Reading: 143 Process Control Terms and Glossary – Questions Answers
Inst Tools > Blog > Instrumentation MCQ > 143 Process Control Terms and Glossary – Questions Answers
Learn the 143 process control terms with our detailed questions and answers glossary to review your technical knowledge.
Last updated: August 31, 2024 8:10 pm
Instrumentation MCQ Process
45 Min Read
Process Control TermsWhat is a Multi-position Controller?What is Cascade Control Action?What is Ambient Pressure?What is Hysteresis?What is a Self-Operated (Regulator) Controller?What is an Error?What is Thermal Shock?What is Time Response?What is Common Mode Interference?What is Reproducibility?What is an Auctioneering Device?What is Supervisory Control Action?What is a Transducer?What is a Closed (Feedback Loop) Loop?What is Proportional Gain?What is a Reverse-Acting Controller?What is Static Gain?What is Ramp Response Time?What is a Controlling System?What is Derivative (Rate) Control Action?What is Integral (Reset) Control Action?What is Load Impedance?What is Zero Error?What is a Transmitter?What is System Deviation?What is Noise?What is Repeatability?What is the Time Constant?What is Feedforward Control Action?What is a Primary Element?What is a Frequency Response Characteristic?What is an Indirectly-Controlled Variable?What is a Signal?What is a Setpoint (Command)?What is Normal Mode Interference?What is an Input Signal?What is Shared Time Control Action?What is Deviation?What is Modulation?What is Span?What is Step Response?What is Zero Elevation?What is a Direct–Acting Controller?What is a Feedback Signal?What are Normal Operating Conditions?What is Rise Time?What is a Directly-Controlled System?What is Signal Output?What is a Summing Point?What is a Multi-Element (Multi-Variable) Control System?Process Control GlossaryWhat is a Proportional Plus Integral (Reset) (PI) Controller?What is Load Regulation?What is Reference Performance?What is Step Response Time?What is Dead Time?What is the Sampling Period?What is the Suppressed-Zero Range?What is Integral Action Rate (Reset Rate)?What is Offset?What is a Signal Transducer (Signal Converter)?What is a Lower Range-Limit?What is a Manipulated Variable?What is Loop Gain?What is Control Mode?What is Electrical Interference?What is a Controller?What is an Indirectly-Controlled System?What is Indicator Travel?What is Relative Damping?What is Drift?What is a Dead Zone?What is Closed Loop Gain?What is Power Consumption?What is a Final Controlling Element?What is Process Pressure?What is Zero Suppression?What is Resolution?What is an Open Loop?What is Electrostatic Field Interference?What is a Reference-Input Signal?What is a Proportional Plus Derivative (Rate) (PD) Controller?What is Adaptive Control Action?What is Magnetic Field Interference?What is Differential Mode Interference?What is a Directly Controlled Variable?What is Proportional Control Action?What is a Return Signal?What is a Ratio Controller?What is a Time Proportioning Controller?What is Pressure Supply?What is Transverse Interference?What is Proportional Plus Derivative (Rate) Control Action?What is an Integral (Reset) (I) Controller?What is a Sampling Controller?What is Ambient Temperature?What is a Measured Signal?What is Overrange?What is Proportional Plus Integral (Reset) Control Action?What is Settling Time?What is the Mounting Position?Process Control TerminologyWhat is Linearity?What is the Signal to Noise Ratio?What is Reference Accuracy?What are Operative Limits?What is a Span Error?What is Sensitivity?What is a Bode Diagram?What is a Proportional (P) Controller?What is Accuracy?What is Proportional Plus Integral (Reset) Plus Derivative (Rate) Control Action?What is an Error Signal?What is Dynamic Response?What is a Proportional Plus Integral (Reset) Plus Derivative (Rate) (PID) Controller?What is the Warm-Up Period?What is Process Temperature?What is High Limiting Control Action?What is a Control System?What is Low Limiting Control Action?What is Output Impedance?What is a Time Schedule Controller?What is a Process?What is a Parameter?What is Upper Range-Limit?What is Range?What is Optimizing Control Action?What are Operating Conditions?What is Dynamic Gain?What is Input Impedance?What is Direct Digital Control Action?What is Zero Shift?What is Source Impedance?What is an Element?What is Control Action?What is a Proportional Band?What is Damping?What is the Elevated-Zero Range?What is an On-off Controller?What is Longitudinal Interference?What is Feedback Control Action?What is a Non-Interacting Control System?What is Ramp Response?What is Dead Band?What is a Sensing Element?
