Reading: SCADA Engineer Job Responsibilities and Skills
Inst Tools > Blog > PLC Tutorials > SCADA Engineer Job Responsibilities and Skills
In this blog, you will learn the job responsibilities of a SCADA engineer and the required skills for an PLC automation engineer.
Last updated: January 5, 2024 3:24 pm
6 Min Read
SCADA EngineerPLC Automation Engineer SkillsSCADA Engineer Job Responsibilities
SCADA Engineer
When it comes to industrial automation, one of the most promising technologies used in it is a SCADA system. It is a graphical display system where the user can control a process, generate reports, manage database systems, and communicate with other systems on a vast network. It requires a very good knowledge of colors, schematics, design overview, networking, and scripting.
When engineers apply for working in this system, they must know in hand what work they will do mostly. This is because SCADA system is vast and has diverse areas of work. So, in this post, we will see the job responsibilities of a SCADA engineer.
SCADA Engineer
The skills required for a SCADA engineer as mentioned below.
  1. SCADA engineers must have a very good knowledge in MS office tools. This is because SCADA programming is repetitive and using shortcuts in MS office reduces coding work to a great extent. Also, most of the database tools nowadays collaborate directly with MS office tools and this becomes a handy knowledge.
  2. SCADA engineers must be familiar with SCADA systems first of all. Freshers are not a concern; but for experienced people, they must have a in-deep knowledge and must be hands on in at-least one SCADA system.
  3. They must also know PLC programming properly. This is an additional benefit, because you can troubleshoot communication issues between PLC and SCADA and also identify why the values are not coming properly in SCADA through PLC.
  4. SCADA engineers must have a good command over networking. Basically, SCADA systems communicate with multiple devices over a complex network and he must be familiar with various protocols like Ethernet, Modbus and also be able to identify issues in PC network settings and other similar things.
  5. SCADA engineers must have good coding skills in languages like C, C++, Java, Visual Basic and Python. This is because SCADA mostly uses scripts in it for programming.
  6. This is optional, but will be beneficial if the SCADA engineer has knowledge in ERP, MES and IoT. These are the fourth-generation automation tools and work on a very high level than SCADA. SCADA systems are integrated with it nowadays for a robust plant operation.
  7. Lastly, SCADA engineers must be hands on with database management tools like SQL server, Microsoft Access etc. This is because SCADA will work with database on mostly all of the occasions and you must know how to write queries in it for extracting as well as dumping data.
The job responsibilities of a PLC SCADA engineer are mentioned below.
  1. SCADA engineer will be responsible for the maintenance and operations of SCADA systems in a plant. Basically, every plant is divided into many segments and each segment will have multiple SCADA systems. So mostly, he will have to look only that segment and not the whole plant, which is not possible practically for a mid-level engineer. Managers in this profile can do such vast roles.
  2. SCADA engineers will ensure that all the security network protocols are running properly from time to time. In that sense, they must be easily able to configure servers, networks and other such equipment.
  3. SCADA engineers must help in business development by giving necessary technical suggestions to sales team and communicate about new technologies in SCADA. If they are able to design a SCADA product such as a report tool or other such type, then it greatly helps in marketing and business growth.
  4. SCADA engineers must help in reading technical brochures and standards, before buying a SCADA software from vendor. Understanding specifications helps in a great way in this regard.
  5. SCADA engineers must be able to efficiently develop SCADA screens, program database tools, develop reports, and setup computer networks. If he is individually able to design the whole SCADA system, then it is a very great advantage.
  6. SCADA engineers must maintain all license and support contract documentation. This helps in maintaining all commercial liabilities and assets in SCADA system properly.
  • HMI Screen Design Applications
  • How to Find Best PLC for Your Project
  • Calling a Function Block in a PLC System
  • Siemens Communication with I-Device
  • PLC Programming Projects for Beginners
PLC Commissioning and Testing Procedure (Programmable Logic Controller)
How to Create New Project Using Simatic Manager
Siemens TIA Portal Elevator System with Safety Features
Developing PLC Logic for Water Pumping and Chemical Addition
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
Tutorial: Siemens Communication between PLCs using I-Device
Electrical Earthing Calculations
How to Communicate with Excel from RsLinx?
Create a User-Defined Function Block in Codesys
How to Communicate with Excel from Intouch SCADA?
PLC Light Sequence Control using Bit Shift Registers
PLC Motor Operation based on Time Cycle Sequence – Program
Parking Garage Indicator PLC Automation
Parking Garage Indicator: PLC Automation System
How PLC controls a ON-OFF Valve
PLC Valve Control Ladder Logic Programming
Example of Automated Guided Vehicle with PLC
PLC Timers with Practical Examples
Omron PLC Timer Example Explained
PLC Programming for Sequential Batch Mixing System
memory types in siemens plc
#13 PLC Best Practices – Disable Unused Communication Ports
Control Algorithms in PLC Programming
PLC Program for Positive edge pulse output for one scan cycle
PLC Program for Positive Edge Pulse Output for One Scan Cycle
Infrared Open Path Gas Detectors Operation
Infrared Open Path Gas Detectors Working Principle
Operation of Chromatography Questions & Answers
Basics of Trips, Interlocks, Permissives & Sequences
Full Wave Rectifier
Full Wave Rectifier
Difference between Globe Valve and Gate Valve
Difference between Globe Valve and Gate Valve ?
3φ AC Power Connections
Three Phase Systems
Full Wave Rectifiers Objective Questions and Answers
