Reading: D Flip Flop PLC Ladder Logic
Inst Tools > Blog > PLC Tutorials > D Flip Flop PLC Ladder Logic
This is the PLC Program to implement D flip flops in PLC. Learn PLC programming based on simple digital electronics examples.
Last updated: November 3, 2023 12:40 pm
6 Comments
D Flip Flop PLC Ladder LogicProblem DiagramProblem SolutionList of inputs and outputsPLC Ladder Diagram for D-FlipflopProgram DescriptionResult
Problem Description
Implement D flip flop in PLC using ladder language programming.
Problem Diagram
Problem Solution
D flip flop has one input which denoted with D. D latch is simple flip flop with NAND gate circuit between S and R input.
In SR flip flop when S=R=1 and S=R=0, outputs either do not change or they are invalid (no action).
As we can see in diagram in D flip flop S and R inputs always be the complements of each other. Hence S=R=1 and S=R=0 conditions will never occur.
This disadvantage of the SR flip flop can be overcome by using D flip flop.
Truth Table for the D Latch
D Flip Flop Truth Table
Digital Inputs
  • SET/RESET :- I0.0
Digital outputs
  • Q output :- Q0.0
  • Q^ output :- Q0.1
M memory
  • Relay coil 1 :- M0.0
  • Relay coil 2 :- M0.1
PLC D Flip Flop
D flip flop logic PLC
D Flipflop Ladder Logic
PLC D Flip Flop Logic
Program Description
For this application, we use S7-300 PLC and TIA portal software for programming. We can implement this logic by using other PLC also.
Network 1:
Here we used NO contact of SET/RSET input (I0.0) and in parallel connection we used NC contact of relay coil 2 (M0.1) to operate relay coil 1 (M0.0).
Network 2:
Here we used NC contact of SET/RSET input (I0.0) and in parallel connection we used NC contact of relay coil 1 (M0.0) to operate relay coil 2 (M0.1).
Network 3:
When relay coil 1 (M0.0) is ON, Q output (Q0.0) will be ON.
Network 4:
When relay coil 2 (M0.1) is ON, Q^ output (Q0.1) will be ON.
As per D flip flop, a condition of Q=1 and Q^=0 is set and a condition of Q=0 and Q^=1 is reset.
Here we can see in diagram as well as in ladder diagram, difference in D flip flop and SR flip flop is that it uses inverted value of S input.
So in D flip flop we are using only one in put for SET/RESET.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of D flip flop.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications.
Result
Simulation of D flip flop in PLC
Author: Bhavesh
  • Permissive and Interlock Circuits
  • PLC Program Conveyor Motor
  • SCADA Interview Questions
  • Motor Control Circuits
  • PLC Programming languages
Advanced Skills Required for a PLC Programmer to Get a Job
Remote Factory Acceptance Test
VFD Pros and Cons – Variable Frequency Drives
Ladder Diagram Example using Memory Bits and Set Coils
PLC Mixing Process with Adjustable Timer and Valve Control
6 Comments
  • Archimedes says:
    August 17, 2018 at 10:14 pm
    Hi there! any idea why we can’t download this pdf? I have the same issue and to the other plc tutorials that you upload here…
    • S Bharadwaj Reddy says:
      August 18, 2018 at 2:52 pm
      Hi, We have small issue with latest version of Google Chrome,meanwhile please use other browsers like mozilla, opera etc. We try to solve this issue soon.
      • Archimedes says:
        August 18, 2018 at 8:38 pm
        Sorry to bother you here but can you check this link please? i had asked a question about vfd drives….
          August 18, 2018 at 10:04 pm
          Yes, You can get 380V 3 phase output using an single phase 230V Inverter.
          Inverter manufacturers do not recommend VFD drives for single-phase supplies in excess of 3kW to ensure compliance with European Power Quality Standards such as BSEN 61000-3-2:2006 and BS EN 61000-3- 12:2005.
          For similar reasons inverter manufacturers do not recommend drives with an output voltage that is different to the supply voltage (e.g.: 240v input, 415v output).
          • Archimedes says:
            August 19, 2018 at 9:21 am
            Thank you sir!
  • Archimedes says:
    August 18, 2018 at 5:57 pm
    Thank you sir for your usefull information! Keep on the great job!
Traffic Lights Ladder Diagram using Timers
PLC Crane Movement Control with Limit Switches
PLC Electric Motor Interlocks
Your First Steps Through STL Language
DC Injection Braking in VFD
Dosing Pump PLC Logic
Commissioning Checklists for Industrial Automation Systems
Oil and Water Separation Process using PLC Programming
OB and FB Blocks in Siemens PLC
Procedure for Siemens S7-300 Download from PC to PLC
PLC Program for an Alternate output circuit
Basic Concepts of the Safety Relay
PLC Program for Two ways switch logic for staircase light
PLC Program for Two Way Switch Logic
Preventive Maintenance of Variable Frequency Drive
PLC Program for Automatic Parameter initialization
PLC Program for Automatic Parameter Initialization When Power UP
Compare Servo Motor and Stepper Motor
Studio 5000 Logix Emulate
Simulation of Studio 5000 and FactoryTalk View Studio
Digital Electronics Projects
Top 100 Digital Electronics Project Ideas for Engineering Students
Parallel Open Circuit Fault
Parallel Open Circuit Faults
11 KV Bus A to Bus B Phase Check Problem
Ladder Diagram PLC program
PLC Counter Instructions
ultrasonic-level-measurement
Ultrasonic Level Transmitter Working Principle
Abbreviations of Pressure, Temperature & Flow
Encode and Decode Instructions
How to Use Encode and Decode Instructions in PLC ?
Tilt Level Switch Working Animation