This process control terms video provides the first 50 questions with detailed explanations.
Process Control Terms - Questions and Answers
Question 1
A. A controller with binary output
B. A controller with constant output
C. A controller without sensors input
D. A controller with multiple discrete output values
Show the Answer
Question 2
A. Control with feedback and feedforward
B. Control where one controller’s input is another’s setpoint
C. Control where one controller’s output is another’s setpoint
D. Control with multiple outputs
Show the Answer
Question 3
A. The pressure at the output
B. The internal device pressure
C. The pressure at the sensing element
D. The pressure of the medium surrounding a device
Show the Answer
Question 4
What is Hysteresis?
A. Difference between maximum and minimum output
B. Maximum difference between upscale and downscale values
C. Minimum difference between input and output
D. Error at zero input
Show the Answer
Question 5
A. A controller requiring external power
B. A controller with binary output
C. A controller using energy from the controlled system
D. A feedback-free controller
Show the Answer
Question 6
What is an Error?
A. The input signal to a controller
B. The rate of change of a variable
C. The desired value of a variable
D. The deviation between measured and true value
Show the Answer
Question 7
A. Desired temperature setpoint
B. Gradual temperature change
C. Noise in the system
D. Abrupt temperature change
Show the Answer
Question 8
A. The response to a gradual input change
B. The behavior of output over time
C. The time response to an input change
D. The desired setpoint
Show the Answer
Question 9
A. Interference between measuring circuit terminals and ground
B. Electrostatic field interference
C. Magnetic field interference
D. Interference between signal terminals
Show the Answer
Question 10
A. Performance during failure
B. Average performance over time
C. Closeness of consecutive measurements over time
D. The ability to maintain a setpoint
Show the Answer
Question 11
A. A cost analysis tool
B. A selector of extreme signals
C. A device for bidding
D. A data aggregator
Show the Answer
Question 12
A. Independent control with intermittent corrections
B. Control with external adjustments
C. Control with no feedback
D. Direct control of all loops
Show the Answer
Question 13
A. The desired setpoint
B. A device converting one form of energy to another
C. A device converting one form of energy to voltage
D. The stability of the control system
Show the Answer
Question 14
A. A signal path with external control
B. A manual control system
C. A signal path including feedback
D. A signal path without feedback
Show the Answer
Question 15
A. Minimum gain of a system
B. Gain with integral control
C. Ratio of output change to input change
D. Gain with feedback
Show the Answer
Question 16
A. A controller where output decreases with input
B. A feedback-free controller
C. A controller with binary output
D. A controller with constant output
Show the Answer
Question 17
A. Gain without feedback
B. Gain at zero frequency
C. Gain with constant input
Show the Answer
Question 18
A. The stability of the control system
B. The time of response to input change
C. The desired setpoint
D. The time interval by which an output lags an input
Show the Answer
Question 19
A. A system with fixed output
B. A system with no feedback
C. A system for manual adjustments
D. A system for deliberate manipulation of variables
Show the Answer
Question 20
A. Control based on cumulative error
B. Control based on current error
C. Control based on rate of change of error
D. Control based on absolute value
Show the Answer
Question 21
A. Control ignoring past errors
C. Control predicting future error
D. Control based on cumulative error
Show the Answer
Question 22
A. Impedance presented by the source
B. Impedance presented to the output
C. Impedance of the signal
D. Impedance of the input device
Show the Answer
Question 23
What is Zero Error?
A. Error at any point
B. Error due to drift
C. Error at the upper range value
D. Error at the zero point
Show the Answer
Question 24
B. A device converting signals
C. A transducer responding to a measured variable
D. A device receiving signals
Show the Answer
Question 25
A. Setpoint change
B. Instantaneous value minus setpoint
C. Desired value
D. Constant output range
Show the Answer
Question 26
What is Noise?
