Sequential Machine Program
  • Automatic Railway Crossing Gate Control
  • Siemens PLC Program Course for Beginners
  • Sequential Batch Mixing PLC System Program
Download Allen Bradley RSLogix PLC Software
How to Use ModScan Software for Testing Modbus Communication?
ControlLogix Architecture – Rockwell Automation
PLC Programming for Pumping and Draining System
Automation System for Hazardous Environments
Introduction to Functional Block Diagram in Studio 5000
Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
How to import GSD files into the TIA Portal? – Siemens PLC
Working Principle of Single Phase Preventer Relay
PLC Structured Text Program for Output Generation via Equations
Difference Between CompactLogix and ControlLogix
What is Trace Function in Tia Portal?
Retentive ON Delay Timer using PLC
PLC Raw Count Calculation formula for Pressure Transmitter
PLC Raw Count Calculation for Pressure Transmitter
Marshalling Panel
What is Marshalling Cabinet?
SR Flip Flop Logic
How to implement SR Flip Flop using PLC Ladder Logic
PLC Programming for Level Switches
PLC Programming using Level Switches
Studio 5000 Logix Emulate Controller
How to Create New Project in Studio 5000?
Distributed IO for Siemens PLC
How to Configure Distributed IO in a PLC Project?
Lamp Counter Logic
Function Block (FB) for Motor Control Logic
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
System architecture
Types of System Architecture used in Industrial Automation
Infrared Gas Analyzers Questions & Answers
Electrical Machines MCQ Series 5
RTD Construction
Introduction to RTDs
Vibrating Fork Level Switch Working Animation
Differential Pressure Transmitter with 5 Way Manifold Valve
pH sensor calibration procedure
displacer level transmitter cylindrical weighs
Displacer Level Transmitter 5-point Calibration
