Reading: SIS Software Simulation – Safety Instrumented System
Inst Tools > Blog > Safety Instrumented System (SIS) > SIS Software Simulation – Safety Instrumented System
Safety Instrumented System (SIS) software simulation before commissioning of any SIF is necessary to do testing in a safety PLC.
Last updated: May 25, 2022 3:15 pm
Safety Instrumented System (SIS) software simulation before commissioning of any SIF is important and also necessary to do simulation testing as and when there are changes in the safety instrumented function.
SIS Software TestsSafety Instrumented System Simulation ProgramSIS Software Simulation TestsSIS Software Documentation
Below are the brief tests followed:
  • Software program Verification
  • The SIL program shall be verified against its specification prior to initial operation by all the below:
  • Application program to be verified
  • Application program to be validated by functional tests.
SIS Software Tests
Software tests objectives shall confirm – To verify the application program works & No outside interference from other programs exists.
Parts of Safety PLC
Example: Pressure transmitters with voting 1oo2 logic. Image Courtesy: Endress Hauser
  • Items to be checked for Inputs:
    • All inputs shall not violate physical limits or boundaries
    • All inputs should produce approximately correct values
    • All inputs should reflect dynamic behavior where required
    • Test program to be created to ensure each module is checked.
    • Untested modules, modified modules, or special software program needs to be thoroughly tested to ensure they have correct interactions & communications with other modules.
Software simulation checks shall include below minimum checks:
  1. Startup and shutdown.
  2. Normal operating behavior.
  3. Alarm conditions.
  4. Safe state when required
Software simulation tests may be done in different stages of the project (Such as integration tests with DCS vendor and Factory Acceptance Test, or field Validation tests) to show that the application software achieved its requirements on the specified hardware and within the defined time as per safety requirements.
Below parameters needs to be ensured during the SIF requirement software simulation check.
  • SIS trip at the proper setpoint
  • Configuration permutations – for 2oo3, verify with multiple 2 sensors combinations.
  • Verify the timing of the whole loop – from sensing the problem to the final action completed – conforms with the SIS loop response time as defined in the Safety Requirement Specifications (SRS).
  • Verify if Diagnostics is accounted for in the logic. For example, for 1oo2D configuration, a diagnosed failed sensor is not voted to trip, but for 2oo3 it can be considered for the vote to trip.
Changes resulting from simulation and testing must follow plant management policies, including hazard analysis, if necessary.
  • From the start of the formal testing, all changes to software functions and configuration data should be implemented strictly in accordance with a defined modification procedure (i.e. Management Of Change – MOC), because the program has already been verified during the SIS Assessment. Modifications without following the MOC process will invalidate the SIS Assessment.
  • During application software integration, any modification to the software shall be subject to a safety impact analysis that shall determine:
a) All software modules impacted
b) Necessary re-design and re-verification activities.
Simulation and test results should be made available to the Safety Coaches for the assessment as per the SIS Work Process.
Software Simulation results need to be documented with the below details:
  • Date of testing
    • Type of test
    • The person involved in testing
  • Also update the simulation testing in Safety Requirements Specification (SRS) documents along with the Maximum Allowable Response Time (MART), and the SIS response time.
The SIS response time must be verified – as good as designed.
However, some things cannot be checked during simulation:
  • For Valves – the time taken by the actuator to close the valve cannot be simulated accurately, hence there may be a mismatch with respect to design.
  • For Temperature elements – the time for process temperature to increase the thermowell is impossible to simulate since it is a function of the thermowell design. Normally temperature sensor takes some time to sense the process temperature.
Hence it is important to check the Software simulation during the SIS-related project implementation/modifications, Factory Acceptance tests, Site Acceptance tests, Validation tests, etc. few manufacturers supply the application program along with an emulator to test the program offline before saving it in the controller.
  • SIS Component Selection
  • SIS Safety Requirements
  • Instruments Sharing in SIS
  • Partial Stroke Testing Device
  • Safety Systems Online Exam
SIS Emergency Block Valves (EBV)
Common Cause Failure – Safety Instrumented System
Safety Requirement Specifications (SRS) – Safety Instrumented System
Pilot-operated Safety and Relief Valves
What is Shutdown Valve?
Functional Safety Questions & Answers
What is Safety Control System ?
SIS Hardware Fault Tolerance – Methods to Overcome HFT issues
SIS Final Control Elements
Rupture disks
Safety Instrumented System Module Failure
SIS Application Program – Safety Instrumented System
Why choose Intrinsic Safety ?
Basic Terms used in SIL Verification
safety PLC programming
SIS Logic Solver
Voting Logic in Safety Instrumented System (SIS)
PRV
Selecting a SIS or SIL Level
Importance of Safety Integrity Level
SIS System Testing - Safety PLC Control System
SIS System Testing – Safety PLC
What is HIPPS System in Oil and Gas
What is HIPPS System in Oil and Gas?
S84 - IEC 61511 Standard for Safety Instrumented Systems
S84 / IEC 61511 Standard for Safety Instrumented Systems
CPU Communication Ports in Siemens PLC
Types of CPU Communication Ports in Siemens PLC
UDT in the PLC Programming
Implement UDT in PLC Programming: User-Defined Data Type
Marking Machine
PLC SCL Program for Marking Machine
Laser Cutting Precision and Accuracy
Benefits of Steel Laser Cutting
Difference Between Modbus and Profibus
HR Interview Questions & Answers
HR Interview Questions and Answers
Statement List (STL) to Find Highest Value in the Data Block
What's the problem with shock and vibration
What’s the problem with shock and vibration ?
