Reading: Communication between Wincc and Tia Portal
Inst Tools > Blog > PLC Tutorials > Communication between Wincc and Tia Portal
Last updated: March 4, 2021 12:15 pm
3 Min Read
This article is about communication between WinCC and TIA portal using simple programming examples and screenshots.
Step 1:
Open TIA PORTAL. Create a new project. Configure the devices and open programming environment.
Step 2:
The same way, create a new project in HMI. I already created an article on it. Read the article before proceed here.
Step 3:
From the above two steps, we created new projects in Tia Portal and WinCC.
After creating new projects, let’s move to establish communication between them.
As shown in the below window click on option “HMI” and expand it. Double click on “device configuration”.
Step 4:
Click on “network view”. Here, you can see PLC is added to the network as we already have configured while creating a new project.
Make sure that you select CPU and HMI have which contains the same port for communication. Here, I have select HMI and CPU which have the same PROFINET port in common.
Network View in Tia Portal
Step 5:
Now as shown in the below window select Profinet port in green color and drag that to the same port of HMI. Doing that will create a network.
PLC and HMI Communicate
Step 6:
Now to check communication established properly select any one HMI or PLC and do right click on it to open the selection menu as shown in the below window.
Click on “compile” and select “hardware rebuild all”.
Compile Project in Tia Portal
Step 7:
You are done with communication. To check IP address select “HMI” as shown in the below window. Click on “device view”.
Tia Portal Device View
Step 8:
Following window will pop-up. Click on green color Profinet port. In the “general” section, select the “Profinet interface” where you can find an IP address and you can make changes with your application.
Tia Portal IP Protocol
Step 9:
Do follow the same procedure for CPU to check an IP address.
Author: Suhel Patel
  • Field instrument to Control System
  • What is SCADA System?
  • Siemens CPU Status & Errors
  • Quiz Questions on Motors
  • Siemens PLC Memory
Functional Block Diagram PLC Example for Traffic Light System
Siemens PLC programming: BCD, Integer, Double Integer, Real
Which Connection is Best for PLC? – Sinking or Sourcing
PLC to PLC Communication using S7 Connection PUT & GET Instructions
From Boolean Algebra to PLC Logic
LIFO Instruction in PLC
DeMorgan’s Theorems using Ladder Diagram
Single Loop Controller Questions
How to Simplify PLC Coding Using Karnaugh Maps?
Forcing and Modifying PLC Logic
Does Really a Safety Barrier is Important? – PLC DCS Systems
DC Injection Braking in VFD
Run 4 Motors Sequentially from Same Push button PLC Program
On Delay Timer using PLC
ON Delay Timer using PLC
Configure Analog Inputs and Outputs in Delta PLC
Difference between PLC and Computers
Analog Input Card Resolution Effects on Accuracy
PLC Analog Input Card Resolution Effects on Accuracy
PLC Program for Counting Objects on Conveyor
PLC Program for Counting Moving Objects on Conveyor
PLC Programming in Bottle Filling Process
Applications of PLC Programming in Bottle Filling Process
SCL Language in Siemens Tia Portal
PLC Program Paint Spraying
PLC Program for Paint Spraying
IP Ratings and Equivalent NEMA Ratings
Furnace Draft Control System
Location of Pressure Taps
Design Considerations of Orifice Plate
Differences between Watts and Volt Amps
Thermal Protection Relay Testing and Commissioning
Testing of Thermal Protection Relay for Motors
PLC Programming Example on LED Control
Safety interlock for motor starters in Siemens PLC
Motor Starter Logic using Siemens PLC Tia Portal
