Reading: R R-C Firing Circuits Disadvantages
Inst Tools > Blog > Power Electronics > R R-C Firing Circuits Disadvantages
Last updated: September 19, 2016 3:58 am
Power Electronics
2 Min Read
Firing Circuits:
Gate triggering is the most commonly used turn-on method employed to switch on the thyristors. Triggering circuits is also called firing circuits. There are various firing circuits available. R-Firing circuits is simple but suffer from limited firing circuits. Firing angle is limited between 0o to 90o.
In actual practice firing angle can be varied between 3o to 90o. Limitation of the firing angle range of R-Firing circuit is eliminated by introducing a capacitor and a diode. Thus R-C firing circuits can increase the firing angle limitation range. Theoretically firing angle can be varied from 0o to 180o. However due to low voltage at 0o and 180o thyristor cannot be turn-on. Hence practically the range of firing angle is between 3o and 177o.
Both R and R-C firing circuits suffer from following disadvantage:
  • They can be employed in power circuits having only one thyristor
  • They are capable of open loop control only
  • Due to lower voltages near 0o to 180o, gate current is small. Especially in R-C firing circuit, near 180o gate current is minimum due to maximum value of R. This will increase the turn on time, especially for R-L load, leading to higher turn on loss
  • Higher frequency gate signal is desirable for reliable turn on. Both the circuits are not capable of providing the same
  • There is no electrical isolation between control circuit and power circuit
However the circuits are simple and cheap. R-C firing circuits is widely used in low power thyristor controllers, such as solid state ac regulators for speed control of fans and blowers. R-C firing circuits can also acts as snubber circuits
Thyristors – Switching, Two Transistor Model, Advantage, Applications
Power Diode – Characteristics, Construction, Working, Advantages
Power Transistor – Structure, Biasing, Characteristics, Advantages
Types of IGBT
Basics of Thyristor
How to test SCR using Multimeter
Introduction to Thyristor – History, Types, Principle, Advantages
Power Electronics – Phase Controlled Half Wave Rectifier RL Load
Turning Off SCR – Commutation
Thyristor Protection Circuits (SCR) – Types, Principle, Explanation
Power Electronic Devices Specification and Classification
SCR Triggering Methods
MCT (MOS Controlled Thyristor) – Symbol, Working, Characteristics, Advantages
SCR Switching Characteristics
Power MOSFET Symbols
Power MOSFET – Symbol, Types, Working, Characteristics, Advantages
Procedure to test the TRIAC
How to Test TRIAC with Multimeter
SCR Class B Resonant-Pulse Commutation
Thyristor Commutation Techniques – Types, Working Principles
Basic components of power electronics
What is Power Electronics? Evolution, Block Diagram, Advantages
IGBT Switching Characteristics
IGBT – Symbol, Construction, Working, Characteristics, Advantages
RC snubber circuits
How Snubber Circuit works ?
Single Phase Half-controlled Rectifier RL Load With FD
Phase-Controlled Half-Wave Rectifier With Freewheeling Diode
Resistance Temperature Detectors Troubleshooting Tips
Vibration Sensor
Vibration Probes Questions and Answers
NEMA to IP Ratings
NEMA Enclosure Types Standards
Rotary Encoder
Rotary Encoder Interview Questions and Answers
Immersion Electrical Heaters
Single and Three Phase Immersion Electrical Heaters Wiring Circuits
Digital Logic Gates TruthTables
Logic Gates
Dahlander Motor
Dahlander Motors – Principle, Advantages, Disadvantages
Infrared Temperature Calibrators
Different Types of Temperature Calibrators
