Root Cause Analysis (RCA) related to the pumps’ turbine to gearbox alignment drifts caused pump transfers upset operations.
| Category: | Mechanical |
| Equipment Type: | Miscellaneous Rotating Machine Problems |
Turbine to Gearbox Alignment Drifts Problem
Even after eliminating the gearbox (GB) failures, frequent turbine driven Cooling Water pump changeovers problems and associated problems discussed in earlier Problem persistently plagued the plant.
On enquiring, the crew said that is from day-1 problem with the indigenous steam turbines, which even the US rotating machine crew could not solve!
Author Root Cause Analysis
The turbine’s unfamiliar looking spring support puzzled the author. The crew informed that it was the US Rotating Machine Technician’s brain child as he thought the indigenous turbine’s support was inadequate!
The author knew of same vendor’s several turbines doing fine with the original support.
Final Solution
The turbine vendor installed their standard supports one at a time to each of the two turbines eliminated alignment drift problem forever and the turbine driven pumps attained near 100% availabilities.
Benefits Realized
Benefits realized are:
- 10% production increase from uninterrupted cooling water pump runs and consequent smooth plant runs
- Vanished total plant shutdown threats during plant load adjustments to suit cooling water availabilities during GB caused pump outages
- Operation and maintenance crew morale increase from freed repeat works drudgery
- 1.8 bars lube oil pressure eliminated (Journal Bearing) JB failures totally and the 65o C gearbox oil temperature instead of the former 115o C the rapid gear teeth wear and consequent too frequent gearbox change threats
Author: S. Raghava Chari
- Turbo-Compressor Problem
- Compressor Anti-Surge Control
- Plant Turbo-compressor Problem
- Failing Plant Air Compressor Drives
- Condensate Pump Frequent Wrecks