A. Unwanted signal component
B. The desired signal component
C. The speed of response
Show the Answer
Question 27
B. Closeness of consecutive measurements under the same conditions
C. Average performance over time
Show the Answer
Question 28
A. The value T in an exponential response term
B. The stability of the control system
C. The time of response to input change
Show the Answer
Question 29
A. Control based on predicted disturbances
B. Control based on feedback
C. Control based on average values
D. Control with no adjustments
Show the Answer
Question 30
A. The system element converting measured variable energy
B. The desired setpoint
C. The final controlling element
D. The element providing feedback
Show the Answer
Question 31
A. A graph of flow rate changes
B. A plot of temperature vs. time
C. Relationship between input and output frequencies
D. A plot of amplitude and phase vs. frequency
Show the Answer
Question 32
A. A variable whose value is sensed to originate a feedback signal
C. A variable not originating a feedback signal but influenced by another
D. Noise in the system
Show the Answer
Question 33
What is a Signal?
B. Information about a variable
C. The stability of the control system
Show the Answer
Question 34
A. The actual value of the controlled variable
B. The desired value of the controlled variable
D. The deviation from the desired value
Show the Answer
Question 35
A. Common mode interference
B. Magnetic field interference
C. Interference between measuring circuit terminals
D. Electrostatic field interference
Show the Answer
Question 36
C. The signal applied to a device
Show the Answer
Question 37
A. Control based on time intervals
B. Control action divided among multiple loops
C. Control with constant monitoring
D. Control with no specific schedule
Show the Answer
Question 38
What is Deviation?
A. Maintaining setpoint
B. Constant output range
C. Any departure from desired value
D. No change in input
Show the Answer
Question 39
What is Modulation?
A. The process of varying one wave characteristic by another
B. The speed of response
D. Maintaining a fixed signal
Show the Answer
Question 40
What is Span?
A. Noise in the system
D. The algebraic difference between the upper and lower range-values
Show the Answer
Question 41
A. The time response to an instantaneous input change
C. The behavior of output over time
D. The response to a gradual input change
Show the Answer
Question 42
A. The shift of zero above the lower range value
B. The value of zero at the lower range limit
Show the Answer
Question 43
A. A controller with constant output
B. A controller with random output
C. A controller where output increases with input
D. A controller with no feedback
Show the Answer
Question 44
B. The deviation from the desired value
C. The return signal from a measurement
Show the Answer
Question 45
A. Range of conditions for normal operation
B. Conditions during device failure
Show the Answer
Question 46
What is Rise Time?
C. The time required for output to change from a specified percentage of the steady-state increment
D. The time of response to input change
Show the Answer
Question 47
A. A system with manual adjustments
C. The system directly guided by the final controlling element
D. A feedback-free system
Show the Answer
Question 48
C. The deviation from the desired value
D. The signal delivered by a device
Show the Answer
Question 49
A. The point where signals are added algebraically
Show the Answer
Question 50
A. A system using multiple process variables
B. A fixed-variable system
C. A single-loop control system
D. A system with one input
Show the Answer
This process control glossary video provides the next 50 questions with detailed explanations.
Process Control Glossary - Questions and Answers
Question 51
A. A controller with derivative action only
B. A controller combining proportional and integral actions
C. A controller with constant output
D. A controller with no integral action
Show the Answer
Question 52
A. The change in output from no-load to full-load
C. The ability to maintain a setpoint
Show the Answer
Question 53
A. Average performance over time
B. Performance during failure
C. Performance under varying conditions
D. Performance under reference conditions
Show the Answer
Question 54
C. The time required for an output to change from an initial value to a large specified percentage of the final steady-state value
Show the Answer
Question 55
What is Dead Time?
