Reading: PLC Program Example on Multiple LEDs using Set Coil
Inst Tools > Blog > PLC Tutorials > PLC Program Example on Multiple LEDs using Set Coil
In this article, you will learn the PLC programming example on multiple LEDs using the Set Coil instruction.
Last updated: March 26, 2024 3:40 pm
PLC Program using Set CoilPLC Learning VideoPLC I/O ListLadder DiagramLogic ExplanationResult
Note: The PLC program example was created for learning practices for the engineers and technicians.
Problem Statement
If Switch 1 is ON, then LED I and LED II will be ON.
If Switch 1 is OFF, then LED I and LED II will be still ON.
If Switch 2 is ON, then LED III and LED IV will be ON.
If Switch 2 is OFF, then LED III and LED IV will be still ON.
PLC Learning Video
This video helps you to learn this PLC program example from scratch. It is helpful for beginners.
The Basic Example of Ladder Logic - Schneider Training
PLC I/O List
Digital Inputs:
The DI signals are listed below.
  • Switch 1: I0.0
  • Switch 2: I0.1
Digital Outputs:
The DO signals are listed below.
  • LED 1: Q0.0
  • LED 2: Q0.1
  • LED 3: Q0.2
  • LED 4: Q0.3
Ladder Diagram
Logic Explanation
In this PLC example, we used EcoStruxure Machine Expert Basic PLC software for programming.
In the above PLC program, we have used Normally Open Contact for Switch 1 (I0.0), Switch 2 (I0.1).
We have also used Set coils for the outputs LED 1 (Q0.0), LED 2 (Q0.1), LED 3 (Q0.2) and LED 4 (Q0.3).
Switch 1 is connected to two LEDs i.e., LED 1 and LED 2.
LED 3 and LED 4 are connected to the input, Switch 2.
For LED 1 and LED 2 to turn ON, input Switch 1 should be turned ON.
LED 1 and LED 2 will remain ON when the input Switch is turned OFF.
When Switch 2 is turned ON, then LED 3 and LED 4 will turn ON.
Then, when switch 2 is turned OFF, LED 3 and LED 4 will remain ON.
Result
When Switch 1 is ON
As Switch 1 is used as Normally Open Contact, it will allow the signal to flow through it. As a result, LED 1 and LED 2 will turn ON.
When Switch 1 is OFF
Ladder Logic Set Coil
There is use of Set Coils for LED 1 and LED 2. So, the outputs will not turn OFF when input Switch 1 is turned OFF. LED 1 and LED 2 will remain ON.
When Switch 2 is ON
Set Instruction PLC Example Logic
LED 1 and LED 2 will turn ON when the input Switch 2 is turned ON. The input Switch 2 is taken as Normally Open Contact, it will allow signal to the outputs.
When Switch 2 is OFF
Ladder Diagram for LED ON and OFF
The outputs, LED 3 and LED 4 will not turn OFF when input Switch 1 is turned OFF. We have used Set coils for the outputs.
On turning OFF the input will not turn OFF the Outputs. Therefore, when Switch 2 is turned OFF, Led 3 and Led 4 will remain ON.
  • Electrical Diagram into PLC Program
  • How to Get a PLC Programmer Job?
  • Seven Segment Display Working Principle
  • PLC Programming Example with Switches
  • Faceplates in FactoryTalk View Studio
What is PCS 7?
Product Painting PLC Program using Omron CX-Programmer
What is Masking in PLC?
PLC Program for Automatic Parameter Initialization When Power UP
How to Communicate with Excel from Intouch SCADA?
Motor Control Circuits
#16 PLC Best Practices – Create Trend for Cycle Time on HMI
Scaling with Parameters (SCP) Instruction in PLC
Label the Electrical Circuit Schematic
Mitsubishi PLC Counter Tutorial Using GX-Works2
PLC Programming for Garden Sprinkler System
Moving Data between PLCs – Siemens Basics – TSEND TRCV
Automatic Railway Crossing Gate Control PLC Program
PLC Programming Example on Bottle Line Control
What is an RTU - Remote Terminal Unit
What is an RTU? – Remote Terminal Unit
Introduction to SCADA
PLC Program for Food Processing
PLC Program for Food Processing Industry
Features of Scada Which are Must in an IoT System
Advanced Skills Required for a PLC Programmer to Get a Job
Shutdown Motors in Timed Operation PLC Program
PLC Program using START & STOP Buttons
PLC Program using START and STOP Buttons
Hydrostatic Level Measurement
NH3 Plant Turbo-compressor Sudden Rise in Temperature
The Importance of Engineering Surface Plates
Metering pumps
Metering Pumps
Ion Analyzers Questions and Answers
Special Designs of Ion Selective Electrodes Questions & Answers
Center Tapped Full Wave Rectifier Operation
Insertion flow meters
What is an Insertion Flow Meter? – Types, Principle, Advantages
Calibration of Measuring Instruments
Calibration of Measuring Instruments – Significance, Costs & Risks
