Reading: Scale and Normalize Instructions in PLC
Inst Tools > Blog > PLC Tutorials > Scale and Normalize Instructions in PLC
Last updated: March 4, 2021 3:17 pm
Scale Instruction
SCALE_X scales the normalized real parameter VALUE where ( 0.0 <= VALUE <= 1.0 ) in the data type and value range specified by the MIN and MAX parameters:
Scale InstructionNormalize InstructionPLC ladder program explanationPLC Ladder Programming
OUT = VALUE ( MAX – MIN ) + MIN
For SCALE_X, parameters MIN, MAX, and OUT must be the same data type. NORM_X normalizes the parameter VALUE inside the value range specified by the MIN and MAX parameters:
OUT = ( VALUE – MIN ) / ( MAX – MIN ), where ( 0.0 <= OUT <= 1.0 )
For NORM_X, parameters MIN, VALUE, and MAX must be the same data type.
Note: SCALE_X parameter VALUE should be restricted to ( 0.0 <= VALUE <= 1.0 )
If parameter VALUE is less than 0.0 or greater than 1.0:
The linear scaling operation can produce OUT values that are less than the parameter MIN value or above the parameter MAX value for OUT values that fit within the value range of the OUT data type. SCALE_X execution sets ENO = TRUE for these cases.
It is possible to generate scaled numbers that are not within the range of the OUT data type. For these cases, the parameter OUT value is set to an intermediate value equal to the least-significant portion of the scaled real number prior to final conversion to the OUT data type. SCALE_X execution sets ENO = FALSE in this case.
If parameter VALUE is less than MIN or greater than MAX, the linear scaling operation can produce normalized OUT values that are less than 0.0 or greater than 1.0. NORM_X execution sets ENO = TRUE in this case.
NORM_X and SCALE_X instructions. Explain the instructions with example.
How to use Scale and Normalize Instructions in PLC
General NORM_X and SCALE_X instructions are used for scaling the value or we can use this instruction in analog value scaling.
By using NORM_X instruction we can normalize the actual value in leaner scale within the value range.
For example, here the input value is 0 to 27648 and this value needs to be normalized in linear scaled value range from 0.0 to 1.0.
After this normalization of the value we can use this output as input value of the SCALE_X instruction. This instruction maps the value in required range (here 0 to 100). This instructions generally used in Siemens S7-1200 PLC.
List of Inputs/Outputs
  • Register A :- For analog value (0 to 27648).
  • Register B :- Out of NORM_X
  • Register C :- Output value of SCALE_X instruction.
NETWORK 1 :-
Norm X Instruction
Here define MIN value and MAX value of the actual input.
For example if analog sensor is connected in the analog channel, MIN value is 0 and MAX value is 27648.
The instruction will scale the actual input value into normalized value (0.0 to 1.0).
NETWORK 2 :-
Scale X Instruction
Here SCALE_X instruction is used. After normalization of the actual value, we can convert it into desired value range (0 to 100).
For example purpose, we have taken here 0 to 100 range but we can take other value also.
Note :- Above application may be different from actual application. This example is only for explanation and educational purpose only. We can implement this logic in other PLC also. This is the simple concept of NORM_X and SCALE_X, we can use this concept in other examples also.
All parameters and graphical representations considered in this example are for explanation purpose only, parameters or representation may be different in actual applications. Also all interlocks are not considered in the application.
Siemens Comparator Logic
How scaling works in PLC ?
Motor Logic with Push buttons
Basics of Interlocking in PLC
Ladder Logic with Timers
PLC Example on Manufacturing Line Assembly
OFF Delay Timer using PLC
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
Basics of Industrial Communication Networks
Evaluating Industrial Automation Projects Return on investment (ROI)
Developing PLC Logic for Water Pumping and Chemical Addition
How to Add Security in InTouch SCADA?
Glass Cutting and Polishing Machine: PLC Automation Solution
Difference Between FC and FB in Tia Portal
Unknown Do’s Need to Know as a PLC Programmer
PLC Program for Controlling Sequence of Conveyors with Interlock
Omron PLC real-time clock street lighting program
Automatic Highway Lights Program using RTC in Omron PLC
Difference Between PLC and RTU
Difference Between PLC and RTU?
Delete Siemens CPU Memory
Batch Mixing with PLC Ladder Logic Program
PLC Memory Organization - Data Files and Program Files
PLC Memory Organization – Data Files and Program Files
Standard Colors in PLC Automation Systems
Types of Scan Time in a PLC
Programmable Logic Controller (PLC) Scan Time – Types, Theory
PLC Motor Control Ladder Logic
PLC Program for Star Delta Motor Starter
control of temperature in a vessel
How to Analyze PID Controller Actions
PLC based Door Open and Closing System
Why do Teenagers want to be Entrepreneurs
Why do Teenagers want to be Entrepreneurs?
Relay ladder diagram example
How to Draw a Schematic Diagram ?
AI AO DI DO Signals
What are AI, AO, DI, and DO? – Definition, Examples, Purpose
Industrial Automation Systems
Remote Functions in Industrial Control Systems (ICS)
PLC Latching circuit Animation
What is Seal-in Circuit ?