A. The interval between input change and response
Show the Answer
Question 56
A. The speed of response
C. The continuous observation interval
D. The time interval between observations
Show the Answer
Question 57
A. A fixed value range
B. A range with zero below the lower range-value
C. A range with zero at the midpoint
D. A range with zero at the upper limit
Show the Answer
Question 58
A. Speed of proportional response
B. Rate of change of the output signal
C. Rate of change of the input signal
D. Ratio of integral response to proportional response
Show the Answer
Question 59
What is Offset?
B. The steady-state deviation from setpoint
Show the Answer
Question 60
A. A device converting one form of energy to another
Show the Answer
Question 61
A. The lowest quantity measurable
C. The midpoint of the range
D. The highest quantity measurable
Show the Answer
Question 62
A. A fixed characteristic of the system
B. Noise in the system
D. A quantity varied to change the controlled variable
Show the Answer
Question 63
What is Loop Gain?
B. Gain with constant input
C. Ratio of output to error signal
D. Gain of the open loop
Show the Answer
Question 64
A. A random control method
B. A fixed control output
C. A specific control strategy
Show the Answer
Question 65
A. Desired signal component
B. Stable output signal
C. External voltage or current affecting circuits
D. Internal noise of a device
Show the Answer
Question 66
A. A manual adjustment tool
B. An automatic device regulating a variable
C. A feedback-free device
D. A fixed-output device
Show the Answer
Question 67
A. The portion of the system influenced by the directly controlled variable
B. A feedback-free system
D. A system with manual adjustments
Show the Answer
Question 68
A. Movement of the control element
B. Length of the path described by the indicator
C. Distance of the output signal
D. Distance between input and output
Show the Answer
Question 69
A. Damping with no feedback
B. Absolute damping value
C. Fixed damping ratio
D. Number expressing quotient of actual to critical damping
Show the Answer
Question 70
What is Drift?
A. Change in output-input relationship over time
B. Stable output over time
C. Sudden output change
D. Constant input
Show the Answer
Question 71
B. The range through which an input change causes no response
C. The range with maximum response
Show the Answer
Question 72
A. Maximum gain of a system
B. Gain with feedback
C. Minimum gain of a system
D. Gain without feedback
Show the Answer
Gain with feedback
Question 73
A. The energy used by a device under steady-state conditions
C. The maximum voltage of a device
Show the Answer
Question 74
A. Initial sensing device
B. Intermediate control component
C. Feedback element
D. Directly changes manipulated variable
Show the Answer
Question 75
A. The pressure of the process medium at the sensing element
C. The desired setpoint pressure
D. The pressure at the output
Show the Answer
Question 76
A. The shift of zero below the lower range value
C. A constant zero value
D. The shift of zero above the lower range value
Show the Answer
Question 77
What is Resolution?
A. The degree to which equal values can be discriminated
D. The speed of response
Show the Answer
Question 78
B. A signal path without feedback
C. A signal path with feedback
D. A manual control system
Show the Answer
Question 79
A. Interference from magnetic fields
B. Interference induced by electrostatic fields
C. Internal noise
D. Stable output signal
Show the Answer
Question 80
B. The external standard for comparison
Show the Answer
Question 81
A. A controller combining proportional and rate actions
C. A controller with integral action only
D. A controller with no derivative action
Show the Answer
Question 82
A. Automatic adjustment of control parameters
B. Time-based control changes
C. Fixed control parameters
D. Manual control adjustments
Show the Answer
Question 83
A. Stable output signal
B. Internal noise
C. Electrostatic field interference
D. Interference from magnetic fields
Show the Answer
Question 84
A. Magnetic field interference
D. Interference between circuit terminals and ground
Show the Answer
Question 85
B. A variable influenced by another variable
C. A variable whose value is sensed to originate a feedback signal
Show the Answer
Question 86
A. Continuous linear control action
B. Non-linear control action
C. Random control action
D. Discrete control action
Show the Answer
Question 87
A. The deviation from the desired value
D. The signal from the output to the input
Show the Answer
Question 88
A. A controller with no feedback
D. A controller maintaining a fixed ratio
Show the Answer
Question 89
C. A controller using periodic pulses
D. A controller with continuous output
Show the Answer
Question 90
A. The internal device pressure
B. The desired setpoint pressure
C. The pressure at the supply port of the device
Show the Answer
Question 91
A. Internal noise
B. Interference between measuring circuit terminals
C. Interference from longitudinal fields
Show the Answer
Question 92
A. Control based on constant value
B. Control based on cumulative error
D. Control with no integral action
Show the Answer
Question 93
B. A controller with no integral action
C. A controller with derivative action only
D. A controller producing integral control action only
Show the Answer
Question 94
C. A controller using intermittent signal observations
D. A controller with continuous monitoring
Show the Answer
Question 95
B. The temperature of the medium surrounding a device
C. The internal temperature of a device
Show the Answer
Question 96
D. The signal representing the measured variable
Show the Answer
Question 97
What is Overrange?
