Reading: Questions on DP Transmitter Wet Leg Compensating Impulse Line
Inst Tools > Blog > Practical Questions > Questions on DP Transmitter Wet Leg Compensating Impulse Line
Calculate the appropriate LRV and URV pressures for the DP Transmitter with Wet Leg Compensating Impulse Line.
Last updated: January 19, 2021 8:44 pm
Practical Questions
3 Comments
2 Min Read
Calculate the appropriate LRV and URV pressures for this hydrostatic level measurement system.
Assuming the process liquid has a weight density of 44 pounds per cubic foot at a temperature of 23 degrees Celsius, and that the “wet leg” compensating impulse line is filled with a glycerin/water mix (S.G. = 1.13).
Assume a static vessel pressure of 126 PSI:
Question 1:
Express your answers in units of inches water column (”W.C. or ”H2O).
Answer:
LRV = +173.7 ”H2O
URV = +94.76 ”H2O
The temperature and static pressure values are extraneous information, included for the purpose of challenging students to identify whether or not information is relevant to solving a particular problem.
Question 2:
As liquid level increases in this vessel, will the transmitter’s signal increase or decrease (i.e. is this level transmitter direct or reverse acting?
Question 3:
If the process liquid heats up and becomes less dense (but the actual level remains the same), will the transmitter’s 4-20 mA signal increase, decrease, or remain the same?
Question 4:
If the wet leg is filled with pure glycerin instead of a glycerin/water mixture (but the process liquid level remains the same), will the transmitter’s 4-20 mA signal increase, decrease, or remain the same?
Question 5:
How would this system respond if someone closed the upper nozzle block valve, isolating the compensating leg impulse line from the process vessel?
Question 6:
Describe a step-by-step procedure for re-filling the wet leg with glycerin, assuming a pressurized vessel.
Do you find any mistake in these questions?
Share with us through below comments section.
  • Transmitters Compensated Leg Systems
  • Level Measurement with Wet leg
  • Density Measurement using DP Transmitter
  • Rate Compensated Heat Detectors Working Principle
  • Closed tank DP Level Transmitter Calibration
Credits: Tony Kuphaldt
Problem on Tachogenerator
Identify Solenoid Valves Energized or de-energized?
Which Instrument is at Fault in this System?
Level Measurement Lab Exercise
Something is Wrong with Strain Gauge Bridge Circuit
Draw Wiring of a Pressure Switch to control two lamps
3 Comments
  • hayder azeez says:
    January 19, 2021 at 10:42 pm
    Answer2: decrease
    Answer3:remain the same
    Answer4:remain the same
    Answer5: signal is stay constant with last case before close nozzle
    Answer6:
    The column will be affected by the pressure of the tank, whether it is an increase or decrease, and thus the reading of the transmitter will change if there is a change in the liquid level
    All that by imposing a closed air pressure equalization valve
    -I hope I understand the questions well
    best regards
  • Ahmed says:
    January 27, 2021 at 7:25 pm
    How possible the low side of the DP be connected to the bottom of the Process VESSEL.
    Answer for URV and LRV for the above question is not correct , I’ve got (LRV = -206.79” H2O, URV= -128.79 )
    Formula I used
    LRV= Lmin * SGp – (H1+H2) * SGf
    URV= Lmax* SGp – (H1+H2) * SGf
  • Avi dadon says:
    June 30, 2022 at 7:56 pm
    Answer 1: URV = +94.76 ”H2O , LRV = +173.7 ”H2O
    Answer 2: As liquid level increases in this vessel, the transmitter’s signal
    increases.
    Answer 3: If the process liquid heats up and becomes less dense (but the actual
    level remains the same),the differential pressure increase there by the
    transmitter’s 4-20 mA signal decrease.
    Answer 4: If the wet leg is filled with pure glycerin (s.g=1.26) instead of a
    glycerin/water mixture (s.g=1.13) (but the process liquid level remains
    Answer 5: If the static pressure (vapor pressure) in the vessel will not change the
    readings before closing the valve will remain the same.
    If the static pressure increase (above 126 psi) then the differential
    pressure will decrease and there for the transmitter reading will increase
    (there by level readings will increase also).
    If the static pressure decrease (less then 126 psi) then the differential
    pressure will increase and there for the transmitter reading will decrease
    (there by level readings will decrease also).
    Answer 6: procedure for re-filling the wet leg with glycerin:
    step 0: make sure bypass valve on the transmitter manifold is closed (not
    drawn).
    step 1: isolate the pulse piping from the vessel by closing the upper
    nozzle block valve and the transmitter high side valve (to protect
    the transmitter diaphragm from over pressure when filling up
    with glycerin pump)
    step 2: open the pulse pipe vent valve (upper) to the atmosphere pressure.
    step 3: open the pulse pipe drain valve (lower) to atmosphere pressure
    to drain what ever is on the wet leg (to a container or to a drain
    ditch or according to local draining protocols & not on the
    floor).
    step 4: connect the glycerin filling pump to the drain side.
    step 5: start the pump and fill the wet leg with glycerin until it reaches
    the vent.
    step 6: quickly close the drain valve.
    step 7: stop and disconnect the glycerin filling pump.
    step 8: close the vent valve.
    step 9: open the transmitter high side valve.
    step 10: open the upper nozzle block valve.
    I hope i got all the answers right :).
Identify High Flow Alarm and Low Flow Alarm?
Questions on Pneumatic Control Loop
How Manometer Measures Differential Pressure for Different Fluids?
Galileo Thermometer
Draw Limit Switch Symbol ?
Float-type Level Switch for Sensing Low Oil Level
Calculate Temperature of RTD
Is it Possible to Measure liquid-liquid Level Interface using Float
Is it Possible to Measure Liquid-Liquid Level Interface using Float?
Resistance Temperature Detector (RTD) Questions
Resistance Temperature Detector (RTD) Questions – 1
Ladder Diagram circuit
PLC Practice Questions
Pneumatic Moment-balance Differential Pressure Transmitter
pressure transmitter calibration setup
Questions on Pressure Transmitter Calibration Setup
PLC Program
Example PLC Program
Siemens PLC Block Diagram
Programmable Logic Controller (PLC) Questions and Answers – 14
Calculate LRV and URV for 4-20 mA Loop-powered DP Transmitter
Weighing Balance Calibration
Calibration Procedure of Weighing Balance and Common Mistakes
Basics of FOUNDATION Fieldbus
Difference between Fieldbus, Profibus and HART Protocols
Structured Control Language (SCL) Elements
Value Assignments in SCL Language – Single, Multiple, Combined
Digital Control Systems
The inverse z-transform & Response of Linear Discrete Systems
Difference between HART and Foundation Fieldbus
Control Valve Failure Rate Calculation
diode-limiter-principle
Diode Limiters/Clippers Operation
Two-Conveyor PLC Control System
Basic Conveyor System for Product Handling in Omron PLC
