Reading: Uncertainty Calculations of Pressure Calibration
Inst Tools > Blog > Calibration > Uncertainty Calculations of Pressure Calibration
For understanding Uncertainty Calculations, we will take an example of Pressure Gauge calibration.
Last updated: September 28, 2022 3:24 pm
Saurabh Vaidya
Calibration Pressure Measurement
6 Comments
9 Min Read
Uncertainty means how Uncertain (or certain) we are.
Types of UncertaintyThe Type AThe Type BUncertainty Calculations5 Point Calibration with 1 Up cycle and 1 Down cycleType A UncertaintyType B UncertaintyUncertainty due to Accuracy of Standard EquipmentUncertainty due to ResolutionUncertainty due to HysteresisUncertainty due to Zero ErrorCombined UncertaintyExpanded Uncertainty
No readings are complete without units and Uncertainty.
There are two types of Uncertainty
  • Type A uncertainty
  • Type B uncertainty
The Type A
The Type A evaluation of standard uncertainty is the method of evaluating the uncertainty by the statistical analysis of a series of observations.
Type A uncertainty is based on readings taken during calibration.
The Type B
 The Type B evaluation of standard uncertainty is the method of evaluating the uncertainty by means other than the statistical analysis of the repeat measurements.
Type B uncertainty is based on other factors than readings taken during calibration.
Uncertainty can be reported either in % value or absolute value.
% Value can be reported as % of reading (% rdg) or % of Full-Scale deflection (%FSD)
Uncertainty Components of Pressure Calibration to be considered but not limited to:
Type A
  1. Repeatability
  2. Reproducibility
Type B
  1. Uncertainty due to Standard equipment
  2. Accuracy of Standard equipment
  3.  Resolution
  4. Hysteresis
  5. Zero Error
Consider UUC pressure gauge of range 0 to 10 bar with resolution 0.1 bar calibrated with master pressure Gauge of range 0 to 40 bar with resolution 0.001 bar.
Uncertainty of master pressure Gauge is 0.01 bar with K=2. Accuracy is 0.1% rdg.
Cal PointUUC
Reading
Standard Reading
(UP)
Standard Reading
(DOWN)
Average
BarBarBarBarBar
00.00.0000.0000.000
22.02.0032.0052.004
44.04.0064.0044.005
88.08.0058.0068.006
1010.010.00810.00710.008
Type A Uncertainty
Type A uncertainty is the standard deviation of readings.
Type A Uncertainty Formula
Where:
x:  reading
x̄: Mean (average)
n: no of readings i.e. 2 in the above case
Using excel in can be calculated using formula = STDEV ()
Uncertainty due to Standard Deviation (Ua)
(Ua)= S.D / sqrt (n)
Sqrt: square root
Cal PointType AUa
BarBarBar
000
20.0014140.001
40.0014140.001
80.0007070.0005
100.0007070.0005
Type B Uncertainty
Uncertainty of standard equipment is mention on the calibration certificate. Also, the K value is mention in the calibration certificate.
Uncertainty due to Standard equipment (Ub1) = Uncertainty of standard equipment/ k
Here, in our example Uncertainty of Standard is 0.01 bar and K value is 2.
As this is absolute value directly in Pressure units, it is the same for the whole range.
If Uncertainty is provided in % rdg, it will be different for different calibration points.
Cal PointUncertainty of StandardUb1
BarBarBar
00.010.005
20.010.005
40.010.005
80.010.005
100.010.005
Accuracy is expressed in % rdg or % full scale or absolute readings direct in units
Uncertainty due to Accuracy of Standard equipment (Ub2)
Ub2 = Accuracy of standard equipment/ Sqrt (3)
Assuming rectangular distribution, the value obtained is divided by a square root of 3
In our example, accuracy is % rdg. Therefore accuracy will be different for every reading.
Cal PointAccuracy of StandardAccuracy of StandardUb2
BarBarBarBar
00.1%*000
20.1%*20.0020.001155
40.1%*40.0040.002309
80.1%*80.0080.004619
100.1%*100.010.005774
If UUC is set according to calibration point, and Standard reading is changed, resolution of Standard is considered.
If the Standard Pressure gauge is set according to calibration point, and UUC readings are changed, the resolution of UUC is considered.
In or above example, UUC is set and Standard readings are changing,
Therefore, the Resolution of a standard pressure gauge is considered.
The resolution of the Standard pressure gauge is 0.001 bar
Uncertainty due to Resolution (Ub3) = ((Resolution of Changing pressure gauge/2)) / SQRT (3))
Cal PointResolutionUb3
BarBarBar
00.0010.000289
20.0010.000289
40.0010.000289
80.0010.000289
100.0010.000289
Hysteresis is the difference between Down Cycle reading and UP cycle reading.
For 2 up and 2 down cycles. Hysteresis is the maximum difference between Down Cycle reading and UP cycle reading.
Uncertainty due to Hysteresis (Ub4) = (Down reading- up reading)/ Sqrt (3)
Cal PointHysteresisUb4
BarBarBar
000
20.0020.001155
4-0.002-0.00115
80.0010.000577
10-0.001-0.00058
The Reading is noted when the pressure of the instrument is completely released.
