Reading: PLC Program for Automatic Parameter Initialization When Power UP
Inst Tools > Blog > Guest Articles > PLC Program for Automatic Parameter Initialization When Power UP
Due to power failure, PLC parameter values becomes zero. Write a PLC Program for Automatic Parameter Initialization when Power UP.
Last updated: November 3, 2023 10:12 am
Guest Articles PLC Tutorials
This is a PLC Program for Automatic Parameter initialization when power up.
Parameter Initialization When Power UPProblem DiagramProblem SolutionPLC Ladder diagramInputs ListOutputs ListProgram DescriptionRuntime Test Cases
Problem Description
In many applications, it is necessary to initialize some data when the machine is powered up.
Sometimes due to power failure, the value in some parameters becomes zero.
Due to this problem, the operator has to feed all data again or every time during power failure.
When the machine gets powered up, at that time necessary parameters should be initialized automatically.
Here we discuss this issue with some basic ladder logic.
Problem Diagram
Problem Solution
In this case, we need to write the logic in the PLC program so all parameters will be initialized automatically.
We can also set a manual initialization button so the operator can initialize data while the machine operation is running.
Here we will consider the machine set speed as data and it will be initialized automatically when the machine turns on.
If the operator wants to reinitialize the set speed during the running cycle then he needs to do it through the initialization button.
PLC Ladder diagram
Here is the PLC program Automatic Parameter initialization when powered up.
PLC Parameter Initialization
List of PLC inputs/outputs
Inputs List
  • Parameter Initialization Button : I0.0
  • MW10 : Set Speed form Display
Outputs List
  • Mw12 : Speed for drive
Program Description
  • For this application we use S7-1200 PLC and TIA portal software for programming.
  • This logic is used for parameter initialization.
  • For first scan, we used here S7-1200 facilities of system Memory. Every PLC have its own system memory.
  • Always ON bit, always OFF bit, first scan bit, and diagnostic status changed are the system memory for S7-1200 PLC.
  • We can configure any memory address “M” for system memory. Here we configured M1.0 for first scan bit which is used for parameter initialization.
  • We write for parameter initialization in Network 1. Here we use NO contact of First scan bit (M1.0) for moving initial 5 RPM in MW12(Speed for drive).By using MOVE instruction 5 RPM will be moved in MW12 . Add NO contact of Parameter Initialization Button (I0.0) for moving Initial 5RPM in MW12 (Speed for drive) manually.
  • For editing data manually in running cycle we write logic in Network 2. Here operator can enter data in MW10 (SET SPEED) from the display and it will go in MW12(Speed for drive).
  • For Example, Say we need to enter 100 RPM speed from display it will be written in word MW10 (Set Speed from display) and as per logic it will be moved in MW12 (Speed for drive), so motor will run on 100 RPM.
Runtime Test Cases
plc program automatic parameters
Note: The above PLC Logic provided for basic idea about application of PLC Program for Automatic Parameter Initialization when Power UP. The Logic is limited and not complete application.
Author: Bhavesh
  • PLC Separate Different Size Objects
  • Automatic Empty Bottle detection using PLC
  • PLC Program for Paint Spraying
  • Siemens PLC configuration in TIA Portal
  • PLC Selective Execution of the Application
Basic Conveyor System for Product Handling in Omron PLC
Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
How to import GSD files into the TIA Portal? – Siemens PLC
Design a Program Using Studio 5000 and FactoryTalk View Studio
Top 100 PLC Objective Questions and Answers
  • mukesh khurse says:
    November 18, 2021 at 1:32 pm
    Sir please make artical about loadcell ladder logic programing how to program and calibration.
Steps to Configure TCP/IP Communication in Siemens S7-1200 PLC
What is Multi-touch Technology? – Industrial Automation
Chemical Mixing Process using PLC
Difference Between PLC and SCADA
PUT Command in Siemens PLC – TIA Portal Basics
#1 PLC Best Practices – Split PLC Code into Modules
PLC project for traffic signals automation
Complete PLC Project: Traffic Light Auto and Manual Automation
Moisture Separator
Inhouse Moisture separator for Pneumatic Systems
PLC Logic - Control Spray Nozzle, Fans, and Puncher
5 Tips to Pass CFSE Exam
JMP instruction in PLC Programming
How to use JUMP Instruction in PLC Ladder Logic?
Program to implement T Flip Flop logic
T Flip Flop PLC Ladder Diagram
Introduction to PLC
#9 PLC Best Practices – Validate indirections
PLC Program for Fishpond Water Level Monitoring System
PLC Program for Artificial Fishpond Water Level Monitoring System
Ladder Logic for Flow Meter Totalizer
How to use Fire Fighting Hydrant
Fire and Safety
Electronic Devices & Circuits Quiz – Set 12
electronics-questions-and-answers
Electronics Questions & Answers
Stripping tower unit
Ultrapure Water in the Semiconductor Industry
Advanced PLC Programming Training Course
4-20 mA Conversion Formulas
Standard 4 to 20 mA Conversion Formula
