Reading: SIS Instrument Sharing – Transmitters Shared for BPCS and SIS Example
Inst Tools > Blog > Safety Instrumented System (SIS) > SIS Instrument Sharing – Transmitters Shared for BPCS and SIS Example
In Safety Instrumented System (SIS), Instrument sharing may be considered with due caution to ensure all protection layers are independent.
Last updated: May 21, 2022 10:48 am
In Safety Instrumented System (SIS), Instrument sharing may be considered based on the system configuration and available sensors or final control elements with due caution to ensure that all protection layers are independent.
SIS Instruments SharingSafety Instrumented System Sharing BasicsA basic example of Independent Protection Layer creditsTransmitters Shared for BPCS and SIS ExampleBasics of SIS Instruments SharingSharing KeypointsCaution with Instruments Sharing
  • The layer of Protection Analysis (LOPA) conservatively assumes that every Independent Protection Layer (IPL) is independent and provides integer order of magnitude risk reduction credits.
  • Sharing Rules have been developed for practical application, using international standards such as IEC for guidance.
  • Any sharing typically violates the assumptions and calculations behind LOPA.
  • Each Layer of Protection is like a barrier or wall that can prevent something from happening, hence proper care is to be considered while sharing instruments.
  • Each IPL may have different strengths, or effectiveness (IPL credits) and hence diversified instruments can be considered while sharing.
  • Each IPL must be independent – common elements (common mode failures) may reduce or eliminate the strength of some or all layers. when the instruments are designed for sharing ensure to avoid common power, instrument tapping, etc.
If the protection layers are not independent, then the shared components must be made stronger to make up for the lack of independence.
The below picture shows the Independent protection layer (IPL) credits with
Safety Instrumented System – 1 credit
Safety Relief Protection System (Ex. Rupture disk) – 1 credit
Basic Process Control System – 1 credit
Pressure Safety Valve – 2 credits
Total – 5 credits
Sharing BPCS and SIS Field Instruments
In this below example, two Temperature transmitters are shared for BPCS and SIS.
transmitters shared for BPCS and SIS
The Sharing basics as below
1. Sum of the LOPA credits
Design as SIL-2 (SIL-1 + BPCS LOPA credits).
2. Increased diagnostics
Shared instruments need 90% diagnostics.
70% for smart NAMUR instruments,
20% for “open/short circuit” detection plus Deviation Alarm between redundant sensors.
3. Independent usage of sensors
BPCS must select the signal (high or low) that will drive the process to a safe state.
Sharing Keypoints
  1. Sharing without an SIS is allowed (Like for Operator response to alarm & BPCS functions), but the shared components must be treated (designed, documented, tested, and audited) as SIS elements. [It may be less confusing to just make it a SIL-2 SIF!!]
  2. Duplication of shared code for independence (instead of different selection mechanisms).
  3. Sharing of the Initiating Event (if the sharing rules are allowed per calculation tools)
  4. It is allowed to share only once.
  5. It is not allowed to share a set of sensors between [BPCS, SIS & ALARM], [IE, SIS & ALARM], etc. The only exception is motor starters.
  6. The maximum “Sum of the LOPA credits” is 3.
If shared components “could be” the cause of the initiating event, then it’s not allowed to share.
  • What is HIPPS System?
  • Emergency Block Valves
  • SIS Common Cause Failure
  • SIS Verification & Validation
  • Testing and Repair Deferral
Safety Integrity Level (SIL)
SIS Bypass and Impairment – Safety Instrumented System
Common Cause Failure – Safety Instrumented System
What is Maintenance Override Switch (MOS) ?
Rupture disks
  • Taekbeom Kwon says:
    November 20, 2023 at 1:28 pm
    Hello, I have a doubt in the sharing.
    What norm allows the sharing sensors between BPCS and SIS, as well as grants each credit either for BPCS and SIS?
    Though these were defined as IPLs.
    I’ll be perfect if you would mention the clause as well.
    BR
    Taek
Understanding High Integrity Pressure Protection Systems (HIPPS)
SIS System Testing – Safety PLC
Reliability of a Control System
Emergency Shutdown Valve : Advantages
Voting Logic in Safety Instrumented System (SIS)
SIS Software Simulation – Safety Instrumented System
SIS Design – Safety Instrumented System
Proof Testing of Safety Instrumented Systems
trip solenoid installed on a control valve appears
SIS Final Control Elements
Component De-rating
Component De-rating in Control Systems
SIS Failures and Reliability - Safety Instrumented Systems
SIS Failures and Reliability – Safety Instrumented Systems
Burner Management System (BMS) Principle
What is Burner Management System (BMS)?
Intrinsic Safe Calculation
purge air blower
SIS – Safety Instrumented System Example
pressurized water reactor
SIS Example : Nuclear Reactor Controls
Functional Safety Engineering
SIS Safety Requirements
Single-Phase Full Wave AC-DC Converter Questions
ESD System Insights
ESD System Insights: Signals for Emergency Valve Shutdown Explained
Measure Capacitance using Multimeter
How to Measure capacitance using Multimeter
What is Electrical Busbar
What is Electrical Busbar? Types, Advantages, Disadvantages
Start Stop of one Motor from same Push button PLC program
TIA Portal Options
How to Troubleshoot Siemens PLC Programs?
Pressure Measurement
How to Measure Pressure in Inches of Water Column
Flowmeter Characteristics
Flow Meter Characteristics
