Reading: Difference Between Static and Temp Memory in Siemens PLC TIA Portal
Inst Tools > Blog > PLC Tutorials > Difference Between Static and Temp Memory in Siemens PLC TIA Portal
Temp memory minimizes PLC program size and static memory maintains data over several scan cycles in the Siemens TIA portal.
Last updated: October 17, 2023 3:18 pm
Hussien Ghareb
Totally Integrated Automation (TIA) software from Siemens is one of the best PLC Automation software platform in the world, it offers a lot of great features.
What is Static Memory?What is Temp Memory?Usage of Static and Temp Memory in PLCMonitoring Level of TanksDownload Siemens TIA Example LogicSummary
one of these features is the ability to size and configure your memory using Static or Temp locations, as a professional PLC programmer you have to organize your code and also your DataBase as that would really accelerate your scan cycle managing your PLC to perform faster.
So here we are to talk about those two types of memory (Static & Temp) and also we will see what is the difference between them.
Static memory is a type of memory which is non-volatile, it stores data permanently with fixed addresses.
The stored data would be changed in case of overwriting so it could remain for several scan cycles without changing, this kind of memory only allocated at Function Blocks (FB).
For Temp memory We can say that it is a Volatile one as the data can not remain for just one cycle.
It stores data for a single scan cycle and after that, the data will be lost, this kind of memory is allocated in the organizational Blocks (OB), Functions (FC), or Function Blocks (FB).
We can summarize that “Static memory has a reserved place for storing data but Temp memory does not have”
Now, we already know what is the difference between both and what is really a static and temp memories are but the big deal is to know how and when you should use these memories.
As a PLC programmer, all of us know very well about Static memory, it is the place where our data is stored such as temperature reading, power consumption for the plant, or the status of your digital sensors in the plant.
All of this data should be stored in a static memory to ensure that the data will not be lost as we want to reuse it again in other places of your code.
Unlike the Temp memory, you can use it when the stored data is needed for just one scan cycle, after that the stored data will be useless so definitely there is no need to reserve a place for this data.
Here we can store it into a temp memory until the job is done after that the memory will be free again that would really make a huge minimization of your storage memory (for large plants coding), maybe you can use this type of memory in mathematical operations or transferring and conversion between data.
The best way to understand anything is to relate it with an example so, here we are with a simple code that monitors the level of ten tanks, each tank has its own Level Transmitter.
and as all of us knows the analog input for Siemens PLC is detected by Input word (IW0, IW2, IW4 …..), but for more accurate calculation most programmers convert it to Real data type (Double word), so for now we should convert every level transmitter to a Real data type before the processing.
So, this situation is for you, would you prefer to use ten static area locations for the conversion of every level transmitter!! Or using single Temp area that can make the same thing for the ten transmitters!!
I think it would be much better if we used a single Temp memory for customize and minimize the size of memory.
Monitoring Level of Tanks in Tia Portal
  • Tanks Level Monitoring Tia Portal Code
  • Tanks Operation Tia Portal Code
Summary
Temp memory would really minimize your program size if it can be used in your program.
Static memory has the ability to maintain data over several scan cycles to reuse it again in your code, both are important to use and to enhance your PLC program.
  • Configuration of Siemens VFD
  • What is a Motion Controller?
  • Purpose of SCADA and HMI
  • Ferrules and Cross Ferruling
  • Basic PLC Question Bank
How to Take Program Backup from Physical PLC? – Siemens PLC
Basics of Loop Checks
How to Troubleshoot Siemens PLC Programs?
Types of Limit Switches – Principle, Advantages, Disadvantages
Difference Between CompactLogix and ControlLogix
SCADA Engineer Job Responsibilities and Skills
PLC SCADA Engineers Interview Questions and Answers
FactoryTalk View Studio – Import and Export Tutorial
PLC Programming for Train Detection and Gate Operation
PLC Example with Switches
PLC Program for Food Processing Industry
Types of PLC
Micro PLC
Micro PLC Hardware Configuration
Smart Drip Irrigation System Using PLC
Loss in Weight Liquid PLC System
Dosing Pump PLC Logic
Function Block Diagram - Studio 5000 Logix Designer
Define the Order of Execution in Functional Block Diagram of Studio 5000
What is meant by the Batching Process
Batch Simulator PLC Example Program using LogixPro Simulator
siemens plc db addressing
FB Block in Siemens PLC Programming
Automating Car Parking with Advanced PLC Logic
PLC Program for Automatic Door Control System
PLC Automatic Door Control System – Programming Example
Automatic Coffee Machine
Automatic Coffee Vending Machine – PLC Logic Programming
Burst Transformers Root Cause Analysis
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
Safety Relief Valve Questions & Answers
Fieldbus Interview Questions
Interview Questions on Fieldbus Communication
Radar Level Transmitter in Briddle level Measurement
Power Transistor Objective Questions
Power Systems MCQ Series 16
What is a Fieldbus?
