Reading: How to Protect Siemens PLC using Password?
Inst Tools > Blog > PLC Tutorials > How to Protect Siemens PLC using Password?
Last updated: March 4, 2021 12:54 pm
2 Min Read
Every industry uses PLC’s to measure and control different process parameters in the plant. PLC configuration and programming access will be limited to a few engineers in the plant.
If an unauthorized person with less knowledge over PLC’s get access to the system and unknowingly may damage or creates problems with the healthy logics.
So, it is best practice to protect PLC by using a password. We know that we can upload and download the program from and to PLC.
We can password protect both the downloading and uploading, so a person with authentication can only work with plc programming.
Below I have explained the method to protect plc using the password.
To create a password, follow the below steps,
  1. Select PLC and right-click on it.
  2. Click on “Properties”.
3. A new window will appear, as shown in the below figure.
Siemens PLC Write Protection
4. Here we will get two options, listed below.
  1. Write protection and
  2. Write/read protection.
5. In Write protection, we can create password protection while downloading the program to PLC.
While downloading the program, it will ask for a password and a person with authentication can only use it.
Siemens PLC Password
6. Another option, write/read protection, by using this option we can password protect for both uploading and downloading of the program from PLC to PC and vice-versa.
Author: Suhel Patel
  • Problem on PLC, VFD, Motor
  • Connect to the Siemens S7 PLC
  • Cyber Attacks on PLC
  • Retentive ON Delay Timer
  • PLC Gate Array Logic
Auto and Manual Liquid Tank System: PLC Program Example
PLC Program for Password Management using Structured Text
Door Lock with Delay PLC Exercise Problems
PLC Output Types
Siemens PLC Organization Blocks (OB)
What is Trace Function in Tia Portal?
Your First Steps Through STL Language
What is Contextual HMI? – HMI Screens on a Mobile or Tablet
What is Profinet and How to Configure in Siemens PLC?
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
Create an Application in HMI using Tia Portal
Tanks Draining Control in PLC using Functional Block Diagram
how-a-4-20ma-transmitter-works
How a 4-20mA Transmitter Works?
WHILE DO Statement in SCL Language
Control Methods in Servo Motor Drives
Various Control Methods in Servo Motor Drives
LIFO Instruction in Allen Bradley PLC Programming
LIFO Instruction in PLC
Master Control Reset (MCR) ladder logic
How to use Master Control Reset (MCR) Instruction in PLC
PLC based Door Open and Closing System
LCS Configuration equipped with LOTO Facility
Ziegler-Nichols closed-loop Tuning
Ziegler-Nichols Closed-Loop Method (Ultimate Gain)
Steam Pressure Control
Non‐contact RADAR Level Transmitter Pulse
Non Contact RADAR Level Transmitter Principle, Limitations, Design, Installation and Calibration
Current to Voltage Conversion Circuit
How to Convert Current to Voltage using Resistor ?
Power Systems MCQ Series 5
Mechanical Temperature Indicators (MTI) Problem
PLC Program for Burglar Alarm Security System
PLC Program for Alarm Security System
Flow Transmitter Output Current Calculation
Calculate Flow Transmitter Output Current
