Reading: PLC Programming to Control Lights in a Sequence
Inst Tools > Blog > PLC Tutorials > PLC Programming to Control Lights in a Sequence
Last updated: March 4, 2021 2:39 pm
3 Min Read
Develop ladder logic program for a display sign that will sequentially turn ON.
PLC Programming Sequence LogicProgram Description:Program Output:When Timers preset value is 3When Timers preset value is 2When Timers preset value is 1Conclusion:
  1. Three lights (L1, L2, L3) 3 sec apart.
  2. Turn Off all the lights after 6 sec.
  3. Three lights (L1, L2, L3) 2 sec apart.
  4. Turn Off all the lights after 4 sec
  5. Three lights (L1, L2, L3) 1 sec apart.
  6. Turn Off all the lights after 2 sec.
  7. Repeat the sequence from step 1
PLC Program to Control Lights in a Sequence
Simple PLC program for light control system
Programming a PLC to Control a Light
Rung 0000:
Start/Stop PB latched with memory B3:0/0.
Rung 0001:
B3:0/0 enabled to turn on L1  (O:0/0 ) and Timer  T4:0 to turn on L2.
Rung 0002:
B3:0/0 and T4:0 enabled to turn on L2  (O:0/1 ) and Timer  T4:1 to turn on L3.
Rung 0003:
B3:0/0 and T4:1 enabled to turn on L3 (O:0/1 ) and Timer  T4:2 to turn on L3.
Rung 0004:
B3:0/0 and T4:2 enabled to turn on Timer T4:3 to Set the timers (T4:0, T4:1, T4:2 and T4:3)  preset to 2sec using move block. Comparator blocks which performing equal operation among counter accumulator and timer accumulator value.
Rung 0005:
The counter block is used to count the number of sequences to choose the preset value of timers.
Rung 0006:
B3:0/0 and comparator block enabled to Set the timers (T4:0.T4:1, T4:2 and T4:3)  preset to 1sec using move block. Comparator blocks which performing equal operation among counter accumulator and timer accumulator value.
Rung 0007:
B3:0/0 and comparator block enabled to Set the timers (T4:0.T4:1, T4:2 and T4:3)  preset to 3 sec using move block. Comparator blocks which performing equal operation among counter accumulator and timer accumulator value.
Rung 0008:
B3:0/0 and comparator block enabled are used to reset the counter to repeat the sequence from beginning
Program Output:
PLC Program for Sequentially Light on Application
PLC control of lights
ladder program for on off control of lamp
Conclusion:
We can use this example to understand the programming logic in Allen Bradley Programmable Logic Controller (PLC).
Author: Hema Sundaresan
JUMP Instruction in PLC Programs
Master Control Reset (MCR) in PLC
One-Shot Rising & Falling Instructions
Sequence and Logic Control in PLC
Scaling with Parameters Instruction
Automation System for Hazardous Environments
PLC Programming Course Online Free
Create a User-Defined Function Block in Codesys
What is a PLC? – Programmable Logic Controller
Actuator Sensor Interface (ASi) Protocol in PLC
Communication between Wincc and Tia Portal
How to Configure IP Address in Rockwell PLC?
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
PLC Programming for Garden Sprinkler System
PLC Code to Start & Stop Motor and Pump as per Logic
SCADA Run
PLC Based Industrial Conveyor Ladder Logic
Delta PLC Simulator
How to Work with Delta PLC Simulator?
What is Interposing Relay in a PLC System ?
Download a Ladder logic program to GE PLC
PLC Tag Naming Conventions
PLC Timer Program
PLC Timer Instructions
PLC Program for Tank Heating Control using Heater
PLC Programming for Tank Heating Control using Heater
Allen-Bradley MicroLogix PLC Wiring
Programmable Logic Controller (PLC) Questions and Answers – 8
Parity Generators Objective Questions
Importance of Hysteresis Loop
PLC Modbus Communication
Introduction to Modbus – Reading and Writing Data
valve packing assembly
What is Valve Packing ?
Field Instruments Selection Aid
Instrumentation Standards
Parking Lights PLC Program Explained with Video
