Reading: Three Phase Systems
Inst Tools > Blog > Electrical Theory > Three Phase Systems
Three Phase Systems
Last updated: August 2, 2018 5:41 pm
Electrical Theory
1 Min Read
A three-phase (3φ) system is a combination of three single-phase systems. In a 3φ balanced system, power comes from a 3φ AC generator that produces three separate and equal voltages, each of which is 120° out of phase with the other voltages (Figure 10).
Three-Phase AC
Figure 10 : Three-Phase AC
Three-phase equipment (motors, transformers, etc.) weighs less than single-phase equipment of the same power rating. They have a wide range of voltages and can be used for single-phase loads. Three-phase equipment is smaller in size, weighs less, and is more efficient than single-phase equipment.
Three-phase systems can be connected in two different ways. If the three common ends of each phase are connected at a common point and the other three ends are connected to a 3φ line, it is called a wye, or Y, connection (Figure 11). If the three phases are connected in series to form a closed loop, it is called a delta, or ∆, connection.
3φ AC Power Connections
Figure 11 : 3φ AC Power Connections
Series Resistance
Batteries Theory
Ammeter
Schematic Diagram
Thermocouples
Series Open Circuit Faults
Electrical System Components and Protection Devices
Transformer Operation Under No-Load
Induction Motor
Applying Kirchhoff’s Voltage Law
Resistance in Parallel Circuits
Calculate Power in Parallel RL Circuit
Moving Iron Vane Meter Movement
Capacitor Principle
Capacitor
Parallel RLC Circuit
Impedance in RLC Circuits
Transformer Coil Polarity
3 Phase Balanced Loads
Power in Balanced 3 Phase Loads
Parallel Circuit Parallel Current Calculations
Parallel Circuit Current Calculations
Single Line Diagram
Single Line Diagram
Using Kirchhoff’s Voltage Law to find Current with Multiple Battery Sources
Kirchhoff’s Laws
Parallel Open Circuit Fault
Parallel Open Circuit Faults
Infrared Spectrometers Questions & Answers
Comparison of Pressure Instruments - Industrial Instrumentation
Comparison of Pressure Instruments – Industrial Instrumentation
Difference Between MCB and MCCB
Time Response Analysis
Approximation of Higher-Order Systems by Lower Order
Strain Gauge Bridge Circuit
Something is Wrong with Strain Gauge Bridge Circuit
High Voltage and Power System Stability Interview Questions
Flame Detector Testing Procedure
Three Wire RTD Wheatstone bridge Circuit
RTD Wheatstone Bridge Circuits
