Reading: Micro Memory Card (MMC) in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Micro Memory Card (MMC) in Siemens PLC
Last updated: March 4, 2021 11:27 am
In this article, we will learn about Micro Memory Card (MMC), which is used in Siemens PLC.
Micro Memory Card in Siemens PLCS7 – 300 Siemens PLCTypes
Siemens micro memory card
MMC means micro memory card which looks the same as SD card but contains a very small amount of space (1 MB, 8 MB, etc.)
Although it looks the same in size and shape, you can’t use MMC in SD slot and reverse is also not possible.
MMC card is used to store the PLC program written by the user. Siemens s7-300 and 400 series of the CPU can not run without having an MMC card in it.
In the loss of a power supply, MMC keeps retaining data. Earlier Li-ion battery was used to hold the program in case of the power fail.
We know that the CPU contains four types of memory.
  1. Load memory
  2. Working memory
  3. System memory
  4. Retentive memory
In all four memory types, when a person downloads a program to the PLC, one part of the program automatically saved to retentive memory which is called MMC.
S7-1200 and 1500 CPU also require MMC card but it is not necessary to keep inserted MMC in this type of the CPU.
This type of PLC only requires an MMC or SD when you have to update a parameter or in case of diagnostic events.
This higher range CPU contains inbuilt memory which used to retain the program. So, this type of CPU can run without MMC.
MMC Card in Siemens PLC
Types
In Siemens automation, both SD and MMC cards are used.
  • MMC cards are used with PLCs and
  • SD cards are used with the HMI.
MMC and SD Cards
The memory range for the MMC card is available from the lowest 64 kb to maximum up to 8 MB, whereas the SD card contain greater capacity of storage from 500 MB to a maximum of 2 TB.
You have to calculate the amount of space requires before choosing MMC.
It is always easy to recognize the memory card of the siemens. The green color card is always an MMC one and black is an SD card.
For example like s7-300 and 400 CPUs, remote I/Os, and VFD use green color MMC, whereas black color SD cards are used in s7-1200, 1500 CPUs, and HMIs.
Compact Flash (CF) Card
Apart from MMC and SD cards, there is one more type of card used in Siemens automation. Which recognize by its square shape and contains a higher capacity of the storage known as CF (compact flash).
Siemens Compact Flash (CF) Card
This type of card is used in motion control applications and HMIs.
Siemens MMC and SD cards play a very important role. For example, In the factory which produces the same type of machine/parts required to insert the program in it.
In such a scenario simply put a program in MMC and use the same program over and over by inserting MMC into CPU slot for about 5 to 10 seconds.
Author: Suhel Patel
  • Read-only Memory
  • Digital Logic Functions
  • Connect to Siemens S7 PLC
  • Non-mechanical Memory
  • Digital Memory Concepts
Finding the Best PLC for Your Project – Tips and Tricks
PID in Siemens TIA Portal
Tanks Draining Control in PLC using Functional Block Diagram
Toggle Switch & Sensor: Conveyor and Puncher PLC Program
PLC Program for Counting Moving Objects on Conveyor
Typical HMI Screen Design for Water Treatment Plant
FIFO Instruction in Allen Bradley PLC Programming
Scale and Normalize Instructions in PLC
Advanced Skills Required for a PLC Programmer to Get a Job
Raw Counts to Engineering Units : Conversion Formula
Motor ON OFF Logic in PLC
Job Skills Required for Industrial Electrical Maintenance
Schneider PLC Example Program for Star-Delta System
Design a Program Using Studio 5000 and FactoryTalk View Studio
Allen Bradley PLC communication is established
Procedure for Connecting Allen Bradley PLC and PC – RS Logix 500
Simple Conveyor Control PLC Program
XG5000 Example of Simple Conveyor Control PLC Program
PLC automation timers and counters
Siemens PLC Course for Beginners
Industrial Automation and Control Systems (IACS)
Introduction to Schneider PLC
Different Types of Schneider PLC
Control Loops
Single Bearing Motor Stator Winding
Critical High KiloWatt Motor Winding Burnout Threats
History of 3-15 psi, 10-50 mA, and 4-20 mA signals
Cut-outs between Platforms or Grating for Field Instruments
Ball Valve root cause
Ammonia Feed Ball Valve to Ship Tank Closed
Career Opportunities in Instrumentation Engineering
Job and Career Opportunities in Instrumentation Engineering
VFD Commissioning and Testing Procedure
Smart Drip Irrigation System Using PLC
