Reading: Thermal Dispersion Flow Switch Working Principle
Inst Tools > Blog > Flow Measurement > Thermal Dispersion Flow Switch Working Principle
The thermal dispersion flow switch is a precise flow-sensing device for liquids. The principle of operation is based on heat transfer.
Last updated: November 1, 2023 11:31 am
Flow Measurement Switches
2 Min Read
Thermal Dispersion Flow SwitchWorking Principle
Based on the principle of heat transfer, the thermal dispersion flow switch consists of two temperature sensors. One temperature sensor is the reference and measures the temperature of the fluid where the thermal dispersion flow switch probe is immersed.
The second temperature sensor is placed near a heating element. As flow flows. there will be a temperature difference between the two temperature sensors.
Working Principle
As the flow rate of the fluid increases there is a cooling effect due to the fluid moving past the heated sensor. The more flow, the more the cooling.
A reduction in temperature difference between the two temperature sensors indicates that the flow rate exceeds the user-adjustable set point. When the flow rate drops there is less cooling, which causes an increase in the temperature difference.
When liquid is flowing, there is a temperature difference between the two sensors. The temperature difference has an inverse relationship with the flow velocity (fast-flowing liquids will result in greater heat differences and vice versa) and the same is used to detect flow. Since the device contains no moving parts, has no wear and tear, and maintains a long lifespan.
Reference: FineTek
  • What is a Thermal Flow Meter?
  • Flow Control Loop Controller
  • Why Flow Directly Proportional
  • InLine Flow Switch Animation
  • Rotary Flow Meter Principle
Ultrasonic Flow Meters Animation
Interview Questions on Flow Measurement
Pushbutton switches and Types of Switches
Different Flow Measurement Technologies
Importance of Flow Meter Turndown Ratio
Factors Affecting the Performance of Ultrasonic Flow Meters
Difference between Fixed Area & Variable Area FlowMeters
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Coriolis Mass Flow Meter as a Multi-Variable Transmitter
Area Velocity Flow Meter Principle
In-Line Flow Switch Working Principle and Animation
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
Heat Tracing Problems
Integral Orifice Parts
What is Integral Flow Orifice Assembly?
mass flowmeters
Orifice Flow Measurement Formula
Basics of Flow Measurement
Advantages and Disadvantages of Flow Measurement Techniques
Advantages & Disadvantages of Different Flow Meters
Paddlewheel flowmeter principle
What is a Paddle Wheel Flow Meter?
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Side Mounting Float Switch Working Principle
Boiler Level Switch
Float level switch Principle
Modbus scan
How Modbus Communication works
Single Beam and Double Beam Instruments
Pressure Gauge Calibration according to Standard DKD-R-6-1
phototransistor symbols
Phototransistor Working Principle
3-Wire, Three-Phase Delta Wiring System
Tank car bonding at siding
Electrical Static Grounding Techniques
Digital Electronics MCQ
Karnaugh Map Objective Questions
Two SOV Connections
Two Solenoid Valves Working Principle