A. Range above upper limit
B. Range within specified limits
C. Desired range of operation
D. Range below lower limit
Show the Answer
Question 98
A. Control based on current and past errors
B. Control with constant output
C. Control ignoring past errors
D. Control predicting future error
Show the Answer
Question 99
A. The time required for the output to stabilize within a specified band
Show the Answer
Question 100
A. The internal layout of a device
C. The position of a device relative to surroundings
Show the Answer
This process control terminology video provides you the detailed explanations for the remaining questions.
https://www.youtube.com/watch?v=pU8w59BKIyo&list=PLI78ZBihrkE3r0spCEdNIGmbaEfKPqUSa&index=46
Question 101
What is Linearity?
B. The ability to maintain a fixed value
C. Closeness to a straight line
D. The stability of output
Show the Answer
Question 102
D. The ratio of signal amplitude to noise amplitude
Show the Answer
Question 103
A. Accuracy in normal conditions
B. Highest possible accuracy
C. Accuracy at a reference point
D. Average accuracy over time
Show the Answer
Question 104
A. Range of conditions without impairment
C. Conditions for device failure
Show the Answer
Question 105
A. Error at the lower range value
B. Error at the midpoint
C. Error across the entire range
D. Error in the feedback signal
Show the Answer
Question 106
D. The ratio of output change to input change
Show the Answer
Question 107
A. A temperature vs. frequency plot
B. A log-log plot of amplitude and phase
C. A plot of pressure vs. time
D. A flow rate vs. volume plot
Show the Answer
Question 108
A. A feedback-free controller
C. A controller producing proportional control action only
D. A controller with integral action
Show the Answer
Question 109
What is Accuracy?
A. Speed of response
B. Closeness to true value
C. Range of operation
D. Stability over time
Show the Answer
Question 110
A. Control with no proportional action
B. Combined control based on error and its rate of change
C. Control ignoring future error
D. Control with constant output
Show the Answer
Question 111
B. The deviation between setpoint and feedback signal
Show the Answer
Question 112
A. The behavior of output over time
Show the Answer
Question 113
A. A controller combining P, I, and D actions
B. A controller with no proportional action
Show the Answer
Question 114
A. The time required for system cooling
B. The time required after energizing a device before rated performance
Show the Answer
Question 115
B. The internal temperature of a device
C. The temperature of the process medium at the sensing element
Show the Answer
Question 116
A. Limiting to an average value
B. Limiting to a maximum value
C. No limitation control
D. Limiting to a minimum value
Show the Answer
Question 117
A. A system without setpoints
B. A system for deliberate manipulation of variables
C. A manual adjustment system
Show the Answer
Question 118
B. Control predicting future values
C. Limiting to a minimum value
D. Control with no lower limit
Show the Answer
Question 119
A. Impedance presented by the output device
B. Impedance of the source
Show the Answer
Question 120
D. A controller adhering to a time schedule
Show the Answer
Question 121
What is a Process?
A. A manual adjustment system
C. The collective functions performed in the equipment
Show the Answer
Question 122
A. A fixed characteristic of a system
B. A device’s internal setting
C. A constant value
D. A controllable or variable characteristic
Show the Answer
Question 123
A. The midpoint of the range
C. The lowest quantity measurable
Show the Answer
Question 124
What is Range?
