Reading: Upload Option Disabled in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Upload Option Disabled in Siemens PLC
Last updated: March 4, 2021 12:11 pm
2 Min Read
How to upload the PLC ladder logic program in Siemens PLC if the upload option (icon) is disabled? Let’s learn with our tutorial.
This article is about uploading the PLC program using Simatic manager if the upload icon is disabled or not working.
Siemens PLC
Normally we face this problem when we download a trial version of the software or we forget to download the related software.
Follow the below step to run your program without any use of the upload icon.
Step 1:
Open Simatic manager. Configure devices and open programming environment.
Step 2:
Let for sake of example, take our famous DOL starter program which I want to test.
After writing the program, I realize that my upload icon is disabled.
DOL starter ladder logic program
Step 3:
Open the simulator.
Uploading Program in Simatic Manager
Step 4:
To run the program, open Simatic manager environment as shown in the below window.
Click on the “online” icon as you can see in the below window.
Step 5:
Clicking on online will open up another window. Click on the split icon shown in the red square to split both windows.
Offline window on the left side and online window on the right side.
In the online window, all the blocks are inbuilt system blocks.
Simatic Manager Offline window
Step 6:
Now simply drag “OB1” from the left side window to the right side online window.
The following pop-up will open. Click “yes” to proceed.
Insert Organization Block
Step 7:
As you can see “OB1” is added to the online window. Uploading is done. Now test the logic.
Uploading Siemens Manager
Step 8:
The program is running perfectly fine.
How to Upload PLC Program in Siemens PLC if Upload Icon is Disabled
Author: Suhel Patel
  • Extended Timer Logic in PLC
  • Pulse Generation Timer
  • Siemens CPU Status & Errors
  • FIFO Instruction in PLC
  • Workstation Healthiness Checks
How to Work With Simulator in S7-1200 and S7-1500 PLC?
Siemens HMI Training – Using UDTs with Faceplates
#3 PLC Best Practices – Leave Operational Logic in the PLC wherever feasible
Label the Electrical Circuit Schematic
Lamp Control using PLC Logic Condition
Complete PLC Project: Traffic Light Auto and Manual Automation
Industrial Oven Control Application with PLC Controller
Why is RTO used in the Place of TON Timer?
Configuration of InTouch Scada Trends
Timers using Statement List (STL) PLC Programming
How to Update the Firmware Version of your PLC
How to Update the Firmware Version of your PLC? – TIA Portal
Siemens Profibus Interface DP
How to Create New Project Using Simatic Manager
PLC control 4 machines with 1 button
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
PLC Ladder Logic Example
Analog Inputs in Siemens TIA Portal
What are Analog Inputs? – Analog Signals Processing in PLC
Multiple Pumps Control using PLC
Modbus in Industrial Networks
PLC Example on Manufacturing Line Assembly
Starting a Synchronous Motor
Fieldbus coupling devices
Fieldbus Coupling Devices
Hazardous Area Questions & Answers
Hazardous Area Classification Questions
OPC classic introduction
Overview of OPC Communication
Flow Standards
Flow Standards
Zener Diode Regulator
Zener Diode Voltage Regulators
Nonlinear Control Systems
Alternators Multiple Choice Questions
