Reading: Structured Text PLC Code for Sequential Process Data Storage
Inst Tools > Blog > PLC Tutorials > Structured Text PLC Code for Sequential Process Data Storage
Learn how to write a structured text PLC code to store data from sequential processes using the case statement.
Last updated: September 18, 2024 2:34 pm
3 Min Read
In this post, we will write a PLC code to store data of various processes sequentially. We will use structured text language for this.
Sequential Process Data StorageStructured Text PLC Code
Let us understand the case scenario first. There are two sensors in the system – temperature and pressure. And in total, there are five processes. Process start and stop are not in our control, we will just get the status of the process (whether it is running or stopped).
When the five processes start in sequence, we get a complete signal from each process when over. With this signal, we must store the current value of temperature and pressure in different registers. The values of these registers will be updated after the corresponding process is over every time.
Following are the PLC IO’s:
  1. Digital inputs – Process complete signal
  2. Analog inputs – Temperature transmitter, pressure transmitter.
Let us see the logic now. Refer to the below image. It is a very simple logic where we use a case statement. We first use a sequence counter to see in which the current step is running.
We increment the counter on every input signal of the process completely received. The set value of the counter will be five, as per the five processes running.
We will reset the counter when the counter is done.
Structured Text PLC Program for Sequential Process Data Storage
In the next step, we use a case statement. We use five cases. As the counter increments on receiving the process complete signal, this means the current counter value is the current step running. So, we use the case number from 0 to 4, where 0 means step 1 and 4 means step-5.
In each case, we use two different registers of temperature storage and pressure storage. For incrementing the case, we use the counter current value as a case reference. This will ensure that in each step, only the corresponding registers will be written.
In this way, we saw how to write a PLC program to store data of various processes sequentially.
  • PLC Program for Sequential Motor Control
  • Run Motors Sequentially using PLC Program
  • Sequential PLC Program Pneumatic Valve
  • PLC Program for Water Level Control Logic
  • Compare Combinational & Sequential Circuit
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
PUT Command in Siemens PLC – TIA Portal Basics
Auto Sugar Bag Filling Station
Types of PLC Memory
Siemens Drum block for Sequencer Operation
Do’s and Don’ts in PLC
Timer in Studio 5000 – TON, TOF, RTO
How to Troubleshoot Siemens PLC Programs?
Automatic Door Operation PLC Programming and Simulation
PLC Brands Software Information
PLC Timer Instructions
PLC Motor Control Ladder Logic
PLC Program for Star Delta Motor Starter
How-to do Security of SCADA Systems
How-to do Security of SCADA Systems?
Batch mixing process automation with Omron PLC
Automate Batch Mixing with Repeated Cycles in Omron PLC
3 to 8 Line Decoder Circuit Diagram
3 to 8 Line Decoder PLC Ladder Diagram
Schneider PLC Programming Example
Schneider PLC Programming Example for Beginners
Save to Memory Card
How to Save a PLC Project to a Micro Memory Card?
Relay Wiring
PLC Program for Forward and Reverse Motor control
3 Phase Motor Control using PLC Ladder Logic
How to Calibrate Load Cells
Renewable Energy Projects
200 Renewable Energy Projects for Students and Engineers
Electronic Meters Questions & Answers
What is Zero Trust Security
How a Single ZTNA Solution Can Help Overcome Cybersecurity Issues?
Boiler Feed Water Circulation System
Resistive Transducers Objective Questions
Thermocouple Calibration
Programmable Logic Controllers Multiple Choice Questions
