Reading: Multimeter – What Do Digits and Counts Mean?
Inst Tools > Blog > Calibration > Multimeter – What Do Digits and Counts Mean?
While buying Multimeter Digits and Counts is an important factor. These are two different ways to express the same thing.
Last updated: September 28, 2022 3:24 pm
Saurabh Vaidya
Calibration
4 Comments
6 Min Read
Many times we come across terms, ‘abc’ Multimeter is 3 ½, 4 ½, 6 ½, 7 ½ digits or 2000, 4000, 6000 counts. (‘abc’ means the manufacturer of multimeter)
Multimeter DigitsMultimeter CountsAccuracy
We also come across the accuracy of ‘abc’ Multimeter is ‘0.15% + 2 digit’.
What do these counts and digits mean?
Digits and counts are two different ways to express the same thing.
Multimeter Digits
Take an e.g. of 3 ½ digit Multimeter.
The format is given as a whole number followed by a fraction, usually a 1/2 or a 3/4.
The whole number represents how many digits displayed from 0 to 9.
The fraction is ½ or a ¾.
Fraction ½ means the most significant digit for each range can be 0 or 1.
A ¾ means the most significant digit for each range is greater than 1.
3 ½ digit Multimeter can display three complete digits and one ½ digit. Three complete digits can have any numbers from 0 to 9 and one ½ digit can have only 0 or 1.
Three Positions of digits can display 0 to 9 numbers and leftmost position can only display 0 or 1 number in 3 ½ digit Multimeter.
Similarly for 4 ½,6 ½, 7 ½ digit Multimeter displays complete 0 to 9 numbers on  four, six ,seven positions respectively and leftmost position displays only 0 or 1 number.
An illustration for 3 ½ Digit Multimeter Display (shown below)
A 6 ½ Digit Multimeter Display (as shown below)
A 7 ½ Digit Multimeter Display (as shown below)
7 ½ Digit Multimeter Reading
An 8 ½ Digit Multimeter Display (as shown below)
Multimeter Counts
If the display of Multimeter is 2000 counts. It can display digits from 0000 to 1999 counts. i.e. 3 ½ digit Multimeter.
If the display of Multimeter is 20000 counts. It can display digits from 00000 to 19999 counts. i.e. 4 ½ digit Multimeter.
Therefore, Digits and counts are two different ways to express same thing.
Counts are ignoring any decimal points and polarity signs.
Many newer Multimeters don’t have a restriction of 0 or 1 at leftmost digits.
Example
Display of Multimeter is 4000 counts. It can display digits from 0000 to 3999 counts. I.e. leftmost digit can have 0,1,2,3 digits.
So, it is more practical to describe a Multimeter by its counts rather than digits.
Counts tell you what the instrument can display before it changes to the next range.
For example, suppose a Multimeter is of 20000 counts (4 ½ digit Multimeter). This means the range changes when it hits 20000 on display.
A 20000 count meter can read 19.999 V on the display, but when it tries to display 20 V, it will read 020.00 V instead or simply 20.00 V.
The Multimeter moves to the next range mean one digit of resolution is lost.
Generally 2000 Count Multimeter (3 ½ digit Multimeter) have range 200.0 mV, 2.000 V, 20.00 V, 200.0 V.
Generally 6000 Count Multimeter have range 600.0 mV, 6.000 V, 60.00 V, 600.0 V
The count refers to the limit of the highest value the Multimeter will display for each range.
As soon as a measured value reaches this limit, the range will move up and the resolution will be downgraded by a factor of 10, that is, the decimal place will be moved to the right one spot.
Multimeter Counts
If we had a Multimeter that was designed to measure up to 1000V with a 40000 count, then, the ranges and resolution can be as follows:
0.0000 to 3.9999 with a resolution of 0.0001
4.000 to 39.999 with a resolution of 0.001
40.00 to 399.99 with a resolution of 0.01
400.0 to 1000.0 with a resolution of 0.1
Accuracy
The accuracy of Multimeter is written as “0.15% + 2 digits”
Means 0.15 % of indicated value + 2 × Resolution
Example
Reading of Multimeter at 1 volt is 1.005 V
Resolution is 0.001 V
Accuracy = (0.15% × 1.005) + (2× 0.001)
Accuracy = 0.0035 V
  • Calibration Organizations
  • Calibration Master Instruments
  • Stroke Checking Procedure
  • Smart Transmitter Sensor Trim
  • As-Left As-Found Calibration
Hierarchy of Calibration Organizations
Selection of Master Instrument for Calibration
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
Calibration and Troubleshooting of Oxygen Analyzer
How to Test a Pressure Switch ?
Smart Transmitter Calibration Tutorial Part 2
4 Comments
  • John says:
    January 10, 2022 at 4:19 pm
    Accuracy = 0.0035 V
    Shouldn’t that be 0.0034V?
  • Sophia says:
    November 1, 2022 at 7:03 am
    Well explained with the help of examples.
  • Olivia says:
    November 1, 2022 at 7:05 am
    Good explanation. Helpful in clearing the basics.
  • Chuck says:
    May 24, 2023 at 5:06 am
    Thank You..
Single Position Calibration of Temperature Bath
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Electrical Standards
DP Level Transmitter with Zero Suppression Calibration
Types of Calibration
Sand Probe Functional Testing
Calibration of Temperature Sensor with Indicator
Calibration Procedure of Weighing Balance and Common Mistakes
Infrared Hydrocarbon Gas Detector Calibration Procedure
process chemical analyzer calibration
Automated Calibration
To check the characteristic of vibration probe
Pressure Transmitter Calibration at the bench
Impulse Line Pressure Testing Procedure
NIST Traceability
NIST Traceability
Uncertainty Calculations of Pressure Calibration
PLC Programming for Train Detection and Gate Operation
UL 489 Circuit Breaker
Difference Between UL489 and UL1077
Rotational Viscometer
What is a Viscometer? – Types, Applications, Advantages
Short Notes on Rectifiers & Filters
Inductor Principle
Inductance and Inductive Reactance
Working Principle of Overload Relay
Single-acting Pneumatic Cylinder operation with Limit Switch
Single-acting Pneumatic Cylinder Operation with Limit Switch
PLC Programming Example on Timers Function Block