The Zero Error is calculated as follows:
Zero Error= l x2,0 – x1,0 l
I.e. Zero readings of down cycle – Zero readings of up cycle
For Multiple cycles. The maximum value is Zero error.
Uncertainty due to Zero Error (Ub5) = Zero error/ Sqrt (3)
Cal PointZero ErrorUb5
BarBarBar
00.0000.000
20.0000.000
40.0000.000
80.0000.000
100.0000.000
Combined uncertainty is not simple addition.
Step 1: All individual uncertainty Ua, Ub1, Ub2, Ub3, Ub4, Ub5  are squared.
Step 2: All individual uncertainty is added after squaring
Step 3:  Square root of the value obtained in Step 2
Cal PointUaUb1Ub2Ub3Ub4Ub5Combine Uncertainty
BarBarBarBarBarBarBarBar
000.00500.00028900.0000.005
20.0010.0050.0011550.0002890.0011550.0000.005
40.0010.0050.0023090.000289-0.001150.0000.006
80.00050.0050.0046190.0002890.0005770.0000.007
100.00050.0050.0057740.000289-0.000580.0000.008
Combined Uncertainty is also called Standard Uncertainty
Cal PointCombine UncertaintyCombine Uncertainty
BarBarBar
0Sqrt (02+0.0052+02+0.002892+02+02)0.005
2Sqrt (0.0012 +0.0052  + 0.0011552  +0.0002892 +   0.0011552 +02)0.005
4Sqrt (0.0012 +0.0052  + 0.0023092  +0.0002892 +   0.0011552 +02 )0.006
8Sqrt (0.00052 +0.0052  + 0.0046192  +0.0002892 +   0.0005772 +02)0.007
10Sqrt (0.00052 +0.0052  + 0.0057742  +0.0002892 +   0.000582 +02)0.008
Standard Uncertainty is multiplied by the k factor to obtained Expanded Uncertainty.
Where k is the coverage factor corresponding to the effective degree of freedom.
k factor is generally 2.
Cal PointExpanded Uncertainty
BarBar
00.010
20.011
40.011
80.014
100.015
Expanded uncertainty is reported in the calibration certificate.
A similar type of calculation is done for 9 Point calibration with 2 up and 2 down cycles.
  • Calibration Organizations
  • Selection of Master Instrument
  • Importance of Unit Measurement
  • Why Calibration is Important?
  • Repeatability and Reproducibility
Basics of Pressure
Why it is important to note As-Found and As-Left data during Calibration?
Pressure Measurement using Manometer
Multiphase Flow Meter Calibration Procedure
6 Comments
  • Bruno says:
    August 15, 2021 at 12:43 am
    For pressure transmitter according to DKD, 9 points is standard procedure. Up down up.
    5 point calibration is for low level pressure gauges. Above CL 1
  • Hajarana says:
    September 22, 2022 at 2:59 pm
    Dear Sir,
    Profound gratitude for conveying your valuable information.
    Thanks
    Hajarana
  • Sasikaran says:
    May 31, 2023 at 11:34 pm
    Dear sir thank you so much for your explanation.
    Regarding the resolution which standard are said that resolution take for UUT or Master equipment
  • Zonele Vuke says:
    June 11, 2023 at 5:28 am
    Very informative & straight to the point, thank you.
  • Kumaresan says:
    July 10, 2023 at 6:28 am
    Hi Sir,
    Thanks for the informative knowledge. But how do you get combined uncertainty value. As calculate in excel i got (0.050) bar for each point. Kindly please explain Thank you.
  • Shiv says:
    August 26, 2023 at 3:48 pm
    Dear Sir
    Please explain Weighing Balance Uncertainty Value calculation with Example
Calibration Procedure of Weighing Balance and Common Mistakes
Turbidity Sensor Calibration Procedure
Stability and Uniformity of Temperature Bath
Pressure Gauge Cocks
Methods of Measurement
PLC Raw Count Calculation for Pressure Transmitter
Types of Manometers
Selection of Master Instrument for Calibration
Difference between Calibration and Ranging
Magnehelic Gauge Calibration
Capacitance Pressure Sensor Principle
Electronic Pressure Sensors Principle
Multiple Position Calibration of Temperature Chamber (Mapping)
Identify the Pressure Gauge Error
5 Valve manifold
5 Valve Manifold Operation
How to do calibration checks of vibration Probe, extension cable and vibration monitor
spiral bourdon tube
Bellows, Diaphragms and Bourdon Tubes
Arc Protective Clothing
What is Arc Protective Clothing? – Importance, Features, Materials
Electrical Motor Model number and serial number
How to Read the Nameplate of a Motor?
DP Transmitter Wet Leg Compensating Impulse Line
Questions on DP Transmitter Wet Leg Compensating Impulse Line
On-Off Valve Problems
How to Solve On-Off Valve Problems?
Why Do We Need to Connect Transformers in Parallel
Why Do We Need to Connect Transformers in Parallel?
What is PDCA - Industrial Maintenance
What is PDCA? – Industrial Maintenance
level-transmitter-calibration-procedure
Level Transmitter Calibration Procedure
Relay Parts
NO vs NC Contact
