Reading: Selection Criteria of pH Analyzers
Inst Tools > Blog > Analyzers > Selection Criteria of pH Analyzers
In this article, you will learn some important specifications and selection criteria of pH analyzers that are considered before purchasing.
Last updated: September 28, 2022 2:10 pm
Gaurav Lunagariya
Analyzers Instrumentation Design
A pH analyzer is a measuring instrument that measures acidity and alkalinity. The pH sensor measures the difference in potential of a pH electrode and a reference electrode.
Selection Criteria of pH Analyzers Electrode AssemblyMeasuring ElectrodeReference ElectrodeTemperature SensorInterconnecting CablespH TransmitterAccessoriesNameplateInspection
In the chemical plant, Parma, and water treatment industries, pH is a crucial parameter that measures the chemical conditions of process material.
In this article, we are going to discuss some important specifications of pH analyzer that are to be considered before purchasing or technical bid analysis.
Selection Criteria of PH Analyzer
 Electrode Assembly
The electrode assembly should flow through / Immersion assembly type with the retractable arrangement, complete electrode assembly shall be weatherproof and water tight to IP – 65.
It consists of combining a pH electrode with a glass electrode, reference electrode, and Temperature sensor.
Measuring Electrode
The pH electrode is a glass membrane type with an asymmetric, potential drift of less than ± 0.05 pH unit per week.
The electrode should be shockproof and screened with metal foil.
Reference Electrode
The reference electrode ought to be the diffusion type (non-flowing) and the diffusion shall take place without the need for external pressure.
The electrode should be linear with respect to temperature changes. The electrode should be silver – silver chloride and the diaphragm for contact with the process medium shall be ceramic or porous PTFE.
The reference liquid is KCL.
Temperature Sensor
Automatic Temperature Compensation for the changes of temperature coefficients of the electrodes shall be provided with an electrode with a Pt 100 or Pt 1000 Temperature sensor.
The interconnecting cables between the electrode and the pH transmitter must be screened with anti-noise sheaths. The length is as per standard and it should be around 10 meters.
pH Transmitter
The transmitter should be the smart type with HART/FF protocol. The supplier shall guarantee that the instrument can operate safely at ambient temperatures which are up to 65 °C.
All electronics including terminal compartment and local indicator shall be weatherproof, IP – 65, and suitable for operation in a tropical climate with relative humidity up to 95 %.
The electronics need to be put in a compartment separate from wiring terminals. The terminals could be vibration-proof and suitable for 1.5 mm2 wires.
The cable entry shall be 1/2” NPT (F). All transmitters’ enclosures shall be minimum weatherproof to IP – 65.
Accessories
Complete mounting accessories of suitable material to be mounted on each sensor and transmitter.
Flow through type assembly, Tee type 1 ” Flanged connection and 1/2″ NPT (F) Sensor connection with CPVC material should be provided.
Nameplate
Each Transmitter should have a nameplate attached firmly to it at a visible place, furnishing the following information.
  • Instrument Tag Number
  • Manufacturer’s Name
  • Model Number
  • Serial number
  • Calibrated Range
  • Output mA
Inspection
Following Inspection should be carried out at vendors’ workshops or at standard calibration LAB.
  • Visual & Dimensional check
  • Calibration check
  • Test certificate
  • Accuracy, Linearity, Repeatability.
The above-mentioned specifications are basic and essential in order to finalize the pH analyzer.
  • CEMS Principle
  • Sox Nox Analyzer
  • Oxygen Gas Measurement
  • Ionization chamber Principle
  • Sensors in Water Treatment Plant
Flow Instruments – Selection, Principle & Application
Relay Loop Back Circuit
Instrumentation Cable trays Installation in vertical orientation
Analytical Standards
NDIR Gas Analyser Working Principle
Response Time Test of RTD and Thermocouple
Tagging Philosophy for Junction Box, Cable, and Cable Drum
Technologies for Oxygen Gas Measurement
Difference between Axial and Radial Diaphragm Seal Connection?
Cable Routing
Transmitter Minimum Span, Accuracy & Turndown
What is a Mimic Panel ?
Instruments Tapping Points
Oxygen Measurement using Tunable Diode Laser System
Tunable Diode Laser Analyzer Working Principle
pH Analyzer Calibration and Troubleshooting
Troubleshooting pH Analyzer Common Problems
History of 3-15 psi, 10-50 mA, and 4-20 mA signals
DCS ESD Logic Overview Graphic Display
Automation System Process Functionalities
Thermowell Problems
Thermowell Problems
Instrument Air (IA) System
Tomography Objective Questions
Safety PLC Coding Practices
Safety PLC Coding Practices – Programming Recommendations
Applications of Digital Control Valves
Digital Control Valves – Introduction, Principle, Setup, Applications
Chemical Sensors Objective Questions
PLC Program for Automatic Bottle Rejection System
Closed Tank Application
Zero Elevation and Zero Suppression in Level Measurement
Formula of 2 Wire RTD, 3 Wire RTD & 4 Wire RTD
