Reading: Moving Data between PLCs – Siemens Basics – TSEND TRCV
Inst Tools > Blog > PLC Tutorials > Moving Data between PLCs – Siemens Basics – TSEND TRCV
Learn how to do moving data between PLCs in this Siemens basics tutorial article based on the TSEND and TRCV function blocks.
Last updated: January 4, 2024 4:46 pm
Mahmoud Salama
11 Min Read
In the previous article, we talked about how to set up a connection between two PLCs using open user communication, and we used the TCP protocol to connect between two PLCs. We showed in the article how to use instructions like TCON and TDISCON to establish this connection.
Moving Data between PLCsSend Data to PLC_2Receive Data from PLC_1Simple logic to automatically create data valuesSimulation of the PLC project
In this article, we will show how we can start moving DATA between the PLCs we connected last article. We will use the TSEND and TRCV blocks for this purpose.
Send Data to PLC_2
We will build on the project we created in the last article, which means there are already the TCON and TDISCON blocks installed into our project. and we will continue our project by adding the TSEND and TRCV blocks to start moving data between the two PLCs.
To send data from PLC_1 into PLC_2 let’s start by creating a data block that will hold all information we need to send to PLC_2. See picture 1.
picture 1. Create a new data block.
As we discussed before, it is a better practice to give a proper naming to your blocks, that way it will be easy and intuitive to figure out what is each block are meant for.
Second, let’s add some data inside the Data block which we want to send to PLC_2.
We assumed that we need to send three different data tags. See picture 2.
TSEND TRCV in PLC Projects
picture 2. Define some data to send to PLC_2.
There is one more thing we need to do to be able to send the data block we just created to PLC_2 and that is to make sure the optimized block access of the Data block is not selected.
To do that we need to go to properties of the data block and unselect that option. See pictures 3 and 4.
Siemens Automation Communication
picture 3. Go to properties of data block.
PLC Data Sharing Protocols
picture 4. Uncheck the Optimized block access option.
Make sure to uncheck this option before using the TSEND block, or it won’t work.
Now that we prepared the data we want to send to the PLC_2 let’s actually attempt to send it. We will do that by using the TSEND block. Just drag and drop the instruction into your main OB1 to add it to your logic. See picture 5.
PLC Data Transmission Techniques
picture 5. Add TSEND block.
When adding the TSEND block you will be asked to create an instance data block because it is essentially a function block, again give it a proper name. See picture 6.
Cross-PLC Data Communication
Picture 6. Create data instance for the TSEND.
When the TSEND block is added into your logic, you will find that there are some important configurations we need to make. See picture 7.
PLC Data Transfer Basics
picture 7. The TSEND block.
As you can see, we need to make some configuration:
  • The REQ signal to allow the sending of the data.
As for the REQ signal, we will define a tag SendData that will be used to enable the sending of the data.
  • ID of the connection I will use to send the data, because I can have more than one connection, so I need to assign which connection will be used.
In the last article, we defined the ID 1 for the connection between PLC_1 and PLC_2, so we will set the ID to 1.
  • DATA that I need to send. We already created a data block with all information I need to send, we can simply just drag and drop the data block into the TSEND block. See picture 8.
picture 8. Configure the TSEND block.
After we setup the TSEND for sending the data to PLC_2, we need to receive these data inside the PLC_2. To do that we will use the TRCV block. See picture 9.
Tcon, Tdiscon, Tsend, And Trcv
picture 9. Add TRCV block.
As you can see, just drag and drop the TRCV block to add it into your logic. And you know that next we will need to create a data instance to that block. See picture 10.
Siemens TRCV
picture 10. Add data instance to TRCV block.
After the TRCV block is called into your logic, we will need to configure some parameters as we did with the TSEND. See picture 11.
Siemens TSEND
picture 11. The TRCV block.
As you can see, the EN-R is an enable signal that must be true to allow the TRCV block to start receiving the data. The ID is the connection that will be used and the DATA is where the received data will be stored.
So, we need to create a data block to receive the data inside it. Remember to give it a proper name. See picture 12.
Open user communication PROFINET
picture 12. Create data block to receive data.
Next, define the information tags that will be received from PLC_1, it is a best practice to ensure the data block hold the same data structure as the data that will be received. See picture 13.
SIEMENS S7 PLC to PLC Communication Example
picture 13. Define data tags.
For the EN-R, we will define a RecieveData tag to enable the data receive. And for the connection ID it is 1 as we set it up before. See picture 14.
Communication Between 2 PLCs
picture 14. EN-R signal.
Next, drag and drop the data block we created into our TRCV block to finish all configurations. See picture 15.
PLC to PLC Communication TIA Portal
picture 15. Add your data block into TRCV block.
When you drag and drop the DB we created, you will notice that TIA Portal is giving a warning and that it is not accepting the data block we just added.
