Reading: Oxygen Analyzer Working Principle
Inst Tools > Blog > Analyzers > Oxygen Analyzer Working Principle
Last updated: June 11, 2018 8:33 pm
Analyzers
2 Comments
9 Min Read
The measurement methods of the oxygen analyzers currently available in the industry can be classified into the following categories.
  1. Zirconia type measurement system
  2. Paramagnetic type
  3. Optical type
  4. Electrochemical type
Since each of the measurement methods has its advantages and disadvantages, it is important to select an oxygen analyzer of an appropriate method for your application and usage.
The following describes an overview of each of the measurement methods and their advantages and disadvantages.
(1) Zirconia type measurement system : Concentration cell system
A solid electrolyte like zirconia exhibits conductivity of oxygen ions at high temperature.
As shown in the figure, when porous platinum electrodes are attached to both sides of the zirconia element to be heated up and gases of different partial oxygen concentrations are brought into contact with the respective surfaces of the zirconia, the device acts as an oxygen concentration cell. This phenomenon causes an electromotive force to be generated between both electrodes according to Nernst’s equation. And it is proportional oxygen concentration.
Advantages : Can be directly installed in a combustion process such as a boiler’s flue and requires no sampling system, and response is faster.
Disadvantages : If the sample gas contains a flammable gas, a measurement error occurs (combustion exhaust gas causes almost no problem because it is completely burned).
(2) Zirconia type measurement system : Limiting Current type
As shown in the figure below, if the flow of oxygen into the cathode of a zirconia element heated to high temperature is limited, there appears a region where the current becomes constant even when the applied voltage is increased.This limited current is proportional to the oxygen concentration.
Oxygen Analyzer Principle
Advantages : •
Capable of measuring trace oxygen concentration.
Calibration is required only on the span side (air).
Disadvantages : • If the sample gas contains a flammable gas, a measurement error occurs.
• The presence of dust causes clogging of the gas diffusion holes on the cathode side; a filter must be installed in a preceding stage.
(3) Magnetic type measurement system : Paramagnetic system
This is one of the methods utilizing the paramagnetic property of oxygen. When a sample gas contains oxygen, the oxygen is drawn into the magnetic field, thereby decreasing the flow rate of auxiliary gas in stream B. The difference in flow rates of the two streams, A and B, which is caused by the effect of flow restriction in stream B, is proportional to the oxygen concentration of the sample gas. The flow rates are determined by the thermistors and converted into electrical signals, the difference of which is computed as an oxygen signal.
Paramagnetic Oxygen Analyzer Principle
Advantages : • Capable of measuring flammable gas mixtures that cannot be measured by a zirconia oxygen analyzer.
• Because there is no sensor in the detecting section in contact with the sample gas, the paramagnetic system can also measure corrosive gases.
• Among the magnetic types, the paramagnetic system offers a faster response time than other systems.
• Among the magnetic types, the paramagnetic system is more resistant to vibration or shock than other systems.
Disadvantages : Requires a sampling unit corresponding to the sample gas properties or applications.
(4) Optical type : Tunable Diode Laser measurement system
Tunable Diode Laser (or TDL) measurements are based on absorption spectroscopy. The TruePeak Analyzer is a TDL system and operates by measuring the amount of laser light that is absorbed (lost) as it travels through the gas being measured. In the simplest form a TDL analyzer consists of a laser that produces infrared light, optical lenses to focus the laser light through the gas to be measured and then on to a detector, the detector, and electronics that control the laser and translate the detector signal into a signal representing the gas concentration.
Optical type Oxygen Analyzer Principle
Gas molecules absorb light at specific colors, called absorption lines. This absorption follows Beers law.
TDL Analyzers are effectively infrared analyzers which obey the Beer-Lambert Law.
I = Io ·e-E ·G ·L
where I is the radiation intensity after absorption,
I0 is the initial radiation intensity,
E is the extinction coefficient,
G is the gas concentration,
and L is the path length of the measurement area.
Advantages :   • Capable of measuring a number of near infrared absorbing gases in difficult process applications.
• Capability of measuring at very high temperature, high pressures and under difficult conditions (corrosive, aggressive, high particulate service).
• Most applications are measured in-situ, reducing installation and maintenance costs.
Disadvantages : The installation of the flange is necessary for both sides of the process.
