Reading: Design a PLC program for Operational Sequence of Packaging Process
Inst Tools > Blog > PLC Tutorials > Design a PLC program for Operational Sequence of Packaging Process
Last updated: March 4, 2021 1:27 pm
3 Min Read
Develop the PLC program to execute the operational sequence of the packaging process.
PLC Packaging ProcessPLC IO DetailsPLC ProgrammingPLC Program DescriptionRUNG 0000RUNG 0001RUNG 0002 & RUNG 0003 RUNG 0004Rung 0005Conclusion:
  1. The purpose of this process is to pack 50 pieces of the product in each container.
  2. As the product passes through the light beam, it is deflected by the photoelectric proximity switch and counted by PLC counter
  3. When the counter reaching 50, the solenoid operator deflector plate energizes to channel the product from chute A to chute B.
  4. When the second count of 50 reached, the solenoid-operated deflector plate de-energizes to channel the product back to chute A and the sequence continues.
  5. Stop PB is pressed anytime to stop the process.
  6. Manual reset is pressed to resetting the accumulator value of the counter to any time.
PLC IO Details
PLC IO Details for Sequence of Packaging Process
PLC Programming
PLC Automation of product packaging
 The following description explains the logic rung wise.
RUNG 0000
Latching rung to operate the system through Master Start (I:0/0) and Stop PB (I:0/1).
RUNG 0001
Start memory latch (B3:0/0) and proximity switch (I:0/2) are connected in series to make a count of  each product  crossing and chute A indicator lamp also turn ON (O:0/1)
Counter done bit enables to turn on another memory (B3:0/1) to trigger a solenoid valve to change deflector plate from chute A to chute B. Chute B indicator (O:0/2) enables.
 RUNG 0004
Once 50 product entered chute B, counter done bit makes solenoid valve to go off and triggers deflector plate to favors chute A. Chute A indicator (O:0/1)  is connected in a normally closed contact to break a memory latch.
Rung 0005
Counter automatically reset when done bit enables. Manual reset (I:0/3) is connected in parallel to reset the counter manually.
The program runs continuously until STOP PB is pressed.
Conclusion:
The above-explained operational sequence of packaging process is for example only. It may vary from real-time. We can use this example program to understand the working of timers, memory bit and interlocking concept function in AB PLC.
Author: Hema Sundaresan
  • Motor control in Ladder logic
  • Conveyor Ladder Logic Program
  • Function Block Programming
  • Operator Interface for SCADA
  • Control Instructions in PLC
How to use Sub Routines with Allen Bradley PLC
Difference Between PLCSIM and PLCSIM Advanced? – Siemens PLC
Why Are Charcoal and Salt Added to an Earthing Pit?
PLC Programming Example with Pushbutton and Motor
How to Use an SQL Server with Indusoft Web Studio?
Developing PLC Logic for Water Pumping and Chemical Addition
DCS Commissioning Steps
Standard Colors in PLC Automation Systems
PLC Pneumatic Circuit Control
Codesys function block example
Create a User-Defined Function Block in Codesys
Types of Interrupts Organization Blocks in Tia Portal
Types of Interrupt OB in Siemens Tia Portal
How Could FB and FC Make Me Professional PLC Programmer
How Could FB and FC Make Me Professional PLC Programmer?
PLC based Automatic Packaging System
PLC Programming for Pumping and Draining System
Why 4-20 mA Current Signal is used instead of Voltage Signal
OSI Reference model
SCADA Communication and Protocols
Three Phase Electric Current Flow Animation
Symmetric Three Phase Electric Current Flow Animation
Butterfly Valve
Butterfly Valves Construction, Types, Stem & Bonnet Assembly
What is Gear Box Backlash
What is Gear Box Backlash ?
DP transmitter
Square-root characteristics of Differential Pressure Flow Meters
Applications of Photo diodes
pH Monitoring System Triggers an Alarm
Common Materials used in Instrumentation Cables
How to Delay a Sensor Signal in PLC?
