Reading: Count and Pack Objects from Conveyor using PLC Ladder Logic
Inst Tools > Blog > PLC Tutorials > Count and Pack Objects from Conveyor using PLC Ladder Logic
This is a PLC Program to count and pack objects from the conveyor. Learn the PLC programming with this example problem and solution.
Last updated: November 3, 2023 12:07 pm
Count and Pack Objects from the ConveyorProblem DiagramProblem SolutionI/O in this ExamplePLC Ladder Diagram to count and pack objects from conveyorPLC Program ExplainedResult
Problem Description
  1. Objects are moving on the conveyor
  2. We need to pack five objects in the empty box. When the empty box is filled. It is carried to the storage via a conveyor belt
  3. Implement this automatic cycle in PLC using ladder language.
Problem Diagram
PLC Program to Count and Pack Objects from Conveyor
Problem Solution
Mostly inductive and proximity sensors are used to detect objects. Here we mount proximity sensor for the object detection and empty box detection.
Inductive sensor are mostly used to detect metal objects and proximity sensors are used to detect metal objects and other objects.
Here one proximity sensor is for object detection and other is for box detection. Objects are moving on conveyor 1 and boxes are moving on conveyor 2.
We will write automatic cycle for this application in PLC. So when empty box is detected on conveyor 2, conveyor 1 will be ON automatically.
And when box is filled with five objects, conveyor belt 2 will start automatically.
Note:- Here we consider simple application for counting and packaging application. We considered an proximity sensor for simplicity. Proximity sensor will sense the object and counter will count the total objects.
I/O in this Example
Digital Inputs
  • Start :- I0.0
  • Stop :- I0.1
  • Proximity :- I0.2 (part detection)
  • Proximity :- I0.3 (Box detection)
  • Counter reset PB :- I0.4
Digital Inputs
  • Cycle ON :- Q0.0
  • Conveyor belt 1 :- Q0.1
  • Conveyor belt 2 :- Q0.2
M memory
  • Total objects :- MW10
  • Relay coil :- M0.2
PLC conveyor objects
PLC Conveyor Belt
objects moving on the conveyor
plc conveyor logic example,
For this application, we use S7-300 PLC and TIA portal software for programming. We can implement this logic by using other PLC also.
Network 1:
In first network we used latching circuit for cycle ON. Here we used START PB (I0.0 ) to start the cycle and STOP PB (I0.1) to stop the cycle.
Network 2:
Here when empty box is detected (I0.3) and cycle is ON, conveyor 1 (Q0.0) will be ON.
Network 3:
Counter is used to count the objects moving on the conveyor 1. Objects are moving on the conveyor 1 (Q0.0) and mounted proximity sensor (I0.2) is detecting the objects.
Now counter counts in the incremental way. Total counted objects will be stored in the memory word or register (MW10).
Network 4:
Network 5:
When five box completely packed in the box, counter output will be ON and as per logic relay coil (M0.2) will be latched for timer operation.
Timer instruction is executed when relay coil (M02.) is activated.
Network 6:
Box is filled with five objects or counter output is ON and empty box is not detected, conveyor belt 2(Q0.2) will be activated.
When objects are moving on the conveyor 1, counter will count the objects. We need to pack three objects in the box. So when box is filled with five object, timer will stop the conveyor belt 1 and conveyor belt 2 will start automatically.
Here we have not considered all interlocks for simplicity. Belts synchronization are assumed because we have used timer based synchronization.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of counting and packaging application. By using this concept we can count objects moving on the conveyor and pack it automatically.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications.
Result
plc programming conveyor belt,
Author: Bhavesh
  • Ladder Diagram in PLC
  • AB PLC Interview Questions
  • DCS Architecture
  • Reduce Relay Noise in PLC
  • PLC Analog I/O Problems
PLC Logic for Analog Alarms using Functional Block Diagram
Difference between PLC and HMI
Working Principle of Single Phase Preventer Relay
Failsafe Wiring Practices
Instrumentation System Architecture
PLC Scan Time
  • Logan Hattingh says:
    November 3, 2021 at 5:26 pm
    Network 3 and 4 have the same description?
Micro Memory Card (MMC) in Siemens PLC
How to use JUMP Instruction in PLC Ladder Logic?
What is Siemens TDC? – Siemens Control System
What is Interface Module in Siemens PLC?
How to Configure an Alarm in InTouch SCADA?
Pause the Timer PLC Ladder Logic
Omron PLC paper cutting machine automation
Automatic Paper Cutting Machine Using CX-Programmer
Siemens PLC Programming OBs in Siemens TIA Portal
FC Function in Siemens PLC
User Defined Data Types - UDT
User Defined Data Types (UDT) – Purpose, Need, Tutorial
PLC Circuit with Switches
PLC Example with Switches
How to Control VFD with PLC using Ladder Logic
pH Measurement Questions & Answers
Centrifugal Machine Field
Batch Type Centrifugal Automation in Sugar Industries
Economizer
What is an Economizer? Purpose, Classification, Advantages
Reciprocating Piston Meters
Overview of Positive Displacement Flow Meters
Electrical Maintenance Engineer's Biggest Enemy
Electrical Components Overheating – Causes, Troubles, Prevent
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
Scaling Sensor Output to Engineering Units
Up Down Counter Objective Questions
