Reading: PLC Application for Stamping Operation – Example Programming
Inst Tools > Blog > PLC Tutorials > PLC Application for Stamping Operation – Example Programming
This is Programmable Logic Control (PLC) Application for PLC Stamping Operation. Write a PLC program for this process.
Last updated: November 3, 2023 2:34 pm
PLC Stamping OperationProblem DiagramProblem SolutionInputs & Outputs ListPLC Program to Operate Stamping of PartsProgram Description
Problem Description
When part is placed on conveyor at position 1, and when cycle start button is pressed it moves to position 2. After reaching at position 2 it will stop for stamping process.
After stamping process part will go at position 3 and from here it will be taken away from conveyor manually.
Write PLC program for this process using ladder diagram language.
Problem Diagram
Problem Solution
In this system, we will use S7-300 PLC and TIA portal software for programming.
Here consider one conveyor system that will move the part from one position to another position.
Three limit switches are used to sense the position of the part on the conveyor. For position 1, 2, and 3 as shown as LS1, LS2, and LS3 respectively.
A reversible motor is used for UP_motor coil for reverse direction and DN_coil for forward direction.
LSDN and LSUP limits switches are used to detect the stamper arm down and up position.
Inputs List
  • START PB :- I0.0
  • STOP PB :- I0.1
  • Limit switch for position 1 :- I0.2
  • Limit switch for position 2 :- I0.3
  • Limit switch for position 3 :- I0.4
  • Limit switch to detect upper position :- I0.5
  • Limit switch to detect down position :- I0.6
Outputs List
  • UP_motor :- Q0.1
  • DN_motor :- Q0.2
  • Conveyor motor :- Q0.0
M memory
  • Relay coil :- M0.0
  • Relay coil 1 :- M0.1
  • Relay coil 2 :- M0.2
  • Relay coil 3 :- M0.3
  • Relay coil 4 :- M0.4
PLC Ladder Logic for Stamping Control
PLC Stamping
limit switch for position
Stamping PLC Logic
PLC Stamping Application
PLC Stamping Example
PLC Conveyor Stamping
Program Description
For this application, we used S7-300 PLC and TIA portal software for programming.
Network 1:
If LS1 (I0.2) is detected and START PB is pressed (I0.0), internal relay coil will be ON. Here cycle will start from home position and we consider here LS1 detection is home position.
Network 2:
If both LS2 (I0.3) and LS3 (I0.4) are not detected, relay coil 1 (M0.0) will be ON.
Network 3:
If LS 1 (I0.2) is not detected and START button (I0.0) is pressed, relay coil 2(M0.1) will be ON.
Network 4:
If anyone is detected from LS1 (I0.2), relay coil 2(M0.2) or relay coil 4(M0.4), relay coil 3(M0.3) will be latched.
Network 5:
If relay coil 3(M0.4) is ON and LSUP (I0.5) is not detected, the motor will start reverse (stamping arm moves upper direction).
Network 6:
Relay coil 4(M0.4) will start when LSDN (I0.6) and LS 3(I0.4) are not detected.
Network 7:
When LS 2(I0.3) is detected, the stamping process should start so the stamping arm will start to move forward (Q0.2).
Network 8:
The conveyor motor (Q0.0) will remain in ON condition if relays 1, 2, or 3 are detected.
Here consider UP motor output meaning is stamping arm moves reverse and DN motor output meaning is stamping arm moves forward.
Relay coil, 1, 2, 3, and 4 taken for logical conditions.
Note:- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of stamping of parts in industry, we can use this concept in other examples also.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications. Also all interlocks are not considered in the application.
Author: Bhavesh
  • SR Flip Flop using PLC
  • PLC D Flip Flop using PLC
  • PLC Interview Questions
  • Siemens S7 1200 PLC configuration
How to use JUMP Instruction in PLC Ladder Logic?
Safety Door Interlock PLC Program
How to Choose a PLC for New Project? – Criteria for Selection of PLC
Flood Warning System using Programmable Logic Controller
PLC Timer Programming Examples – TON, TOF, TP and TONR
Tutorial: Siemens Communication between PLCs using I-Device
PLC Program for Washing Machine
Up Counter PLC Program
EasyBuilder Pro Online Simulation of Mitsubishi FX3U PLC
PLC Math instructions
Typical HMI Screen Design for Water Treatment Plant
Draw a ladder logic to switch ON-OFF a bulb using a toggle switch
Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
PLC Handbook
PLC Handbook
PLC Programming Limit Switch
Functional Block Diagram of XNOR Logic Gate
PLC Functional Block Diagram for Logic Gates
Split Range Control Block Diagram
Split Range Control Application using PLC Ladder Logic
Allen Bradley RSLogix 500 PLC Programming
Manual sequential logic in Schneider PLC
Programming Schneider PLC Manual Sequential Machine
What is RS Linx - Types of Softwares in Rockwell Automation
What is RS Linx? Types of Software in Rockwell Automation
Difference Between Permittivity and Permeability
Control Valves Leak Tightness
Control Valves Leak Tightness Restoration Pose Difficulties
Level Instruments
Level Instruments General Specifications
Solar Arrays
Solar Photovoltaic Cells – Parts of the Solar Panel
Motor Slip Calculation
Electrical Motor Terms and Concepts
U tube Manometer Working
Basics of Pressure
Coal Hopper
Coal Based Fuel Feeding System for Boiler
Beta ratio ( β )
Important Factors in Flow Measurement
