Reading: Steps to Import PlantPAx Add-On Instructions in Studio 5000
Inst Tools > Blog > Control Systems > Steps to Import PlantPAx Add-On Instructions in Studio 5000
In this article, you will learn the steps to import PlantPAx Add-On Instructions in Studio 5000 logix designer.
Last updated: July 2, 2022 11:22 am
Control Systems
3 Min Read
PlantPAx Library consists of a set of Add-on-blocks for configuring parameters and operating analog inputs, analog outputs, digital inputs, and digital outputs.
Import Add-On Instructions in Studio 5000
We will Import all required add-on-instructions to help us create instructions for analog inputs, analog outputs, digital inputs, and digital outputs.
Step1: Open Studio 5000. Click on New Project and Select controller.
Studio 5000
If you have PLC Hardware you can choose Specific Controller from the list and type the name of the project you want and click on Next.
Studio 5000 Logix Emulate Controller
I have selected Emulator (Studio 5000 Logix emulate)
Step 2: Right Click on Add on Instructions and click on Import add on Instructions.
For Analog Inputs, Select all P-AIN Add-On-Instructions as per requirements as shown below.
Select P-AIN Add-On-Instructions
P-AIN- It states Analog Input block as shown below.
PlantPax Analog Input Block
Below are the Parameters, according to requirements you can choose.
Step 3: Import all required analog input add-on instructions similarly.
Import analog input add on instructions in studio 5000
Please note below add-on-instruction will work on the Functional block diagram routine only as it indicates the FBD symbol.
FBD symbol
You will see some add-on instructions in the list that will work on the Ladder diagram only.
Ladder Diagram add-on instructions list
Step 4: For analog outputs, for the control valve, I will be using the P_PIDE add-on block as it has better functionality for tuning and better scalable parameters.
P_PIDE add-on block
Step 5: Now I will import the Digital input add-on block eg: it can be used for limit switches, relays, etc. as per your availability and requirements of parameters you can select the checkboxes.
Digital input add-on block in PlantPax
Step 6: Next I will import Digital _Output add-on instructions, this can be used for configuring and operating On-Off valves, dampers, electrical motors, indicators and alarm bells.
a. Digital Output block add-on for Solenoid On-Off valve.
b. Digital output block add-on for Variable speed drive.
c. Digital Output block for Motor
Digital Output block for Motor in Logix Designer
Step 7: Now I will be importing the most important and frequently used add-on block called “Interlock” which can be used anywhere to provide interlock to any device for the legitimate process.
Interlock Function Block in Studio 5000
Interlock block has a 16-bit array i.e you can configure 16 interlocks for a valve or motor or any digital output devices.
  • Import PlantPAx Library
  • DCS Technical Evaluation
  • Download PlantPAx Library
  • Condensing Turbine System
  • Cloud PLC and SCADA System
PID Controller Action : Directing Acting & Reverse Acting
Pre-commissioning or Commissioning Activities
Control Panels Material Take-Off (MTO) – Engineering Project
14 Basic Control Systems Questions for Interview Preparation
Types of Interlocks
What is Alarm Shelving? – Nuisance Alarms, Types, Suppression
Vendor View of Supplying Industrial Process Control & Safety Systems
Chemical Reactor Temperature Control System
Difference between ON-OFF Controller and PID Controller
Steady-state process gain
Steady-State Process Gain
PID Controller
Proportional Integral Derivative Controllers – PID MCQ
Voting System in PLC
Voting Concept in Package Safety System
NAMUR OPEN ARCHITECTURE
Integral Wind-Up Limitation
What is Integral Wind Up ?
System architecture
Types of System Architecture used in Industrial Automation
Ziegler-Nichols closed-loop Formula
Tuning a Temperature Process Control Loop
Process Control System
Basics of Process Control Systems
Smart Sensors in Industry
Smart Sensors in Industry – Components, Types, Advantages
Encoder Principle
Encoder Working Principle
Testing of Pneumatic Systems
Tunnel Diode
Tunnel Diode Working Principle
Liquid Chromatography Questions & Answers
Location of Measurement Displays
Multi-Cartridge Filter
Cartridge Filters