And that is because we didn’t unchecked the “Optimized block access” of the data block as we did with TSEND. See picture 16.
Profinet to Siemens PLC
picture 16. Optimized block access.
As we said before, we have to uncheck this option otherwise the TSEND and TRCV won’t work. See picture 17.
Siemens S7 Data Transfer
picture 17. Uncheck the optimized block access option.
You can see that once we unchecked the “optimized block access” the data block is now accepted with the TRCV instruction.
Now that the calling and configuration of the TSEND and TRCV blocks is done. Let’s simulate our project and see how the data will be sent and received.
First we will create a simple logic that ensures that there are data values for our defined tags.
We will create a simple logic to automatically create and update the data values so it will be easier to see the data transfer between the two PLCs. See picture 18.
Siemens Networking Basics
picture 18. Simple logic.
This simple logic will use the clock bit %M50.5 to automatically change the values of the data stored inside SendToPLC_2 data block.
Let’s compile our project and start a simulation. The first thing we will need to do is to establish the connection between the two PLCs using the TCON block we configured last article.
Remember that we will need to enable the connection capability from PLC_2 and establish the connection with PLC_1. See pictures 19, 20 and 21.
Efficient PLC Data Handling
picture 19. No connection between PLCs
PLC Data Logging and Transmission
picture 20. enable the connection.
Siemens PLC Peer-to-Peer Communication
picture 21. Establish the connection.
Now, that we established the connection between the two PLCs let’s move the data from PLC_1 into PLC_2 as we set it up.
First, make the SendData tag TRUE. See picture 22.
Siemens Communication Blocks
Picture 22. REQ signal is true.
You can see that, even though the SendData is TRUE, there were no data sent from PLC_1 to PLC_2. And that is because the TRCV block is not yet enabled to receive any data. See picture 23.
Real-Time Data Exchange in PLCs
picture23. EN-R signal is false.
As you can see, because the RecieveData is not yet TRUE, the TRCV block is not enabled to receive any data. Once the EN-R is true the data will be sent from the data block in PLC_1 into the data block of PLC_2. See picture 24.
Siemens PLC Data Handling
picture 24. EN-R signal is True.
Once the EN-R is true, you can see that the data is moved from PLC_1 into PLC_2.
If you open the project and simulate it yourself, you will find the data is continuously being updated in PLC_1 and transferred into PLC_2.
And this is how we can establish a communication between two PLCs and use TSEND, TRCV blocks.
In the next article, we will talk about another compact block that can do the same functionality as the TCON, TDISCON and TSEND using one block.
Download the project files.
  • PLC Logic Document
  • PLC Source Code
  • Free Schneider PLC Training
  • Real-time PLC Automation Projects
  • How to Choose a PLC for a Project?
  • How to Configure Distributed IO?
  • Zigbee Based Project Ideas and List
Types of Digital Outputs in PLC
How to Start Writing SCL Language in Siemens Tia Portal?
How to Design an Effective HMI? – Human Machine Interface
Ladder Logic Example of Two Motors Interlinked with another Motor
Redundant Automation Systems – Need and Advantages
Parking Lights PLC Program Explained with Video
ESG in Industrial PLC Automation Systems
PLC Program for Motor Starter
PLC Programming for Traffic Barrier Control
Test and Process Modes in Siemens PLC
#4 PLC Best Practices – Use PLC Flags as Integrity Checks
Define the Order of Execution in Functional Block Diagram of Studio 5000
Free Mitsubishi PLC Online Training Courses
Free Mitsubishi PLC Online Training Course and Tutorials
PLC Program for Automatic Bottle Rejection System
Start the Counting from a Preset Value in PLC
Ladder Logic of Motor Forward and Reverse
PLC Programming Example for Motor Forward and Reverse Control
Machine Tool and Coolant Control PLC Ladder Logic
Machine Tool and Coolant Control: PLC Ladder Logic Design
Advanced Skills Required for a PLC Programmer to Get a Job
HMI Simulation for PID Controller
PID Controller Output Types – PID_PWM and PID_Output
Types of PLC
Loop Current Step Response (LCSR) Test for RTD
Response Time Test of RTD and Thermocouple
Eddy Current
Eddy Current Working Principle Animation
different PLC brands of Distributed IO
What is Distributed IO? – Decentralized Peripherals in PLC
High Level Alarm of Distillation Process
Investigate High Level Alarm of Distillation Process
Three phase inverter Animation
Three Phase Inverter Animation
Advanced Microcontroller Projects Using Proteus Simulation
Differential Pressure Transmitter
Calculate Process Variable from 4-20mA using Fraction of Measurement
Density-Measurement-using-DP-Transmitter-for-open-tank
Density Measurement for Open Tank with Constant Level Application