(5) Electrochemical type : Galvanic cell type
If oxygen is dissolved via the diaphragm in an electrolytic solution in which an anode (base metal) and cathode (noble metal) are adjacent to each other, a current proportional to the quantity of dissolved oxygen is generated. The amount of oxygen passing through the diaphragm is proportional to the partial oxygen pressure of the sample gas, therefore, the oxygen concentration can be determined by measuring the current.
Electrochemical type Oxygen Analyzer Principle
Advantages :   • The detecting system can be made compact; this measurement system is available in portable or transportable form.
• Relatively inexpensive in comparison with oxygen analyzers of other measurement systems.
Disadvantages : The cell life is limited. As it is a kind of oxygen cell, the galvanic cell deteriorates even if not used.
In general, it should be replaced approximately every year.
Application examples for each oxygen analyzer
Oxygen concentrations are measured for a variety of purposes, such as energy conservation, air pollution prevention, safety management, and quality control.
The following lists major application examples by measurement method.
Concentration cell system Zirconia Oxygen Analyzer
Package boiler combustion control, gas fired
Combustion control of power generation boilers, gas fired
Combustion control of pulverized coal boilers
Combustion control of hot stoves for steelmaking
Heating and combustion exhaust gas control of coke ovens for steelmaking
Low-oxygen concentration control of reheating and soaking furnaces for steelmaking
Air leakage detection of sintering furnaces for steelmaking
Lime kiln combustion control
Cement kiln combustion control
Combustion control of heating furnaces for oil refinery & petrochemical industry
Naphtha cracking furnaces
Incinerator combustion control
Oxygen concentration measurement in oxygen enrichment facilities
Oxygen concentration measurement of exhaust gas from activated sludge process equipment
Limiting Current type Zirconia Oxygen Analyzer
Oxygen concentration control of N2 reflow furnaces
Atmospheric control of semiconductor manufacturing equipment
N2 and air purity control for air separators
Oxygen deficiency prevention
Oxygen concentration control of glove boxes for research and development and parts machining
Oxygen concentration control of experimental clean rooms for environment, fermentation, biochemistry, etc.
Continuous measurement of flow gases during food packaging
Paramagnetic system Oxygen Analyzer
Low-oxygen concentration control of CDQ plants for steelmaking
Oxygen concentration control of gas containing a flammable gas
Safety control (explosion prevention) at various plants
Measurement of trace oxygen concentration in various manufacturing processes
City gas quality control
Galvanic cell system Oxygen Analyzer
Tunable Diode Laser Analyzer(TDLS)
Process control
Also Read: pH Analyzer Interview Questions & Answers
Questions and Answers on Gas
Dual-beam Non-dispersive Analyzer
Oil in Water Analyzer Working Principle
Thin-Layer Chromatography : Manual Method
Turbidity Sensor Calibration Procedure
2 Comments
  • Venkat says:
    November 12, 2017 at 11:16 am
    Please give me material is all gas detection methods.to my mail I’d.
  • Satish says:
    August 29, 2020 at 8:57 pm
    I need a trace oxygen online analyser which is installed in plant. Detail catalog is required.
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
Silica Analyzer Problems and Troubleshooting Tips
pH measurement
What is the Application of Electrical Conductivity Meter?
Fluorescence
Ambient Air Quality Monitoring System Principle
Two Electrode Conductivity Probes Principle
Ammonia Analyzer Principle
Gas Filter Correlation (GFC) spectrometer
Gas Filter Correlation (GFC) Spectroscopy
Analytical Standards
Moisture and Dew Point Analyzer Problems
Moisture and Dew Point Analyzer Problems and Troubleshooting Tips
Analyzer chopper wheel
NDIR Analyzer Filter Cells
Luft detector
Luft detector Principle
Gas Analyzers Interview Questions
Gas Analyzers Interview Questions and Answers
pH Monitoring System Triggers an Alarm
Technologies for Oxygen Gas Measurement
How to Calibrate Oxygen Analyzer? – O2 Sensor Testing Procedure
Two Out of Three Logic
Alarm and Trip Systems
Humidity Calculator
Humidity calculator
Selection Guidelines for Cable Glands
Importance of Instrumentation Engineering
Importance of Instrumentation Engineering – Objectives
Diode-vi-characteristic-curve-for-forward-bias
VI Characteristic of a Diode
3 Way Circuit Animation
Three Way Electrical Switch Working Animation
Difference between Permanent Magnet BLDC and DC Motor
Inability to Test Repaired HT Motors
Inability to Test Repaired HT Motors in Workshop Posed Problems