A. The region between the limits of measurement
Show the Answer
Question 125
A. Control with no specific goal
B. Manual adjustment for best value
C. Maintaining a fixed value
D. Automatic seeking of the best value
Show the Answer
Question 126
A. Internal factors of a device
C. Conditions to which a device is subject
Show the Answer
Question 127
A. Gain at zero frequency
B. Gain without feedback
D. Gain for sinusoidal signals
Show the Answer
Question 128
A. Impedance of the signal
B. Impedance of the output device
C. Impedance presented to the source
D. Impedance of the load
Show the Answer
Question 129
A. Analog control action
B. Manual control action
C. Control by a digital device
D. Control by mechanical means
Show the Answer
Question 130
What is Zero Shift?
B. A parallel shift of the input-output curve
D. The shift of zero below the lower range value
Show the Answer
Question 131
A. Impedance of the output device
B. Impedance of the signal
C. Impedance presented to the input of a device
D. Impedance presented to the load
Show the Answer
Question 132
What is an Element?
A. A complete control system
B. A manual control device
C. A fixed-output device
D. A component of a device or system
Show the Answer
Question 133
A. Changing system parameters
B. Modifying system structure
C. Recording system performance
D. Adjusting output based on input
Show the Answer
Question 134
A. The change in input required for a full range output change
B. A fixed value range
Show the Answer
Question 135
What is Damping?
A. Maintaining a fixed output
B. Increasing system oscillation
C. Suppression of oscillation
D. Random control actions
Show the Answer
Question 136
A. A range with zero above the lower range-value
D. A range with zero at the lower limit
Show the Answer
Question 137
A. A controller with continuous output
B. A binary controller with fully on/off states
C. A controller with proportional output
Show the Answer
Question 138
A. Electrostatic field interference
B. Interference from transverse fields
C. Interference appearing between circuit terminals
D. Interference appearing between terminals and ground
Show the Answer
Question 139
A. Control without monitoring
B. Control based on output comparison
C. Control by trial and error
D. Control based on preset conditions
Show the Answer
Question 140
A. A system with manual controls
B. A system avoiding disturbance to other variables
C. A system with feedback
D. A system without feedback
Show the Answer
Question 141
B. The total time response to a change in input rate
D. The response to a sudden input change
Show the Answer
Question 142
What is Dead Band?
A. Constant output range
B. Minimum input range
C. Range with no response
D. Maximum output range
Show the Answer
Question 143
A. Feedback element
B. Final controlling device
C. Intermediate control component
D. Directly responsive to measured quantity
Show the Answer
  • Electrical Engineers Objective Questions and Answers
  • Industrial Electronics Objective Questions and Answers
  • Digital Circuits Objective Questions and Answers
  • Electrical Measurement Objective Questions and Answers
  • Electronic Circuits Objective Questions and Answers
Top 10 Industrial safety Objective Questions
Measurements & Instrumentation Quiz – Set 8
Cartridge Filters
Measurements & Instrumentation Quiz – Set 1
Industrial Automation Components Questions and Answers
Active Electrical Filters Objective Questions
200 Quiz Questions for Instrumentation and Control Professionals
Measurement and Calibration Objective Questions
Nuclear Plant Sensors and Detectors Quiz
Instrument Document Quiz
Top 100 Power Plant Engineering Objective Questions & Answers
Circuit Control Devices Multiple Choice Questions & Answers
Dataloggers Objective Questions
Data Loggers Objective Questions
Instrumentation Engineering Documents
Instrumentation Engineering Documents Questions Answers
Digital to Analog Converters Objective Questions
Measuring Instruments MCQ
Control Loops Multiple Choice Questions
Control Loop Multiple Choice Questions
Hazards of Compressed Air
Relay Types
Types of Relays – Questions and Answers
Measurement of Phase Angle Objective Questions
Hydrostatic Level Measurement
ball Valve Animation
Basics of Ball Valves
OMRON PLC program for waste-burning automation
Waste-Burning System OMRON PLC Program Example
Full Wave Rectifiers Objective Questions and Answers
Difference Between RS232 and RS485
Level Measurement Objective Questions
RTD with Thermowell
Temperature Sensor Accessories
